In our company several teams will work on different components of several projects at the same time. For example, one team might make make specific kinds of software (or hardware) for some project(s), another team another specific kind of software. We use Jira projects to host issues for specific projects and Jira boards for sprints for different teams.
We face the issue of avoiding code duplication across projects, and have developed a set of core libraries which we use in those projects. While working on a project, some developer will realize that a piece of code they have written is of greater interest and should be extracted into a core library, or that some core code they are using has a bug, needs some more parametrization, or a new feature... you name it.
So they create a core library issue that goes into the core project's backlog. All these issues are reviewed, prioritized, and estimated in a core library meeting (once a week), and will be tackled according to their priority (alongside project-specific issues) in some future sprints.
Prioritization is done by sorting issues, and we put a sorted
label on sorted issues (so we can search for non-sorted ones). Then we manually put one issue per core component to the top of the backlog in order for them to be tackled first. When some team puts such an issue into their sprint, they have to manually drag another item to the top of the backlog instead.
This is quite error-prone. Basically, what we have is the additional issue statuses "sorted" and "estimated" between "open" and "in progress". Reflecting this through the sorted
label and their position in the board is rather cumbersome and error-prone. (For example, if someone moves an issue in some sprint up and down, this will be reflected in the core board, silently scrambling the order of issues the team might have had decided about in an extensive discussion weeks earlier.)
So what would be a better way to implement this?
