Context
Our group builds and is responsible for maintaining multiple apps for a larger institution. We are in the process of breaking up our monoliths into reusable microservices (hooray!). When we got up to notifications (primarily email notifications) we got stuck. Our users consume multiple applications, and each service may have dozens of trigger points which would fire off a notification to other users. Do we adopt the philosophy that every microservice should handle their own notifications or should all notifications belong to a service unto themselves and rely on database triggers?
I am looking for articles or perhaps some experience advice since this is something we really, really can't afford to get wrong.
The argument for notifications in service
Microservices should be self contained. Each is responsible for its own state, its own model and should should [as much as possible] not be dependent on another service to function. Notifications are an essential feature for many services. What good is a chat service if you have to open it up every time to check for new chats? On actions, the microservice should fire off notifications - whether directly or by enqueuing it with some mail delivery service. This also helps with mitigation and further development. While iterating on the service, the developer is always aware of what notifications may be sent out depending on changes to the application state.
The case for database triggers
Considering the volume of notifications being sent out, it is best to have them centralized. Any updates, additions or deletions of notifications should occur in a single place. Furthermore, having notifications sent from the controller (or actions in flux) is risky, since it is possible that after the action is taken place, the DML operation fails. This would result in a user receiving a notification which is out of sync with the source of truth - the database. By having the notification service solely rely on triggers in the database, it also keeps to service encapsulation. The notification service does not care which service updated which model, only that the model did indeed update. Another risk is multiple applications operating on the same table (while this may seem like poor architecture, you may have an admin app and a user app). If there are multiple services updating a table, you may have multiple notifications going off to users with conflicting entries. By centralizing it, you are able to ensure that only a single notification goes off (perhaps by throttling how many notifications go off in a single interval, thus only notifying the last of the changes).
Question
We are responsible for quite a few microservices that each have dozens of notifications. Our team is growing quite quickly, and my fear is that we're going to have notifications all over the place. Developers may accidentally make a switch in code, not realizing that this is going to trigger a ton of notifications to some poor user. What is important to me is consistency through out the org.
I'm hoping for some advice on the tradeoffs between the two architectures described above - notifications from application logic or from database triggers.
Thank you so, so much for your help and consideration!
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
ZAR
  • 221
Third option: Make notifications its own microservice. Each microservice can utilize its own internal rules for communicating to the notification microservice. The notification microservice can focus on executing its own internal set of rules for pushing notifications given any of the various validation rules that need to be checked before pushing.
Price Jones
  • 635
  • Right, and thank you for responding - the question now is how does this microservice know when to fire? Should another service post to the notification service, or should a trigger from the DB send the change to the notification service? – ZAR Oct 26 '16 at 14:09
    My point is that if notifications is its own microservice, then the events that trigger it can originate from multiple sources depending on what is best for the given situation - whether a microservice or a db or any other potential source. If any additional work is needed surrounding sending a particular notification, the microservice can encapsulate it.... So the question is not whether you should adopt a particular philosophy across the suite of projects, but which one is best suited to the needs of each. – Price Jones Oct 26 '16 at 14:19
  • good point. The fear I have here is that it is possible to have a service that has both application and db sources contacting this notification service. For instance, let us take a chat app that notifies on new message. We can contact our notification service when the user hits "send" or when the message is inserted to the DB. When you have dozens of microservices and a bunch of developers, you have to be prepared for someone overlooking the DB trigger and putting it in the app logic (and vice versa). So it would be great to have a general rule. – ZAR Oct 26 '16 at 14:24
  • but a centralized notification service is definitely the way to go. I agree with you. But we still need to figure out the even origin that posts to the notification service. Having a mix of application logic and DB triggers leaves it possible to have duplicates. – ZAR Oct 26 '16 at 14:25
Well, your microservice is basically part of a Service Layer, correct? Your clients will subscribe to event endpoints on that Service Layer; that will not change. So the only real question is "from where will your events originate?"
Database triggers are the wrong tool for this. Database triggers have a different purpose; if you want to eliminate your monolithic architecture, putting your event originations there will have the opposite effect.
Centralize your events in a single microservice instead, or simply let each microservice handle its own notifications.
This isn't about a "single source of truth." Every microservice gets its data from the database in the state that it's in at the moment that it is retrieved. Events are not special in that regard.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
  • Thank you for responding. Similar to my comment to @PriceJones, I agree that notifications should be a microservice for sending. The question is exactly what you identified - where does the event originate. Should a service's logic contact the notification service or should it originate from a DB trigger (which I see you are arguing against). I agree that notifications should be a microservice, but what calls that service? I would like to understand your point about DB triggers *having the opposite effect*. That would be really helpful! – ZAR Oct 26 '16 at 14:12
    Database triggers are siloed in your RDBMS. Putting them there *centralizes* them,and requires people with specialized skills to maintain them, so it's promoting your *monolithic* architecture rather than promoting a decentralized one. – Robert Harvey Oct 26 '16 at 14:49
