Lua uses positional parameter passing. So there isn't a 'natural' way to pass named arguments. You can simulate them by turning this:
--invalid code
rename(old="temp.lua", new="temp1.lua")
into this:
rename{old="temp.lua", new="temp1.lua"}
using this:
function rename (arg)
return os.rename(arg.old, arg.new)
end
More generally this is known as the introduce parameter object refactoring. You're doing the same thing in your question but just being more formal about it by insisting on the parenthesis.
Depending on arity (the number of arguments) and readability these simulated named arguments can become very helpful indeed. If the arity is small and the meaning of the values are obvious without looking at the function definition then the compact form is fine. Personally I had no idea what {10, 10}, 3, right
were going to be until I looked at the table. Though I must say, a name like Foo
doesn't help. Readability is far more important than saving lines of code.
@whatsisname is correct about some separating required and optional arguments but this is not required nor universal. For example:
function Window (options)
-- check mandatory options
if type(options.title) ~= "string" then
error("no title")
elseif type(options.width) ~= "number" then
error("no width")
elseif type(options.height) ~= "number" then
error("no height")
end
-- everything else is optional
_Window(options.title,
options.x or 0, -- default value
options.y or 0, -- default value
options.width, options.height,
options.background or "white", -- default
options.border -- default is false (nil)
end
See lua.org
One thing to be careful of: make every used member of the table something easy to spot. Don't bury one off somewhere weird where it's easy to miss. Another reason short functions are good.
