Performance:
It depends.
In your particular case there will be no performance difference because the two will be similarly laid out in memory.
In a very specific case (if you were using an empty struct as one of the data members) then the std::pair<>
could potentially make use of Empty Base Optimization (EBO) and have a lower size than the struct equivalent. And lower size generally means higher performance:
struct Empty {};
struct Thing { std::string name; Empty e; };
int main() {
std::cout << sizeof(std::string) << "\n";
std::cout << sizeof(std::tuple<std::string, Empty>) << "\n";
std::cout << sizeof(std::pair<std::string, Empty>) << "\n";
std::cout << sizeof(Thing) << "\n";
Prints: 32, 32, 40, 40 on ideone.
Note: I am not aware of any implementation who actually uses the EBO trick for regular pairs, however it is generally used for tuples.
Readability:
Apart from micro-optimizations, however, a named structure is more ergonomic.
I mean, map[k].first
is not that bad while get<0>(map[k])
is barely intelligible. Contrast with map[k].name
which immediately indicates what we are reading from.
It's all the more important when the types are convertible to one another, since swapping them inadvertently becomes a real concern.
You might also want to read about Structural vs Nominal Typing. Ente
is a specific type that can only be operated on by things that expect Ente
, anything that can operate on std::pair<std::string, bool>
can operate on them... even when the std::string
or bool
does not contain what they expect, because std::pair
has no semantics associated with it.
Maintenance:
In terms of maintenance, pair
is the worst. You cannot add a field.
tuple
fairs better in that regard, as long as you append the new field all existing fields are still accessed by the same index. Which is as inscrutable as before but at least you don't need to go and update them.
struct
is the clear winner. You can add fields wherever you feel like it.
In conclusion:
pair
is the worst of both worlds,
tuple
may have a slight edge in a very specific case (empty type),
- use
struct
Note: if you use getters, then you can use the empty base trick yourself without the clients having to know about it as in struct Thing: Empty { std::string name; }
; which is why Encapsulation is the next topic you should concern yourself with.
