40
When transferring object through an API, as in schemaless JSON format, what is the ideal way to return non-existent string property? I know that there are different ways of doing this as in examples in the listed links below.
I'm sure I have used null in the past but don't have a good reason to give for doing that. It seems straight forward to use null when dealing with the database. But database seems like an implementation detail that shouldn't concern the party on the other side of the API. E.g. they probably use a schemaless datastore that only store properties with values (non-null).
From a code point of view, restricting string functions to work only with one type, i.e. string (not null), makes them easier to prove; avoiding null is also a reason for having Option object. So, if the code that produces request/response doesn't use null, my guess is the code on the other side of the API won't be forced to use null too.
I rather like the idea of using an empty string as an easy way to avoid using null. One argument that I heard for using null and against the empty string is that empty string means the property exists. Although I understand the difference, I also wonder if it's the just implementation detail and if using either null or empty string makes any real life difference. I also wonder if an empty string is analogous to an empty array.
So, which is the best way of doing it that addresses those concerns? Does it depend on the format of the object being transferred (schema/schemaless)?
imel96
  • 3,488
    Also note that Oracle treats empty strings and null-strings the same way. And right there are: on a paper questionnaire, how could you distinguish between no answer given and an answer consisting of an empty string? – Bernhard Hiller Mar 14 '17 at 10:56
  • If you use inheritance, it is easy to say `if( value === null) { use parent value; }` However, if you set the child value, even to an empty string (e.g. override the default parent value with blank), then how do you "re-inherit" the value? To me, setting it as null would mean "unset this value so we know to use the parent value." – Frank Forte Sep 28 '18 at 17:15
  • Since "Remove empty property" is also why to "avoid" a `null` (it is true that `null` is avoided as such), the questioner means "Return non-null" [Object] (i.e: empty String, empty Array, etc) when they write "avoid". – cellepo Sep 07 '19 at 17:47
8 Answers8
36
TLDR; Remove null properties
The first thing to bear in mind is that applications at their edges are not object-oriented (nor functional if programming in that paradigm). The JSON that you receive is not an object and should not be treated as such. It's just structured data which may (or may not) convert into an object. In general, no incoming JSON should be trusted as a business object until it is validated as such. Just the fact that it deserialized does not make it valid. Since JSON also has limited primitives compared to back-end languages, it is often worth it to make a JSON-aligned DTO for the incoming data. Then use the DTO to construct a business object (or error trying) for running the API operation.
When you look at JSON as just a transmission format, it makes more sense to omit properties that are not set. It's less to send across the wire. If your back-end language does not use nulls by default, you could probably configure your deserializer to give an error. For example, my common setup for Newtonsoft.Json translates null/missing properties to/from F# option types only and will otherwise error. This gives a natural representation of which fields are optional (those with option type).
As always, generalizations only get you so far. There are probably cases where a default or null property fits better. But the key is not to look at data structures at the edge of your system as business objects. Business objects should carry business guarantees (e.g. name at least 3 characters) when successfully created. But data structures pulled off the wire have no real guarantees.
Kasey Speakman
  • 4,341
  • 26
    While most modern serializers have optional fields, omitting nulls from the response is **not** always a good idea, because it may introduce additional complexity to handle nullable fields. Thus, it is really *case-dependent*, depending on how your serialization library handles nullables, and whether or not the (potential) additional complexity of handling those nullables is *really* worth saving a few bytes per request. You must work hard to analyze your business cases. – Chris Cirefice Mar 14 '17 at 20:07
  • @ChrisCirefice Yes, I believe the last paragraph covers that. There are cases where it will be better to employ different strategies. – Kasey Speakman Mar 14 '17 at 20:37
  • I agree that JSON is used only as transmission format, it's not passing object through the wires like CORBA. I also agree that properties can be added and removed; representations can change, controls can change, especially on the web. – imel96 Mar 20 '17 at 16:17
20
Going with an empty string is a definitive no. Empty string still is a value, it is just empty. No value should be indicated using a construct which represents nothing, null.
From API developer's point of view, there exist only two types of properties:
  • required (these MUST have a value of their specific type and MUST NOT ever be empty),
  • optional (these MAY contain a value of their specific type but MAY also contain null.
This makes it quite clear that when a property is mandatory, ie. required, it can never be null.
On the other hand, should an optional property of an object not be set and left empty, I prefer to keep them in the response anyway with the null value. From my experience it makes it easier for the API clients to implement parsing, as they're not required to check whether a property actually exists or not, because it's always there, and they can simply convert the response to their custom DTO, treating null values as optional.
Dynamically including/removing fields from the response forces including additional conditions on the clients.
Either way, whichever way you choose, make sure you keep it consistent and well documented. That way it really does not matter what you use for your API, as long as the behaviour is predictable.
Andy
  • 10,238
  • 50
  • Yes, empty string is a value and I use `null` for references. Mixing values with references is one of my concern. How do you differentiate optional fields with `null` from a non-optional string fields that have `null` value? Re parsing, isn't not testing property existence makes the parser more fragile? – imel96 Mar 13 '17 at 16:08
    @imel96 Non-optional fields can NEVER be null. If something is non-optional it MUST always contain a value (of its specific type). – Andy Mar 13 '17 at 16:35
    This. As a frequent consumer of APIs, I hate when I have to deal with "dynamic" structures coming back to me, even if it's in the form of an optional field being omitted. (also much agreed that there's a big difference between a ZLS and a Null). I'd happily accept null values all day long. As an API author, one of my goals is to make client consumption as painless as possible, and that means having expected data structures, always. – jleach Mar 14 '17 at 02:27
  • @DavidPacker so, if I understand correctly, you use `null` to indicate the value is optional. So, when you define an object which has a non-optional string property, and the consumer doesn't have this property, it has to send empty string for that property. Is that right? – imel96 Mar 14 '17 at 15:22
  • @imel96 Can you provide an example of a property the client would not have? – Andy Mar 14 '17 at 16:48
  • There's a fourth option here: using an array with 0 or 1 elements. If the property is optional, use `[]` when it's absent and `["some concrete value"]` when it's present. – Greg Nisbet Mar 14 '17 at 20:40
    @GregoryNisbet Do not do that, please. That makes no sense. – Andy Mar 15 '17 at 08:54
  • @DavidPacker one example that I've seen a few times is home phone number in contacts. Quite often people send empty strings even when documentation says null is allowed. My guess is people then to do that when the source is human filled forms, send everything to the API endpoint. Using null would require converting the empty field values into nulls. Same for responses, if they're coming from database nullable columns, it's easier to just send null (without converting to empty string). – imel96 Mar 15 '17 at 15:29
  • @DavidPacker It's just using a 0 or 1-element array as a stand in for an option type. That way the keys don't change when an optional property is absent, and you aren't using a particular value like `null` or `""` to represent the absence of a value. If the value of your property can be any JSON value (rather than being constrained to be a string), then using an array is a natural choice. – Greg Nisbet Mar 15 '17 at 16:21
  • @imel96 You as an API developer do not care about the values that you receive as long as the request is valid. If a property is required, your API MUST NOT accept a `null` or an empty value (ie. an empty string), it must actively refuse it (in REST world that is using the 400 code). If the format is actually correct, you may write in documentation that you are treating empty strings as missing values and converting them to `null`s. For empty optional fields you would then return the `null` values. It's up to the API clients what they do with it, it's their responsibility, not yours. – Andy Mar 15 '17 at 22:52
null Usage is Application/Language Dependent
Ultimately the choice of whether or not to use null as a valid application value is largely determined by your application and programming language/interface/edge.
At a fundamental level, I'd recommend trying to use distinct types if there are distinct classes of values. null may be an option if your interface allows it and there are only two classes of a property you're trying to represent. Omitting a property may be an option if your interface or format allows it. A new aggregate type (class, object, message type) may be another option.
For your string example, if this is in the programming language, I'd ask myself a couple questions.
  1. Do I plan on adding future types of values? If so, an Option will probably be better for your interface design.
  2. When do I need to validate consumers calls? Statically? Dynamically? Before? After? At all? If your programming language supports it, use the benefits of static typing as it avoids the amount of code you have to create for validation. Option probably fills this case best if your string was non-nullable. However, you're probably going to have to check user input for a null string value anyways though, so I'd probably defer back to the first line of questioning: how many types of values do/will I want to represent.
  3. Is null indicative of a programmer error in my programming language? Unfortunately, null is often the default value for uninitialized (or non-explicitly initialized) pointers or references in some languages. Is null as a value acceptable as the default value? Is it safe as a default value? Sometimes null is indicative of deallocated values. Should I provide consumers of my interface with an indication of these potential memory management or initialization problems in their program? What's the failure mode of such a call in the face of such problems? Is the caller in the same process or thread as mine so that such errors are a high risk to my application?
Depending on your answers to these questions, you'll probably be able to hone in on whether or not null is right for your interface.
Example 1
  1. Your application is safety critical
  2. You're using some type of heap initialization on startup and null is a possible string value passed back upon failure to allocate space for a string.
  3. There's a a potential such a string hits your interface
Answer: null is probably not appropriate
Rationale: null in this case is actually used to indicate two different types of values. The first may be a default value which the user of your interface may want to set. Unfortunately, the second value is a flag to indicate that your system is not functioning correctly. In such cases, you probably want to fail as safely as possible (whatever that means for your system).
Example 2
  1. You're using a C struct which has a char * member.
  2. Your system does not use heap allocation and you're using MISRA checking.
  3. Your interface accepts this struct as a pointer and checks to make sure that struct does not point to NULL
  4. The default and safe value of the char * member for your API can be indicated by a single value of NULL
  5. Upon your user's struct initialization, you would like to provide the user the possibility of not explicitly initializing the char * member.
Answer: NULL may be appropriate
Rationale: There is a little chance that your struct passes the NULL check but is uninitialized. However, your API may not be able to account for this unless you have some sort of checksum on the struct value and/or range checking of the address of the struct. MISRA-C linters may help users of your API by flagging usage of structs before their initialization. However, as for the char * member, if the pointer to struct points to an initialized struct, NULL is the default value of an unspecified member in a struct initializer. Therefore, NULL may serve as a safe, default value for the char * struct member in your application.
If it's on a serialization interface, I'd ask myself the following questions about whether or not to use null on a string.
  1. Is null indicative of a potential client side error? For JSON in JavaScript, this is probably a no as null isn't necessarily used as an indication of allocation failure. In JavaScript, it is used as an explicit indication of object absence from a reference to be set problematically. However, there are non-javascript parsers and serializers out there that map JSON null to the native null type. If this is the case, this begs the discussion of whether or not native null usage is okay for your particular language, parser and serializer combination.
  2. Does explicit absence of a property value impact more than a single property value? Sometimes a null is actually indicating that you have a new message type entirely. It may be cleaner for your consumers of the serialization format to just specify a completely different message type. This ensures that their validation and application logic can have clean separation between the two distinctions of messages that your web interface provides.
General Advice
null can not be a value on an edge or interface that does not support it. If you're using something that's extremely loose in nature on the typing of values of properties (i.e. JSON), try to push some form of schema or validation on the consumers edge software (e.g. JSON Schema) if you can. If it's a programming language API, validate the user input statically if possible (via typing) or as loud as is sensible in runtime (a.k.a. practice defensive programming on consumer facing interfaces). As importantly, document or define the edge so there's no question as to:
  • What type(s) of value a given property accepts
  • What ranges of value are valid for a given property.
  • How an aggregate type should be structured. What properties must/should/can be present in an aggregate type?
  • If it's some type of container, how many items can or should the container hold, and what are the types of values the container holds?
  • What order, if any, are properties or instances of a container or aggregates type returned?
  • What side-effects are there of setting particular values and what are the side effects of reading those values?
backscattered
  • 218
Here my personal analysis of these questions. It is not backed by any book, paper, study or whatever, just my personal experience.
Empty strings as null
This is a no-go for me. Do not mix the semantics of empty string with that of non-defined. In many cases they may be perfectly interchangeable, but you can run into cases where non-defined and defined-but-empty do mean something different.
A kind of stupid example: let's say there is an attribute that stores a foreign key, and that attribute is not defined or is null, that would mean that there is no relation defined, whereas an empty string "" could be understood as a defined relation and the ID of the foreign record is that empty string.
Not defined vs null
This is not a black or white topic. There are pros and cons to both approaches.
In favour of explicitly defining null values, there are these pros:
  • The messages are more self-descriptive in that you get to know all the keys just by looking at any message
  • Related to the previous point, it is easier to code and detect errors in the consumer of the data: it is easier to detect errors if you fetch the wrong keys (maybe misspelling, maybe the API changed, etc).
In favour of assuming a non existing key equals the semantics of null:
  • Some changes are easier to accomodate. For instance, if a new version of the message schema includes a new key, you can code the consumer of the information to work with this future key, even when the producer of the message has not been updated and does not serve this information yet.
  • Messages can be less verbose or shorter
In case the API is somehow stable, and you thoroughly document it, I think it is perfectly OK to state that a non-existent key equals the meaning of null. But if it is more messy and chaotic (as it pretty often is), I think you can avoid headaches if you explicitly define every value in every message. I.e. if in doubt, I tend to follow the verbose approach.
All that said, the foremost important thing: state your intentions clearly and be consistent. Don't do one thing here and the other one there. Predictable software is better software.
bgusach
  • 596
  • The example for using empty strings is what I mean by implementation detail, i.e. assuming the API is used to expose database rows. Will it make any difference if there's no database involved and purely for transferring object representations? – imel96 Mar 13 '17 at 15:18
  • It does not have to be an implementation detail. My example actually talks about PKs which are DB related, but what I tried to explain is that an empty string is not nil/nothing/`null`. Another example: in a game, there is a character object, and it has a "partner" attribute. A `null` partner clearly means that there is no partner at all, but `""` can be understood as there is a partner whose name is `""`. – bgusach Mar 13 '17 at 15:28
  • I'm okay with null partner _reference_ means there's no partner and also _reference_ is not a string. But partner name is a string, even if you allow null as partner name, wouldn't you catch that null and replace it with empty string at some point? – imel96 Mar 13 '17 at 15:47
  • If there is no partner, I would not change the `null` for an empty string. Maybe rendering it in a form, but never in the data model. – bgusach Mar 13 '17 at 16:35
  • I didn't mean no partner, partner would be an object. It's the partner `name` that I was talking about, would you allow partner name to be null? – imel96 Mar 14 '17 at 15:26
  • For the sake of simplicity, I thought that `partner` would not contain an object but a string, e.g. `"johnny"`... and then again, if no partner, I would just set the attribute to `null` instead of the empty string, since technically it is possible that somebody has the unfortunate name of `""`. – bgusach Mar 14 '17 at 21:35
I would supply an empty string in a situation where a string is present, and it happens to be an empty string. I would supply null in a situation where I want to explicitly say "no, this data is not there". And omit the key to say "no data there, don't bother".
You judge which of these situations can happen. Does it make sense for your application to have empty strings? Do you want to distinguish between saying explicitly "no data" by using null and implicitly by having no value? You should only have both possibilities (null and no key present) if both need to be distinguished by the client.
Now keep in mind that this is all about transmitting data. What the receiver does with the data is their business, and they will do what is most convenient to them. The receiver should be able to handle anything you throw at it (possibly by rejecting the data) without crashing.
If there are no other considerations, then I would transmit what is most convenient for the sender, and document it. I'd prefer not to send absent values at all because this is likely to improve the speed of encoding, transmitting and parsing JSON.
gnasher729
  • 42,090
  • 59
  • 119
Although I cannot say what is best it is almost certainly not a simple implementation detail, it changes the structure of how you can interact with that variable.
If something can be null you should always treat it as if it will be null at some point, so you will always have two workflows, one for null, one for a valid string. A split workflow isn't necessarily a bad thing, as there's quite a bit of error handling and special-case-uses which you could utilise, but it does obfuscate your code.
If you always interact with the string in the same way it will probably be easier for the functionality to stay in your head.
So as with any "what is best" question I'm left with the answer: it depends. If you want to split your workflow and more explicitly capture when something is not set, use null. If you would rather the program just keep doing as it does, use an empty string. The important thing is that you are consistent, pick a common return and stick with that.
Considering you are creating an API, I would recommend sticking to an empty string as there's less for the user to compensate for, because as a user of an API I won't know every reason your API could give me a null value unless you're very well documented, which some users won't read anyway.
Erdrik Ironrose
  • 4,806
  • Having "split workflow" is bad. Lets say on the producer side everything is clean, string type methods only return `string`s, never null. If the API uses null, then at some point the producer needs to create this `null` to conform with the API. Then the consumer needs to handle `null` too. But I think I got what you're saying, just decide and define the API with authority, right? Does that mean that there's nothing wrong with any of them? – imel96 Mar 14 '17 at 15:48
  • Yes, whatever you do in your API will impact how the user will have to structure their code, so considering your design in terms of the user of the API you should be able to define which way is best. Ultimately it's your API. Just be consistent. Only you can decide the pros and cons to the approach. – Erdrik Ironrose Mar 15 '17 at 10:44
Document!
TL;DR>
Do as you see fit - sometimes the context in which it is used matters. Example, Bind Variables to an Oracle SQL: Empty String is interpreted as a NULL.
Simply I would say - Make sure you document each scenario mentioned
  • NULL
  • Blank (empty)
  • Missing (removed)
Your code might act in different ways to it - document how your code reacts to it:
  • Fail (Exception etc), maybe even fails validation (possibly a checked exception) vs can't handle the situation correctly (NullPointerException).
  • Provide reasonable defaults
  • Code behaves differently
Then in addition to that - it is up to you to behave consistently, and possibly adopt some of your own best practices. Document that consistent behavior. Examples:
  • Treat Null and Missing the same
  • Treat an empty string exactly as such. Only in the case of a SQL bind, it might be considered a blank. Make sure your SQL behaves consistently and in an expected way.
YoYo
  • 576
  • The problem is, without addressing the concerns, disagreement happened quite often. Consider in team environment, the decision has to be team decision, a lot of times that mean there would be an argument. When you have multiple teams, every team is entitled to their own decisions. I've seen APIs that I can only guess that they're implemented by different teams that don't agree with each other. If any one can agree to one thing, documenting it is trivial. – imel96 Mar 15 '17 at 15:41
tl;dr - if you use it: be consistent in what it means.
If you included null, what would it mean? There is a universe of things what it could mean. One value is simply not enough to represent a missing or unknown value (and these are only two of the myriad of possibilities: e.g. Missing - it was measured, but we don't know it yet. Unknown - we didn't try to measure it.)
In an example I came across recently, a field could be empty because it was not reported to protect someone's privacy, but it was known on side of sender, not known at side of sender, but know to the original reporter or unknown to both. And all of these mattered to the receiver. So usually one value is not enough.
With an open world assumption (you simply don't know about things not stated), you would just leave it out and it could be anything. With closed world assumption (things not stated are false, for example in SQL) you better make clear what null means and be as consistent with that definition as you can...
Grimaldi
  • 244
