12
This question has an excellent answer by Eric Lippert describing what the stack is used for. For year's I've known - generally speaking - what the stack is and how it's used, but parts of his answers make me wonder if this stack structure is less-used today where async programming is the norm.
From his answer:
the stack is part of the reification of continuation in a language without coroutines.
Specifically, the without coroutines portion of this has me wondering.
He explains a bit more here:
Coroutines are functions that can remember where they were, yield control to another coroutine for a while, and then resume where they left off later, but not necessarily immediately after the just-called coroutine yields. Think of "yield return" or "await" in C#, which must remember where they were when the next item is requested or the asynchronous operation completes. Languages with coroutines or similar language features require more advanced data structures than a stack in order to implement continuation.
This is excellent in regards to the stack, but leaves me with an unanswered question about what structure is used when a stack is too simple to handle these language features that require more advanced data structures?
Is the stack going away as technology progresses? What replaces it? Is it a hybrid type of thing? (e.g., does my .NET program use a stack until it hits an async call then switches over to some other structure until completed, at which point the stack is unwound back to a state where it can be sure of the next items, etc?)
That these scenarios are too advanced for a stack makes perfect sense, but what replaces the stack? When I had learned about this years ago, the stack was there because it was lightning fast and lightweight, a piece of memory allocated at application away from the heap because it supported highly efficient management for the task at hand (pun intended?). What's changed?
jleach
  • 2,632
Basically yes.
Suppose we have
async void MyButton_OnClick() { await Foo(); Bar(); }
async Task Foo() { await Task.Delay(123); Blah(); }
Here's an extremely simplified explanation of how the continuations are reified. The real code is considerably more complex, but this gets the idea across.
You click the button. A message is queued up. The message loop processes the message and calls the click handler, putting the return address of the message queue on the stack. That is, the thing that happens after the handler is done is that the message loop has to keep running. So the continuation of the handler is the loop.
The click handler calls Foo(), putting the return address of itself on the stack. That is, the continuation of Foo is the remainder of the click handler.
Foo calls Task.Delay, putting the return address of itself on the stack.
Task.Delay does whatever magic it needs to do to immediately return a Task. The stack is popped and we're back in Foo.
Foo checks the returned task to see if its completed. It is not. The continuation of the await is to call Blah(), so Foo creates a delegate which calls Blah(), and signs that delegate up as the continuation of the task. (I just made a slight mis-statement; did you catch it? If not, we'll reveal it in a moment.)
Foo then creates its own Task object, marks it as incomplete, and returns it up the stack to the click handler.
The click handler examines Foo's task and discovers it is incomplete. The continuation of the await in the handler is to call Bar(), so the click handler creates a delegate which calls Bar() and sets it as the continuation of the task returned by Foo(). It then returns up the stack to the message loop.
The message loop keeps processing messages. Eventually the timer magic created by the delay task does its thing and posts a message to the queue saying that the continuation of the delay task can now be executed. So the message loop calls the task continuation, putting itself on the stack as usual. That delegate calls Blah(). Blah() does what it does and returns up the stack.
Now what happens? Here's the tricky bit. The continuation of the delay task does not only call Blah(). It has to also trigger a call to Bar(), but that task doesn't know about Bar!
Foo actually created a delegate that (1) calls Blah(), and (2) calls the continuation of the task that Foo created and handed back to the event handler. That's how we call a delegate that calls Bar().
And now we've done everything that we needed to do, in the correct order. But we never stopped processing messages in the message loop for very long, so the application remained responsive.
A graph of task objects containing references to each other via the closure classes of delegates. Those closure classes are state machines which keep track of the position of the most recently executed await and the values of the locals. Plus, in the example given, a global-state queue of actions implemented by the operating system and the message loop which executes those actions.
Exercise: how do you suppose this all works in a world without message loops? For example, console applications. await in a console app is quite different; can you deduce how it works from what you know so far?
Stacks are a useful data structure when the lifetimes of method activations form a stack, but in my example the activations of the click handler, Foo, Bar and Blah do not form a stack. And therefore the data structure which represents that workflow cannot be a stack; rather it is a graph of heap-allocated tasks and delegates that represents a workflow. The awaits are the points in the workflow where progress cannot be made further in the workflow until work started earlier has completed; while we're waiting, we can execute other work that does not depend on those particular started tasks having completed.
The stack is just an array of frames, where frames contain (1) pointers to the middle of functions (where the call happened) and (2) values of local variables and temps. Continuations of tasks are the same thing: the delegate is a pointer to the function and it has a state which references a specific point in the middle of the function (where the await happened), and the closure has fields for each local variable or temporary. The frames just don't form a nice neat array anymore, but all the information is the same.
Eric Lippert
  • 45,799
  • 87
  • 126
    Very helpful, thanks. If I could mark both answers as an accepted one I would, but because I can't I'll leave them blank (but, didn't want anyone to think the time to reply wasn't appreciated) – jleach Jan 13 '17 at 11:45
    @jdl134679: I would suggest that you mark something as the answer if you feel your question has been answered; that sends a signal that people should come here if they want to *read* a good answer rather than *write* one. (Of course writing good answers is always encouraged.) I don't care who gets the checkmark. – Eric Lippert Jan 13 '17 at 11:53
Appel wrote an old paper garbage collection can be faster than stack allocation. Read also his Compiling with continuations book and the garbage collection handbook. Some GC techniques are (unintuitively) very efficient. The continuation passing style defines a canonical whole-program transformation (the CPS transformation) to get rid of stacks (conceptually replacing call frames with heap-allocated closures, in other words "reifying" individual call frames as individual "values" or "objects").
But call stack is still very widely used, and current processors have dedicated hardware (stack register, cache machinery, ....) dedicated to call stacks (and that is so because most low-level programming languages, notably C, are easier to implement with a call stack). Notice also that stacks are cache friendly (and that matters a lot for performance).
Practically speaking, call stacks are still here. But we now have many of them, and sometimes the call stack is split in many smaller segments (e.g. of a few pages of 4Kbytes each), that are sometimes garbage collected, or heap allocated. These stack segments could be organized in some linked list (or some more complex data structure, when so needed). For example, the GCC compilers have an -fsplit-stack option (notably useful for Go, and its "goroutines" and its "async processes"). With split stacks you can have many thousands of stacks (and co-routines become easier to implement) made of million of small stack segments, and "unwinding" the stack may be faster (or at least nearly as fast as with a single-chunk stack).
(in other words, the distinction between stack & heap is blurring, but might require whole-program transformation, or changing incompatibly the calling convention and the compiler)
See also this & that and many papers (e.g. this) discussing CPS transformation. Read also about ASLR & call/cc. Read (& STFW) more about continuations.
The .CLR & .NET implementations might not have state-of-the art GC & CPS transformation, for many pragmatical reasons. It is a trade-off related to whole program transforms (and ease of using low-level C routines & have a runtime coded in C or C++).
Chicken Scheme is using the machine (or C) stack in an unconventional way with CPS transformation: every allocation happens on the stack, and when it becomes too large a generational GC copying & forwarding step happens to move recent stack allocated values (and probably the current continuation) to the heap, and then the stack is drastically reduced with a large setjmp.
Read also SICP, Programming Language Pragmatics, the Dragon Book, Lisp In Small Pieces.
Basile Starynkevitch
  • 32,434
  • 84
  • 125
