16
I am trying to write a servlet which does task based on the "action" value passed it to as input.
Here is the sample of which
public class SampleClass extends HttpServlet {
     public static void action1() throws Exception{
          //Do some actions
     public static void action2() throws Exception{
          //Do some actions
     //And goes on till action9
     public void doPost(HttpServletRequest req, HttpServletResponse res)throws ServletException, IOException {
          String action = req.getParameter("action");
           * I find it difficult in the following ways
           * 1. Too lengthy - was not comfortable to read
           * 2. Makes me fear that action1 would run quicker as it was in the top
           * and action9 would run with a bit delay - as it would cross check with all the above if & else if conditions
          if("action1".equals(action)) {
               //do some 10 lines of action
          } else if("action2".equals(action)) {
               //do some action
          } else if("action3".equals(action)) {
               //do some action
          } else if("action4".equals(action)) {
               //do some action
          } else if("action5".equals(action)) {
               //do some action
          } else if("action6".equals(action)) {
               //do some action
          } else if("action7".equals(action)) {
               //do some action
          } else if("action8".equals(action)) {
               //do some action
          } else if("action9".equals(action)) {
               //do some action
           * So, the next approach i tried it with switch
           * 1. Added each action as method and called those methods from the swith case statements
          switch(action) {
          case "action1": action1();
               break;
          case "action2": action2();
               break;
          case "action3": action3();
               break;
          case "action4": action4();
               break;
          case "action5": action5();
               break;
          case "action6": action6();
               break;
          case "action7": action7();
               break;
          case "action8": action8();
               break;
          case "action9": action9();
               break;
          default:
               break;
           * Still was not comfortable since i am doing un-necessary checks in one way or the other
           * So tried with [reflection][1] by invoking the action methods
          Map<String, Method> methodMap = new HashMap<String, Method>();
        methodMap.put("action1", SampleClass.class.getMethod("action1"));
        methodMap.put("action2", SampleClass.class.getMethod("action2"));
        methodMap.get(action).invoke(null);
        * But i am afraid of the following things while using reflection
        * 1. One is Security (Could any variable or methods despite its access specifier) - is reflection advised to use here?
        * 2. Reflection takes too much time than simple if else
All i need is to escape from too many if/else-if checks in my code for better readability and better code maintanance. So tried for other alternatives like
1.switch case - still it does too many checks before doing my action
2.reflection
i]one main thing is security - which allows me to access even the variables and methods within the class despite of its access specifier - i am not sure weather i could use it in my code
ii] and the other is it takes time more than the simple if/else-if checks
Is there any better approach or better design some one could suggest to organise the above code in a better way?
EDITED
I have added the answer for the above snippet considering the below answer.
But still, the following classes "ExecutorA" and "ExecutorB" does only a few lines of code. Is it a good practice to add them as a class than adding it as a method? Please advise in this regard.
Tom Taylor
  • 356
    Possible duplicate of [Approaches to checking multiple conditions?](http://softwareengineering.stackexchange.com/questions/191208/approaches-to-checking-multiple-conditions) – gnat Mar 06 '17 at 08:22
    Why are you overloading a single servlet with 9 different actions? Why not simply map each action to a different page, backed by a different servlet? That way selection of the action is done by the client and your server code just focuses on serving the client's request. – Maybe_Factor Mar 15 '17 at 03:38
6 Answers6
14
Based on the previous answer, Java allows enums to have properties so you could define a strategy pattern, something like
public enum Action {
    A ( () -> { //Lambda Sintax
        // Do A
    B ( () -> executeB() ), // Lambda with static method
    C (new ExecutorC()) //External Class
    public Action(Executor e)
        this.executor = e;
    //OPTIONAL DELEGATED METHOD
    public foo execute() {
        return executor.execute();
    // Action Static Method
    private static foo executeB(){
    // Do B
Then your Executor (Strategy) would be
public interface Executor {
    foo execute();
public class ExecutorC implements Executor {
    public foo execute(){
        // Do C
And all your if/else in your doPost method become something like
public void doPost(HttpServletRequest req, HttpServletResponse res) throws ServletException, IOException {
    Action.valueOf(action).execute();
This way you could even use lambdas for the executors in the enums.
J. Pichardo
  • 911
  • well said.. But i need a small clarification.. All my actions action1(), action2() would be few lines of code.. will it be good to pack it within a class? – Tom Taylor Mar 06 '17 at 08:41
    This is not the number of lines that should convince you to create specific classes/objects, but the fact that they represent different behaviours. 1 idea/concept = 1 logical object. – mgoeminne Mar 06 '17 at 10:29
    @RajasubaSubramanian You could also use a lambda or method reference if you feel that a class is too heavy. `Executor` is (or can be) a functional interface. – Hulk Mar 06 '17 at 11:28
  • @RajasubaSubramanian I made an update with Lambda examplesl – J. Pichardo Mar 06 '17 at 16:38
    @J.Pichardo Thanks for the update :) Since I'm still in java7 I couldn't use lambda expression.. So, followed the enum implementation of strategy pattern suggested here at https://dzone.com/articles/strategy-pattern-implemented – Tom Taylor Mar 07 '17 at 03:10
    @RajasubaSubramanian cool, I learned something new, – J. Pichardo Mar 07 '17 at 03:42
Instead of using reflection, use a dedicated interface.
ie instead of :
Use
 public interface ProcessAction{
       public void process(...);
Implements each of them for each actions and then :
 // as attribute
Map<String, ProcessAction> methodMap = new HashMap<String, ProcessAction>();
// now you can add to the map you can either hardcode them in an init function
methodMap.put("action1",action1Process);
// but if you want some more flexibility you should isolate the map in a class dedicated :
// let's say ActionMapper and add them on init :
public class Action1Manager{
    private static class ProcessAction1 implements ProcessAction{...}
    public Action1Manager(ActionMapper mapper){
       mapper.addNewAction("action1", new ProcessAction1());
Of course this solution isn't the lighest, so you may not need to go up to that length.
Walfrat
  • 3,456
  • 26
  • i think it must be `ProcessAction` instead of `ActionProcess` is that so... ? – Tom Taylor Mar 06 '17 at 08:47
    Yes I fixed it. – Walfrat Mar 06 '17 at 08:49
    And, more generally, the answer is "use OOP mechanisms". So, here, you should reify the "situation" and its associated behaviour. In other words, representing your logic by an abstract object, and then manipulate this object instead of its underlying nuts and bolts. – mgoeminne Mar 06 '17 at 10:26
  • Also, a natural extension of the approach proposed by @Walfrat would consist in proposing an (abstract) factory that creates/returns the right ProcessAction depending on the specified String parameter. – mgoeminne Mar 06 '17 at 10:32
  • @mgoeminne That sound about right – J. Pichardo Mar 06 '17 at 14:50
  • If Java 8 is allowed, instead of reflection, you can use something like `map.put("action-1", new Consumer{void accept() { do the action; }});`. – 9000 Apr 06 '17 at 21:38
Use the Command Pattern, this will require a Command Interface something like this:
interface CommandInterface {
    CommandInterface execute();
If the Actions are lightweight and cheap to build then use a Factory Method. Load the classnames from a properties file which maps actionName=className and use a simple factory method to built the actions for execution.
    public Invoker execute(final String targetActionName) {
        final String className = this.properties.getProperty(targetAction);
        final AbstractCommand targetAction = (AbstractCommand) Class.forName(className).newInstance();
        targetAction.execute();
    return this;
If the Actions are expensive to build then use a pool, such as a HashMap; however in most cases I'd suggest this could be avoided under the Single Responsibility Principle delegating the expensive element to some pre-constructed common resource pool rather than the commands themselves.
    public class CommandMap extends HashMap<String, AbstractAction> { ... }
These can then be executed with
        commandMap.get(targetActionName).execute();
        return this;
This is a very robust and decoupled approach that applies SRP, LSP and ISP of the SOLID principles. New commands do not change the command mapper code. The commands are simple to implement. They can be just added to the project and properties file. The commands should be re-entrant and this makes it very performant.
Martin Spamer
  • 542
You can utilize the enumeration based object to reduce the need for hardCoding the string values. It will save you some time and makes the code much neat to read & extend in the future.
 public static enum actionTypes {
      action1, action2, action3....
  public void doPost {
      switch (actionTypes.valueOf(action)) {
          case action1: do-action1(); break;
          case action2: do-action2(); break;
          case action3: do-action3(); break;
Karan
  • 366
Factory Method pattern is what I looks if you are looking for scalable and less maintainable design.
Factory Method pattern defines a interface for creating an object, but let subclass decide which class to instantiates. Factory Method lets a class defer instantiation to subclass.
 abstract class action {abstract doStuff(action)}
action1,action2........actionN concrete implementation with doStuff Method implementing thing to do.
Just call
    action.doStuff(actionN)
So in future if more action are introduced, you just need to add concrete class.
Anuj Singh
  • typo abstarct --> abstract in the first code line. Please edit. Also, can you add a bit more code to flush this example out to show more directly how this answers the OP's question? – Jay Elston Apr 13 '17 at 01:36
With reference to @J. Pichardo answer i am writing the modifying the above snippet as the following
    A (new ExecutorA()),
    B (new ExecutorB())
    Executor executor;
        this.executor = e;
    //The delegate method
    public void execute() {
public foo Executor {
    foo execute();
public class ExecutorA implements Executor{
      //Do some action
public class ExecutorB implements Executor{
      //Do some action
Tom Taylor
  • 356
