Working in an architecture roles I was asking the team that was developing a component to add some logging at certain points. For this I was offered and NFR document to fill in.
Does logging fit as a Non functional Requirement or could they go somewhere else. in oneway a NFR document is convienent for a boiler plate requirement but its functional in that actions trigger logs.
whatsisname
  • 27,463
  • 73
  • 93
user1605665
  • 235
    I can see it both ways. While I think it's a functional requirement, in that it actually specifies *functionality*, that functionality does not contribute directly to any user story or use case. – Robert Harvey Jan 30 '17 at 03:30
  • To add to the comment by @RobertHarvey, it can be seen as a non-functional requirement because it is something that needs to be kept in mind for every future story you implement (i.e. it probably ends up in the definition-of-done). – Bart van Ingen Schenau Jan 30 '17 at 17:31
That depends on the scope of your application. If you have some legal liability to provide a thorough logging of calculations, user-interactions with the software etc, you need the logging to fulfill your functional requirements.
On the other hand, if you're talking about logging to provide your developers, sysadmins and/or operations a means of debugging and monitoring, then it may not be an actual requirement. In that case, you will have a somewhat pure non-functional requirement.
mhr
  • 660
