In bare metal or minimal RTOS type embedded systems with multiple processors is it possible to have an identical program running on each processor that uses Message Passing Interface (MPI) to provide load balancing and also redundancy in the case of processor failure? Such as a state machine that changes what actions other CPUs perform based on passed messages, for example asking another processor to take over some part of the system loop for load balancing or sending periodic alive messages and remembering what each CPU is responsible for as far as CPU redundancy.
In this example diagram the actual parts of the full system loop that are "open" could be any distinct systems. There could be no cooperation just the ability to open and or close parts of the full system loop running on each CPU in a kind of very primitive asymmetric multiprocessing. "Process migration" to another CPU would be triggered by a request for another CPU to open that part of the system loop after which the requesting CPU closes its portion, or a lack of response from another CPU when queried if alive for some amount of time.
It has been proposed as a solution to potential processor failure and solution to load balancing since we can not port an embedded OS to truly do symmetric or asymmetric multiprocessing on the custom board, and it sounds like it is theoretically possible, but an incredibly poor design idea. Also, I have not been able to find any design patterns or algorithms for using message passing in this way.
Some background important to the software engineering decisions: A student CubeSat project (not graded or for a class), we have a small software development team with mostly junior students with little to no knowledge of operating systems design. For various reasons we can not do any of the many real world solutions I have read about. This while it sounds like it is possible sounds like it will introduce too much complexity for the team to deal with, and even if it can be done will cause a terrible design that will lead to some problem that turns the CubeSat into an orbiting rock.
I am not even sure we would be able to implement message passing in a way reliable enough for spacefairing, I have not even been able to find any production ready communication protocols that can be used to pass messages on a bus with a tiny OS or bare metal like we need. But I am also curious to know if this proposed solution for process migration, CPU redundancy, and load balancing is even viable for a safety critical system. It seems like it could lead to a state where two CPUs are running the same "Process" or part of the program loop if one wakes that would be hard to detect.
