It seems to be fairly common opinion that you should only test public methods for a class or module and not private methods. If private methods are doing their job correctly, then that should be reflected in public methods.
That being said, when testing a public method that makes internal calls to private methods, should you test for things that could happen in that private method? Essentially, indirectly testing the private method?
Simplified example:
// Basic JavaScript module
let MyModule = function() {};
MyModule.prototype.taco = function() {
burrito();
// Private function burrito
let burrito = function(){
if (somethingHappened) {
throw new Error('Oops!');
In this case, the private method burrito
is called from within the public taco
method. In some situations, burrito
can throw an error.
Should I write a test for taco
where I am testing to see if an error ever gets thrown under certain situations? I'm not technically testing to see if the taco
method itself throws an error, but rather if the underlying private method throws an error.
It's something I think is important to test, but since it's maybe bad practice to test private methods directly, is this the right way to test it? Or should I not test it at all? I just want to make sure that certain errors are thrown in a predictable manner.
For example, if burrito
method makes an http request to some API server somewhere, but the server is offline at the time, it throws an error. It would be nice to write a test for this to ensure that when the server endpoint is offline, that the correct error is thrown.
