public class TaskA implements Runnable {
public class TaskB implements Runnable {
I have two runnable class as TaskA, TaskB. I want to have a TaskManager to run these two tasks and have possibility to add more task in the future. So I have the TaskManager as following:
public class TaskManager {
    private ThreadPoolExecutor threadPool;
    private Object task;
    public TaskManager(TaskA task) {
        this.task = task;
    public TaskManager(TaskB task) {
        this.task = task;
    public void startThreadPool() {
        threadPool = new ThreadPoolExecutor(...);
        threadPool.execute((Runnable) task);
I would like to know whether it is a good practice? If not, anyone have any suggestion? should we use consumer or so to implement this one?
c2340878
  • 79
    `private Runnable task;`... and I'm not sure what your `TaskManager` offers above and beyond what the `ThreadPoolExecutor` offers anyway. –  Mar 07 '17 at 01:37
Since it seems you only use task as a Runnable internally, use Runnable instead of Object. Change your third line to:
private final Runnable task;
Simple, saves you a cast later. And I'd consider renaming it from "task" to "runnable" for clarity, if that makes more sense.
user949300
  • 8,679
  • 26
  • 35
TLDR:
Use just one constructor that accepts a Runnable and a member of type Runnable.
Long answer:
If you really, really need to have two difrerent constructors, one that receives a TaskA and one that receives a TaskB, (one possible reason is that TaskManager calls methods that are particular to TaskA or TaskB) then you have two options:
  1. Have two members, private TaskA taskA and private TaskB taskB
  2. Have just one member private Runnable task, since Runnable is the common ancestor of TaskA and TaskB
In the other hand, if you don't really need a constructor for each type of task, you can have just one constructor public TaskManager(Runnable task) and only one member of type Runnable like in option 2 previously stated.
It all dependends of whether or not you will need to call methods that are particular to TaskA or TaskB. If TaskManager only really cares about the Runnable contract then there's no need for two constructors, let alone having to cast an Object to a Runnable to run it.
Lastly, if TaskManager really needs something from the tasks beside the Runnable functionality, then create a RunnableTask like this:
public interface RunnableTask extends Runnable {
    public int getThis();
    public int getThat();
public class TaskA implements RunnableTask { ... }
public class TaskB implements RunnableTask { ... }
    private RunnableTask task;
    public TaskManager(RunnableTask task) {
        this.task = task;
        threadPool.execute(task);
        // do somewthing with task.getThis();
        // do somewthing with task.getThat();
Tulains Córdova
  • 39,201
  • 154
