I was wondering how you handle issues like that in your company.
Usually when something goes wrong at a customer he needs to:
  1. Submit the issue he encountered
  2. Add logs / configuration data
  3. Suddenly the logs are not in high debug level - so he needs to increase debug level and reproduce the problem
  4. Then again, you can't find the issue, and you give him a debug version and ask him to reproduce again
  5. etc...
Collection needs to be from several machines most of the times.
This of course leaves a lot of frustration in both sides. I was wondering how do you handle stuff like that? (better bug reporting systems? recommended actions in bugs / etc?)
to add an example:
The application can be an enterprise one which is composed of several products in several machines (Let's say - Application tier, Database tier and some kind of MQ tier - 3 machines).
Now, when there's a bug, logs need to be collected from those 3 machines and then the investigation starts.
ArielB
  • 181
  • related (possibly a duplicate): [Getting users to write decent and useful bug reports](http://softwareengineering.stackexchange.com/questions/132248/getting-users-to-write-decent-and-useful-bug-reports) – gnat Dec 08 '16 at 14:55
    Are you posting from a cell phone? Most modern cell phones have an option to automatically add capitalization where appropriate. If you're using a computer, get your shift key fixed. – Robert Harvey Dec 08 '16 at 19:53
  • @RobertHarvey Delightful comment + very relevant to my thread. Thanks for the link gnat, i'll check it out. – ArielB Dec 11 '16 at 09:30
One solution is to add an Analytics package to your product.
This will report back all the bugs and usage to you so that you can see how people are using your service and what bugs they are experiencing.
With a B2B style product you obviously have to be careful around what information you send back. You might want to take the "submit a bug report" option, where you prompt the user for permission before sending the logs back.
Heading off into general advice here. I know the kind of systems you mean but I'm not sure there is a proven method of dealing with those kind of 'why is this thing in state x' errors. Especially when the system is deployed to a customer's site!
  • Collate all the logs together with (eg) logstash or splunk.
  • Log performance metrics, statsd or similar
  • Add audit trails to objects that get passed around i.e., order accepted, sent to warehouse, item missing from pick list, emailed customer..
  • Keep the audit trail with the object.
  • Keep logs clean. I.e., if you are logging errors that aren't 'real' fix the error asap. If you see an error it should mean something is wrong.
  • Go wild with debug logging all over the place and leave it switched on.
Ewan
  • 70,664
  • 76
  • 161
  • Well, The issue is not usually collecting the logs, but to "get enough information" to understand what caused the problem, also recommended way of correlating errors in different components (when you have one flow) – ArielB Dec 11 '16 at 09:29
  • maybe add an example to your question? what kind of system are we talking about? – Ewan Dec 11 '16 at 09:39
  • Allright, Comment updated. it's still general - for multi tier apps – ArielB Dec 11 '16 at 10:07
  • is it tracking the history of messages to see what went wrong in the overall flow which is the main problem? – Ewan Dec 11 '16 at 10:16
  • Yep - it's a pain. sometimes the logs aren't in high debug level (which raises another question - should it be? even though it might hurt performance?), automation of that can be possible (trying to search for a specific flow in all of the logs) - but i'm not sure it's possible to cover even most of the cases – ArielB Dec 11 '16 at 10:19
