I'm on a software development programme in financial services - with 100 developers, plus testers, BAs, PMs and other support staff.
We've read through Implementing Lean Software Development, and The Phoenix project, which both talk about identifying the bottleneck in your flow, and optimising it away. (Some similarities to critical path in a project).
Intuitively, we can identify the bottlenecks as, number of testing environments, amount of time and effort required for regression testing, size of the monolith, number of developers and so on. What we're trying to do is boil it down to the one bottleneck that holds everything else up. (Like a manufacturing process flow).
Applying Lean Software Development talks about value stream analysis - but doesn't quite go far enough to identify the one blocker that is critical to the whole system.
My question is: What is the method to identify the key bottleneck in a software engineering programme?
EDIT: Additional Assumptions:
In my environment - funding is allocated for large chunks of scope to be delivered at a specific date. In essence, the quality, scope and time is locked in up front. (With some variances for scope and time if absolutely required).
This means there lacks a concept of 'small pieces moving through the system'. There are only large projects with lots of stories (60+ stories - each with 10 days of work in them).
This is a somewhat waterfall-like environment (as much as Sarbanes Oxley dictates) with a separate System Integration Test and User Acceptance Test phase.
