A lot of my code seems to be going through the following evolution -
Iteration 1
interface IAccountManager {
void Import(string importData);
class SalesAccountManager : IAccountManager {
private int GetAccountId(string data) {
//Some data conversions, database references, calculations etc
return accountId;
private int GetAccountName(string data) {
return name;
public void Import(string importData) {
SalesAccount a = new SalesAccount();
a.Id = GetAccountId(importData.Substring(11, 55); //hardcoding just to keep this example simple
a.Name = GetAccountName(importData);
a.Save();
It all works well, everyone is happy but then I find I need to add a BusinessAccountManager
. Upon further inspection, it seems that the GetAccountId
and GetAccountName
methods are not going to change. So, what seems like a natural solution? We just make an Abstract base class that inherits from IAccountManager
and make those methods protected and make Import
abstract. Now, we have -
Iteration 2
abstract class AbstractAccountManage : IAccountManager {
protected int GetAccountId(string data) {...No change here...}
protected int GetAccountName(string data) {...No change here...}
public abstract void Import(string importData);
class SalesAccountManager : AbstractAccountManager {
public void Import(string importData) {...No change here...}
class BusinessAccountManager : AbstractAccountManager {
BusinessAccount a = new BusinessAccount();
a.Save();
But it seems this abstract class is basically a helper class, so I could've done the following -
Iteration 3
interface IAccountManagerStrategy {
public int GetAccountId(string data);
public int GetAccountName(string data);
class AccountManagerStrategy : IAccountManagerStrategy {
public int GetAccountId(string data) {...No change here...}
public int GetAccountName(string data) {...No change here...}
private IAccountManagerStrategy accountManagerStrategy {get;}
public SalesAccountManager(IAccountManagerStrategy accountManagerStrategy) {
this.accountManagerStrategy = accountManagerStrategy;
a.Id = accountManagerStrategy.GetAccountId(importData.Substring(11, 55); //hardcoding just to keep this example simple
a.Name = accountManagerStrategy.GetAccountName(importData);
a.Save();
//Similar to above but for a BusinessAccount
Note: The implementation of GetAccountId
and GetAccountName
methods is not very likely to change (but one never knows).
With the above background -
Questions
From a software architecture perspective, is it a good approach to refactor such abstract classes that act as repositories of shared private methods (similar to above) into helper classes (or strategy pattern, if we want to call it that) as seen in Iteration 3? This question is not for this specific case but in general.
If it is a good approach to do that refactoring, then what is the real use of abstract classes and the
protected
keyword as far as software design/architecture is concerned?Would an abstract class like
above be violating SRP after the methods were changed from private to protected (I suppose it can be argued that its no longer doing only one thing, but difficult to say when to stop identifying what a single responsibility should be)?
Note: This question is not about composition vs polymorphism. It is about understand the correct usage of abstract
and understanding why or why not refactor concrete methods of an abstract class into helper/utility classes.
