Afaik, typically there're two ways of doing this: a) symbolic link b) syncing script. In both case, you have to create another repo (name it dotfile
below) for bash_profile
to be version controlled.
Use symbolic links
bash_profile
gets moved to your version controlled dir(containing .git
), $HOME/.bash_profile
is a soft link ⇢ $HOME/dotfile/bash_profile
is where your actual bash_profile
resides, see holman dotfile as an example.
Use syncing script
bash_profile
stays in your HOME
dir but it's only a copy of the 'latest' one . The latest bash_profile
still lives in $HOME/dotfile
Yep, it's a copy and paste approach, this is why you need some syncing script
to save you from DRY work. see mathiasbynens dotfiles as an good example. His syncing script
https://github.com/mathiasbynens/dotfiles/blob/master/bootstrap.sh.
Furthermore
As you suspect:
I'm curious if there's a good way to version control a single file in a populated directory
Version controlling a single file doesn't make much sense, copy & paste or just drop it into some cloud drives saves you much hassle.
The real point is that things don't get scaled this way, when the dotfiles
in your $HOME
grows, when you want to version control your favorite text editor's config(say vimrc
), when you use SSH
to work with multiple shell remotely, you might have zshrc
, bashrc
, fishrc
etc.
This means in the long run you might want to version control all your dotfile
s. Github's dotfile is a good starting point.
