In a multi-threaded environment, we must consider concurrent access to writable resources. A common approach is to use Monitor
or its shorthand form lock
Task
is at a different abstraction level than Thread
. A task may run on a thread of its own (and according to the logs, they do so in our application), but that is not guaranteed. See e.g. What is the difference between task and thread?:
If the value you are waiting for comes from the filesystem or a database or the network, then there is no need for a thread to sit around and wait for the data when it can be servicing other requests. Instead, the Task might register a callback to receive the value(s) when they're ready.
That is, that kind of Task
somehow shares a Thread
with other running code (I must admit that I do not understand how that works in detail, currently it looks to me like a specialization of the "famous" DoEvents
Consequently, Monitor
won't be able to distinguish between them, and - because Monitor
can be re-entrant - allow both of them access the resource. That is, Monitor
"fails."
Examples with Threads
typically use Monitor
nonetheless. So I want to ask how I can be sure that Monitor
is safe with a Task
(or: how can I be sure that a Task
is running on a Thread
of its own).
