I have an ASP.NET MVC 5 site.
I have several complex view models - usually subsets of a far larger model. Should I create items in the repository that take the ViewModels - then just use Dapper.net to map them to some SQL?
If not I would have to map the ViewModel to the Model somewhere. I can then use the standard Model Insert or Update. This causes two problems - how and where to map from ViewModel to Model (I don't want to create lots of work).
Also, where I am updating a subset of fields of a larger model - I want to avoid setting the fields that aren't in the ViewModel to NULL. If I just map a ViewModel to a Model - I will lose data.
It seems the simplest easiest solution is just to pass ViewModels in and out of Repositories. But is this bad practice? If so how can I make my other option (or a third option) work better?
niico
  • 241
This wouldn't necessarily be wrong for a very small, trivial app, or a quick'n'dirty KISS/YAGNI solution just to get something out of the door with minimal time or effort, but doesn't really fit with the spirit of the MVC pattern so I would caution against that as a general approach.
A few notes on MVC:
  • A ViewModel (A model of the view) belongs exclusively to your UI layer; not to your business layer or data layer.
  • The aim of the MVC pattern is to encapsulate all UI-specific concerns; decoupling the UI from the app. This allows the rest of the app to remain wholly agnostic to the UI; freed of any UI-specific constructs or concerns.
  • ViewModels can be reasonably expected to contain View-specific properties, and maybe custom logic describing how to display an item of data, as well as Data Annotations on top of the displayed properties.
  • Changes to a View are often facilitated by changes in the corresponding ViewModel; this indicates a very close dependency between the two.
By pushing ViewModels directly into your Repository, you risk introducing technical debt in a number of ways:
  1. If anything about your View changes, it can affect the ViewModel, which means it potentially affects the Repository too; this exposes you to the risk of future changes cascading and being "snowballed" across the app unnecessarily.
  2. Other views needing to re-use the same repository method would also need to know about the ViewModel used by the repository; even if those Views have their own separate ViewModels - that adds further danger to the cascading/snowballing effect of changes to the ViewModel.
  3. Using the ViewModel in this way implies direct interaction between the Controller and a Repository - that's all good in simple cases, but for anything nontrivial it involves additional logic which doesn't strictly belong in either class:
    • The responsibility of a Controller should ideally be limited to Creating a ViewModel from the service/business layer and injecting it into a View (or conversely, receiving an HTTP Request and using the request data to call into the service/business layer).
    • The responsibility of a Repository should ideally be limited to object persistence.
  4. Arguably, using a ViewModel in this way means it ceases to be a real ViewModel because you would need to move it into your Business layer or service layer to work; the result is having that layer effectively 'contaminated' by UI-specific concerns
When a simple call into your repository isn't enough and you need additional business logic to pull down the right kind of data into your controller, consider putting that logic into a separate Service class to ensure that neither your controllers nor repositories have that burden, for example:
public class MyLittleController : Controller
    // Service uses the Repositor(y/ies) internally and does a lot of work
    // to fulfil a request
    private IMyLittleService _service;
    public MyLittleController(IMyLittleService s) { _service = s; }
    // By using a service for the veryComplexQueryString, the only logic
    // in the controller is for deciding between a 404 or a ViewModel...
    public ActionResult MyLittleWebpage(string veryComplexQueryString)
        var adventurer = _service.QueryAdventurer(veryComplexQueryString);
        var quest = _service.GetQuest(adventurer?.Id);
        if (quest == null)
            return HttpNotFound();
        var model = new MyLittleViewModel
            Name = adventurer.Name,
            Quest = quest.Name,
            FavouriteColour = adventurer.FavouriteColour,
        return View(model);
Bridging the divide between your Business Layer and your Presentation Layer is the responsibility of your Controller, which includes mapping to/from your ViewModels. You could consider doing the actual work within Helper methods or use a library such as AutoMapper. (Related question on SO)
Sometimes its easier to use a different model for your POST and PUT requests. A ViewModel is for your UI state, so it's only real purpose is to be used in an action which returns a View().
POST/PUT requests are about issuing commands, and a POST/PUT action usually isn't expected to return View(model); (usually a RedirectToAction instead). A POST/PUT action usually only needs to be a 'pass through' to some service class, in which case the domain models could be used for the request instead.
Update in response to the comment about Data Annotations:
Luckily, Dapper itself ignores Data Annotations so that shouldn't cause you any problems. Most of the time each framework uses it's own Data Annotations in fact; the real danger of using across many layers is not really a technical one and more of a 'code cleanliness' issue, and conceptually it starts to feel like a violation of SRP (a single model which serves different purpose depending where it's used).
As an aside, I once reviewed some code whereby somebody had managed to reuse the same Model for a whole bunch of different libraries and tools - it had various properties and attributes which were used in different frameworks in it. The reality of reusing Models in too many places can often look a bit like this:
[XmlElement("Album")]
public class Album
    [DisplayName("Album ID")]
    [ScaffoldColumn(false)]
    [Key("Id")]
    [XmlAttribute("id")]
    public int AlbumId { get; set; }
    [DisplayName("Genre ID")]
    [ForeignKey("Genre")]
    [XmlIgnore]
    public int GenreId { get; set; }
    [DisplayName("Artist ID")]
    [ForeignKey("Artist")]
    [XmlIgnore]
    public int ArtistId { get; set; }
    [DisplayName("Album Title")]
    [Required]
    [StringLength(80)]
    [XmlAttribute("albumTitle")]
    public string Title { get; set; }
    [NotMapped]
    [DisplayName("Album")]
    [XmlAttribute("AlbumName")]
    public string AlbumName { get; set; }
As somebody trying to read a model like this and figure out which attributes or properties are used at which layer it becomes a lot to think about; and all in the name of merely "saving" a few lines of code to map between models.
Furthermore, you do run the risk that some of the annotations could end up having an effect in the wrong place; again this is more of a risk with an ORM such as EntityFramework which also uses some of those same attributes as ASP.NET
Ben Cottrell
  • 11,656
  • 30
  • 41
  • Thanks for the comprehensive answer. On the final point - are you saying I need to create a new model - that isn't the full model (that mirrors the Db), that isn't a view model, but that is just used for updating a subset of data? – niico Mar 18 '17 at 10:08
  • @niico If necessary, yes - it could either be a completely new model which is only used for your POST/PUT request(s), or you might be able to use an existing Model from the business layer if there happens to be an appropriate one already with the right subset of fields. usually POST/PUT requests aren't tied into View/UI functionality, so it can make sense to put request models into the business layer, since they're really just the REST equivalent of a method parameter object. – Ben Cottrell Mar 18 '17 at 10:16
  • You mention that the only purpose of the ViewModel is for UI state. However - the overlap with a model just used for updating is huge - they will either be identical or virtually identical. Would making this new model not violate DRY principles? – niico Mar 18 '17 at 10:24
  • You mention Data Annotations on ViewModels - could this cause problems if ViewModels are used to insert or update data? – niico Mar 18 '17 at 10:35
  • Exactly where would you put these new models out of interest (in which project / folder). I have projects: Data, Model, MVCWebsite – niico Mar 18 '17 at 10:35
    @niico Your concern about violating DRY is a valid one, and certainly understandable - for that topic, I personally agree with the top answer on this thread: [Uncle Bob's clean architecture - An entity/model class for each layer?](http://softwareengineering.stackexchange.com/questions/303478/uncle-bobs-clean-architecture-an-entity-model-class-for-each-layer) – Ben Cottrell Mar 18 '17 at 12:49
  • .. as for where to put the models (assuming these are models you are using for Dapper), then they're technically part of your data layer, so whichever project contains your ORM mapping code seems would make sense to me – Ben Cottrell Mar 18 '17 at 12:50
  • What about this - hydrating a full model to and from the Data layer. But when Updating, call the update method in the data layer something like UpdateThisSubset - and only update the fields concerning the subset. No ViewModels in Data layer, no DRY violation & super quick & easy? That does still require mapping of ViewModel to Model though. – niico Mar 19 '17 at 13:50
    @niico I see nothing wrong with that idea; you're getting into greater detail; the concepts of separation between layers, as well as the various patterns for Repository, MVC, etc are all intended to solve the high-level architecture concerns and keep the code clean. Those sorts of nitty-gritty details are more a matter of careful judgement; if it still fits with SOLID,DRY,etc then you're probably not doing anything wrong. – Ben Cottrell Mar 19 '17 at 15:51
  • I've gone down this path now with some development - it works but I am constantly having to write mapping code from view model to model & back in the controller. Yes, there is AutoMapper etc - although that seems risky and I need to specifically state what I'm mapping - it's a dependency and it just seems easier to manually map it. Perhaps I just have to accept doing things "correctly" in this case - is significantly more work - maybe it's not worth it on this smallish project with 1 dev?! How do I make that call? – niico Mar 21 '17 at 09:01
  • @niico I personally always apply this sort of separation even on small projects as well as larger ones because large projects often start out small. Over time I've found the pain of refactoring later to be worse (because refactoring changes are more likely to break existing stable/working code). While it can certainly be tedious, I don't find it excessively time-consuming for new code. I usually stick hand-rolled mapping code into helper methods; so while there's a lot of extra boilerplate code, that keeps it out of the way and stops it from cluttering the important stuff. – Ben Cottrell Mar 21 '17 at 12:03
  • @niico On the other hand, if you decide you really don't want all those extra mapped classes, then you could wait until you find a need for it. Mapping across models is an elegant way to solve problems where the model requirements for your Views are different to the model requirements for your business layer or data layer (such as wanting "subsets" of data). If it doesn't solve any problems, then you're probably not getting anything out if it (yet..). – Ben Cottrell Mar 21 '17 at 12:05
  • So what you're saying is putting ViewModels in the Repository layer is OK for smaller projects?! – niico Mar 21 '17 at 13:21
    @niico If it works for you, then that's really a judgement call for you to make. Objectively speaking, any solution which works (and you're happy with) is totally valid as a solution, it just means you might have 'technical debt' to pay down later if your ViewModel needs to change in future; but that's an inevitable part of sometimes being pragmatic and getting things done more quickly. – Ben Cottrell Mar 21 '17 at 18:08
