I was reading Why are websites (even this one) sometimes "Down for Maintenance"? , and it dawned on me that my industry accepts planned downtime asa given despite the disruption to staff and the (mostly hidden) cost to the business.
What strategies can I use to achieve zero (planned) downtime in a database-backed web app? Specifically upgrades that require db schema changes.
PS I thought about a using a 'database abstraction layer' (does that exist?), or use a two stage upgrade process where the first stage upgrades the schema and starts using it in parallel to the old schema and the second stage retires the old schema from use? (Does anyone do that? Is that crazy?)
PPS I'm assuming I need to have a couple web application servers hitting the same database.
PPPS an example schema change would be changing the users table - going from a single name text field to a combination of forename and surname columns. (This is the simplest example)
