The business team in my company has come up with a new field to add to one of our entities. For new instances of this entity, it'll be calculated dynamically, but for previously existing instances, we need to set up a default value of, at the moment, 15. I can easily set that as the default value in the db, but to me, it is part of the business logic. Not only can it change in the future, but it is also separated from the rest of the business logic, all of which is so far in the application level. It'll be even somehow hidden to developers.
I can, not so elegantly, write some code at application level that will set that value when new instances are reloaded. But this is uglier.
My question is then, is it ok to put this "business logic" in the database?
EDIT: I'm not asking about pros/cons of different architectures with the business logic in the DB/app, but as stated in the title edit, about this concrete case of a default value.
