I have an ASP.NET Web API application. It uses enums for some fixed sets of states or types. Now I need to extend enum to support more values. But it will break backwards compatibility so I need to create new version of method. Is it better to use strings for this purpose? I suppose I can easily extend a list of possible string values and this changes don't require new version of api method. What do you think?
UPDATE: I have enum
public enum ElementTypes
    Tree,
    Test,
    Post
and I need to add two new items into this enum.
mtkachenko
  • 267
    Possible duplicate of [Semantic Versioning in OpenAPI with string "enum": new values OK?](https://softwareengineering.stackexchange.com/questions/345773/semantic-versioning-in-openapi-with-string-enum-new-values-ok) – Jan Paolo Go Jun 01 '18 at 22:04
Its best to use enums serialised as strings and use versioning to deal with backwards compatibility issues.
This gives you the type safety of enums in your c# code, but retains the meaningful values in your json and consuming apps.
Maybe add more info about your particular backwards compatibility issue? Adding more values to an enum should not necessarily cause a problem. But obviously using strings as input does not solve all possible backwards compatibility issues, so you need versioning in any case
Ewan
  • 70,664
  • 76
  • 161
  • I added example. So I see it requires new version anyway. I mean if I use list of constant strings in api and I need to return new string constant - new version is required here anyway, right? – mtkachenko Dec 14 '16 at 11:17
    it (always) requires a new version. but its not clear why it would not be backward compatible with the previous version – Ewan Dec 14 '16 at 11:18
  • Yeah, I see my explanation is a bit unclear. I mean situation when I just add new string to existing list of constants without new version. So consumer didn't expect to recieve this value in response. I need to create a new version. – mtkachenko Dec 14 '16 at 11:26
