194
After some serious quality problems in the last year, my company has recently introduced code reviews. The code review process was quickly introduced, without guidelines or any kind of checklist.
Another developer and I where chosen to review all changes made to the systems, before they are merged into the trunk.
We were also chosen as "Technical Lead". This means we are responsible for code quality, but we don't have any authority to implement changes in the process, reassign developers, or hold back projects.
Technically we can deny the merge, giving it back to development. In reality this ends almost always with our boss demanding that it be shipped on time.
Our manager is an MBA who is mostly concerned with creating a schedule of upcoming projects. While he is trying, he has almost no idea what our software does from a business point of view, and is struggling to understand even the most basic customer demands without explanation from a developer.
Currently development is done in development branches in SVN, after the developer thinks he is ready, he reassigns the ticket in our ticketing system to our manager. The manager then assigns it to us.
The code reviews have lead to some tensions within our team. Especially some of the older members question the changes (I.e. "We always did it like this" or "Why should the method have a sensible name, I know what it does?").
After the first few weeks my colleague started to let things slide, to not cause trouble with the co-workers (she told me herself, that after a bug report was filed by a customer, that she knew of the bug, but feared that the developer would be mad at her for pointing it out).
I, on the other hand, am now known for being an ass for pointing out problems with the committed code.
I don't think that my standards are too high.
My checklist at the moment is:
  • The code will compile.
  • There is at least one way the code will work.
  • The code will work with most normal cases.
  • The code will work with most edge cases.
  • The code will throw reasonable exception if inserted data is not valid.
But I fully accept the responsibility of the way I give feedback. I'm already giving actionable points explaining why something should be changed, sometimes even just asking why something was implemented in a specific way. When I think it is bad, I point out that I would have developed it in another way.
What I'm lacking is the ability to find something to point out as "good". I read that one should try to sandwich bad news in good news.
But I'm having a hard time to find something that is good. "Hey this time you actually committed everything you did" is more condescending than nice or helpful.
Example Code Review
Hey Joe,
I have some questions about your changes in the Library\ACME\ExtractOrderMail Class.
I didn't understand why you marked "TempFilesToDelete" as static? At the moment a second call to "GetMails" would throw an exception, because you add Files to it but never remove them, after you deleted them. I know that the the function is just called once per run, but in the future this might change. Could you just make it an instance variable, then we could have multiple objects in parallel.
... (Some other points that don't work)
Minor points:
  • Why does "GetErrorMailBody" take an Exception as Parameter? Did I miss something? You are not throwing the exception, you just pass it along and call "ToString". Why is that?
  • SaveAndSend Isn't a good name for the Method. This Method sends error mails if the processing of a mail went wrong. Could you rename it to "SendErrorMail" or something similar?
  • Please don't just comment old code, delete it outright. We still have it in subversion.
Aaron Hall
  • 5,895
  • 47
RobMMurdock
  • 1,651
    I tried to answer most questons with my current chages. Thanks for all the comments, notes and answers – RobMMurdock Oct 18 '16 at 17:31
    @Brandin: I think that I'm the problem, or at least a part of it. But I keep a neutral tone, give "actionables" and am trying to explain why I think changes need to be made, to the current code. So I'm trying to figure out how to give better feedback. That's the whole point. I'm not here to complain about my coworkers, I'm trying to find a way to use the few hours of code reviews we get, to make things better for the company. – RobMMurdock Oct 18 '16 at 17:48
    Please don't serve up a $h!t sandwich to achieve some mythical balance of bad and good. If they have done something good tell them so, if they have done something that needs correction then let them know. Mixing good and bad dilutes the message. If they get much more negative feedback than positive, maybe they'll realize they need to change. Your sandwich approach gives a 2:1 ratio for every negative, so they end up net positive, is that the message you want to send. – cdkMoose Oct 18 '16 at 17:54
    Stop the use of 2nd person. Code is the subject, not the coder. For example, write: *SaveAndSend should be renamed to better fit its behavior, like for example SendErrorMail*. Right now, it really look likes you are giving orders to your colleague, even with all the "could you please" you spilled all over. I wouldn't accept that from a reviewer. I far prefer someone that outright states "This must be done", rather than asking me (even politely) to do something. – Diane M Oct 18 '16 at 20:35
  • Ok, nobody pointed that before, ill make an answer for this. – Diane M Oct 18 '16 at 20:46
    It has been mentioned quite often but let me repeat: Talk about the code, not the author. This reduces the risk of the author feeling insulted by your remarks. Just have a look at how often discussions on SO derail because "you did not code that correctly" was not going down well with the OP. Furthermore, you might want to drop by in [CR](https://codereview.stackexchange.com/)'s [main chatroom](https://chat.stackexchange.com/rooms/8595/the-2nd-monitor) to get some tips from the serial reviewers over there (although their situation differs wildly from yours). – Nobody moving away from SE Oct 19 '16 at 12:11
    "I read that one should try to sandwich bad news in good news" You need to make sure there's a clear, global understanding that this is *not* what code reviews are. They're not like employee performance reviews or reviews of a movie, which weigh up good and bad. They're more like a part of the QA process. You wouldn't expect your testers to create tickets saying "This feature is great, and works just as I expect it to!", and you shouldn't expect it in code reviews either. – Ben Aaronson Oct 19 '16 at 13:19
  • Tangentially related: if you don't treat people like adults, they won't act like adults. In the real world, not everyone gets a trophy. – corsiKa Oct 19 '16 at 15:05
    "Why should the method have a sensible name, I know what it does?" Saying something like that as a senior developer is like telling you "I am totally incompetent at my job". "that she knew of the bug, but feared that the developer would be mad at her for pointing it out" If management really want the code quality to improve, then they must give the technical project leads the necessary authority and assign these roles to people with some leadership skills. – Kaiserludi Oct 19 '16 at 18:16
    I think your first step should be in creating a basic set of code standards/guidelines, allow other members to provide feedback, and basically get "buy-in"/agreement from everyone that the guidelines are "within reason". Then, they're all aware they agreed to be held to them. That worked well at a prev. company I worked at. – code_dredd Oct 20 '16 at 04:53
    Don't use this phrase " but in the future this might change." Code only for what is needed now. Don't create complexity for future change that may or may not happen. If you definitely know it will change that's different, but not for the off chance that it might change. – House of Dexter Oct 20 '16 at 21:10
  • Doing code reviews by email is difficult. You will likely find it much easier with a code review tool such as Phabricator: https://www.phacility.com/ – David Phillips Oct 21 '16 at 15:14
  • Having "2 developers chosen to do reviews" is a recipe for disaster. It's made the environment antagonistic from the start. It's no surprise you're having difficulties (esp. with "more experienced" developers). Yes code reviews help catch bugs, but actually that's **NOT** the primary objective. They're more important for _sharing knowledge_. Get the **whole team** doing reviews to **share knowledge** and things should improve. As an aside, I don't think you should "look for positive things in a code review". Sure, praise that which stands out as impressive; but don't be superficial. – Disillusioned Oct 25 '16 at 14:13
  • As an aside. I strongly suspect the chunks of code you're reviewing are far too big. Smaller reviews usually mean less rework for the developer. Less external pressure to just get it in. Less chance the review will have so many comments that the developer feels bombarded. – Disillusioned Oct 25 '16 at 14:20
    I've found that adding measures of control to developers who have never been held accountable is usually met with resistance. Like you, I've found that goes hand in hand with poor quality. – Brandon Oct 25 '16 at 16:56
  • As @CraigYoung says it seems that too much code is being reviewed in one go, and that could be because of how code review has been tied in to the ticketing system. Maybe developers should be asking for review earlier, at a stage when they have completed only part of the code change necessary for the ticket. If there's a reason to change it it's normally easier to change before lots of work has been done on top. – bdsl Feb 27 '17 at 00:59
20 Answers20
128
How to find positive things in a code review?
Great, you have a real opportunity to create value for your firm.
After the first few weeks my colleague started to let things slide, to not cause trouble with the co-workers (she told me herself, that after a bugreport was filed by a customer, that she knew of the bug, but feared that the developer would be mad at her for pointing it out).
Your coworker should not be doing code review if she can't handle telling developers what's wrong with their code. It's your job to find problems and get them fixed before they affect customers.
Likewise, a developer who intimidates coworkers is asking to be fired. I've felt intimidated after a code-review - I told my boss, and it was handled. Also, I like my job, so I kept up the feedback, positive and negative. As a reviewer, that's on me, not anyone else.
Well, that's unfortunate, you say you're being tactful. You can find more to praise, if you have more to look for.
Critique the code, not the author
You give an example:
Avoid using the words "you" and "your", say, "the" changes instead.
Did I miss something? [...] Why is that?
Don't add rhetorical flourishes to your critiques. Don't make jokes, either. There's a rule I've heard, "If it makes you feel good to say, don't say it, it's no good."
Maybe you're buffing your own ego at someone else's expense. Keep it to just the facts.
Raise the bar by giving positive feedback
It raises the bar to praise your fellow developers when they meet higher standards. So that means the question,
is a good one, and worth addressing.
You can point out where the code meets ideals of higher level coding practices.
Look for them to follow best practices, and to keep raising the bar. After the easier ideals become expected of everyone, you'll want to stop praising these and look for even better coding practices for praise.
Language specific best practices
If the language supports documentation in code, namespaces, object-oriented or functional programming features, you can call those out and congratulate the author on using them where appropriate. These matters usually fall under style-guides:
  • Does it meet in-house language style guide standards?
  • Does it meet the most authoritative style guide for the language (which is probably more strict than in-house - and thus still compliant with the in-house style)?
Generic best practices
You could find points to praise on generic coding principles, under various paradigms. For example, do they have good unittests? Do the unittests cover most of the code?
Look for:
  • unit tests that test only the subject functionality - mocking expensive functionality that is not intended to be tested.
  • high levels of code coverage, with complete testing of APIs and semantically public functionality.
  • acceptance tests and smoke tests that test end-to-end functionality, including functionality that is mocked for unit tests.
  • good naming, canonical data points so code is DRY (Don't Repeat Yourself), no magic strings or numbers.
  • variable naming so well done that comments are largely redundant.
  • cleanups, objective improvements (without tradeoffs), and appropriate refactorings that reduce lines of code and technical debt without making the code completely foreign to the original writers.
Functional Programming
If the language is functional, or supports the functional paradigm, look for these ideals:
  • avoiding globals and global state
  • using closures and partial functions
  • small functions with readable, correct, and descriptive names
  • single exit points, minimizing number of arguments
Object Oriented Programming (OOP)
If the language supports OOP, you can praise the appropriate usage of these features:
  • encapsulation - provides a cleanly defined and small public interface, and hides the details.
  • inheritance - code reused appropriately, perhaps through mixins.
  • polymorphism - interfaces are defined, perhaps abstract base classes, functions written to support parametric polymorphism.
under OOP, there are also SOLID principles (maybe some redundancy to OOP features):
  • single responsibility - each object has one stakeholder/owner
  • open/closed - not modifying the interface of established objects
  • Liskov substitution - subclasses can be substituted for instances of parents
  • interface segregation - interfaces provided by composition, perhaps mixins
  • dependency inversion - interfaces defined - polymorphism...
Unix programming principles:
Unix principles are modularity, clarity, composition, separation, simplicity, parsimony, transparency, robustness, representation, least surprise, silence, repair, economy, generation, optimization, diversity, and extensibility.
In general, these principles can be applied under many paradigms.
Your criteria
These are far too trivial - I would feel condescended to if praised for this:
On the other hand, these are fairly high praise, considering what you seem to be dealing with, and I wouldn't hesitate to praise developers for doing this:
Writing down rules for passing code review?
That's a great idea in theory, however, while I wouldn't usually reject code for bad naming, I've seen naming so bad that I would reject the code with instructions to fix it. You need to be able to reject the code for any reason.
The only rule I can think of for rejecting code is there's nothing so egregious that I would keep it out of production. A really bad name is something that I would be willing to keep out of production - but you can't make that a rule.
Conclusion
You can praise best practices being followed under multiple paradigms, and probably under all of them, if the language supports them.
Aaron Hall
  • 5,895
  • 47
    I would even argue that many of these can be headings on a code review feedback template. This allows opportunities for comments such as "great work" under multiple headings, without any real additional cost. It also gives colleagues a good idea of *how* to make their code better. – Stephen Oct 17 '16 at 23:18
    While listing many good practices, you are probably answering the wrong question - because it really is a xy-problem. And it's hard to find a review system that would allow those feedbacks. The important things are hidden in useless noise. Sometimes, the answer to a question is just "Don't do it - it's the wrong way. Your problem lies elsewhere and should be solved adequately." If people start to focus on finding good things, code review has become a waste of time. You can tell your coworker during lunch how nice his implementation is, and he might appreciate it. – Eiko Oct 18 '16 at 08:11
    @Aaron: Agree with you in the approach. A lot of the answers here say "don't sugar coat it", but I understand it is not about pleasing everyone. People are more likely to follow good approach when the good things they do are reinforced, not when they are told they are wrong. They key here is to be tactful but consistent about what to do. From the OP's description, he is in a less-than-perfect coding team, with even old members who are used to their way. They would be more receptive to gentle approach. – Hoàng Long Oct 21 '16 at 01:43
  • @HoàngLong Not every 'old timer' will necessarily be 'more receptive'. There's always someone unreasonable somewhere. For example, I used to work with a guy who insisted in 'porting' his Perl best practices over to Python and Subversion's to Git, and have some kind of complaint every time it was called out, regardless of how it was, even if the reasoning was explained. Since at the time the responsibility for that fell on my lap (I was the only one experienced with both Python and Git), I think some people may simply feel threatened(?) and react accordingly... – code_dredd Feb 11 '17 at 19:16
106
Don't bother picking something good unless its a solid concise example and is directly related to the focused issue.
I won't sugar coat it - from the sounds of it you are dealing with at least one person who is insecure with their abilities and is handling being challenged about their work in an immature way. They are also likely bad at their job - a good developer should always be willing to self reflect, take constructive criticism, and be open to changing their ways.
Now that that's out in the air lets talk about you. Regardless of if you think you are being reasonable you need to be extra careful with people like this to get the ball rolling. I've found the best way to deal with these people is to be very careful with how you word things.
Make sure that you are blaming the code and not the author. Focus on the one issue at hand rather than the poo-mountain that is your code base, which they may have had a significant hand in creating and would be seen as a further personal attack. Choose your battles initially, focus on critical issues that manifest themselves to your users so that you aren't launching a volley of criticisms at the person leading them to dismiss everything you are saying.
Body language and tone are important if you are talking to them in person, be clear with what you are saying and make sure you aren't talking down to them or dismissing their technical abilities. They'll most likely be on the defensive right off the bat so you need to settle their worries instead of confirming them. You need to be conscious about this conversation without being too obvious so that they subconsciously think you are on their side, and hopefully they accept that they need to make the changes that were brought to attention.
If this doesn't work you can start getting a bit more aggressive. If the product is runnable from a conference room, bring it up on the projector during the code review and show the bug first hand, its better if a manager is right there so the person can't back down. This isn't to shame them but to force them to accept that the problem is real for the user and that it needs to be fixed, instead of just a gripe you have with their code.
Eventually if you aren't getting anywhere, are tired of treating the person like a kindergarten student, and management is completely unaware of the problem, and it either reflects poorly on your performance as a code reviewer or you care about the well being of your company and/or product, you need to start talking to your boss about their behavior. Be as specific and impersonal as possible - make a business case that productivity and quality are suffering.
plast1k
  • 1,549
    Another strategy that I've found useful as a reviewer and as someone being reviewed is to attribute the need to cover edge cases, because of a third party. My apologies to those in management positions, but saying things like "we need to account for this edge case because management has really been riding our tails, so we want to make sure this is near bullet proof. Gives them a sense of ease." Also sounds like management wouldn't mind be the "bad guy" in the OP's case anyway. – Greg Burghardt Oct 17 '16 at 21:06
  • This doesn't actually answer the question. – Aaron Hall Oct 17 '16 at 22:18
    @AaronHall I don't disagree, I may have stepped out from the direct question a bit but felt I that should weigh in on OPs specific case with an alternative path. – plast1k Oct 17 '16 at 22:24
  • 32
    I agree what you're saying here, and this is getting even further afield, but I think it's important to remember that code reviews aren't supposed to be adversarial. They're two people sitting down with the *shared* goal of making good code and a good product. It's okay for you to disagree sometimes about whether one approach or another is better, but all of the arguments on both sides should be rooted in doing the right thing for the team, the company, and/or the customer. If you can both agree to that, it's a smoother process. – hobbs Oct 18 '16 at 02:15
    _"Don't bother picking something good unless its a solid concise example and is directly related to the focused issue."_ - I think that opening is a bit harsh. When I do a code review I _always_ "bother" to start with something positive, even I have to resort to something benign. It helps set the tone, and shows you aren't simply looking for the negative aspects of the code. – Bryan Oakley Oct 18 '16 at 02:55
  • @BryanOakley, Here I am thinking my answer was being too soft on an industry veteran who can't even commit his changes completely :D. A welder who kept missing a couple of joints wouldn't have a job for very long. Really though under normal circumstances I agree that a balance of positive and negative discussions should be found - it just bums me out because I know what it feels like as a peon trying to elevate an entire company out a massively deep pit carved from a culture that has never once cared about quality. – plast1k Oct 18 '16 at 03:04
    "Make sure that you are blaming the code and not the author". Agreed, but the insecure/immature kind won't take it that way. – MetalMikester Oct 18 '16 at 13:18
  • I added one of my first reviews, where I had some higher standards than now and got most fire for beeing rude to the developer. With my current reviews I try to be more structured and having clearer actionables. – RobMMurdock Oct 18 '16 at 19:00
    It's incredibly important to tell the author that you're reviewing the code, not the author. Also, sandwiching different kinds of feedback is not a good idea. Stay with one kind of feedback per review round. – Filip Haglund Oct 18 '16 at 19:50
    Wow - In my experience I have to disagree. In these approaches mentioned on this page especially this one above: You sound like an apologist. I am sick of lazy, arrogant, novice and rude developers who are lateral and always "boxed in" their mindsets. We adapted a ruthless process, if they don't like it - they have to move on to another job. Simple. We cut all the time wasting and all this positive hold hands to get the best developers. Sure, we support junior devs and are positive now and then but we say it straight up. We have such a better positive working team now – TheBlackBenzKid Oct 19 '16 at 05:58
  • @Kik Someone who refused to name a function something that makes sense isn't justified in not respecting someone who their superior chose to review their code. I think the case you provide is different, and how each party handle those cases defines their maturity. – plast1k Oct 25 '16 at 16:09
  • Being good in this field isn't just being good at technical skills, those cheesy canned job requirements list teamwork for a reason. – plast1k Oct 25 '16 at 16:15
96
Code reviews can be toxic, time wasting, will to live-sapping nerd wars. Just look at the divergence of opinion on things like clean code vs comments, naming conventions, unit and integration testing, check in strategies, RESTfulness, etc., etc.
The only way to ensure you avoid this is to write down the rules for passing a code review.
Then it's not a person who is failing or approving the checkin. They are merely checking that the rules have been followed.
And because they are written down in advance, when you write your code you can follow the rules and not have to explain your reasoning or have arguments later.
If you don't like the rules, have a meeting to change them.
Pabru
  • 113
Ewan
  • 70,664
  • 76
  • 161
  • 57
    "The only way to ensure you avoid this is to write down the rules for passing a code review." This. You should be reviewing everything against some *standards that have been set for the project as a whole,* not against your personal ideas of what is OK, however insightful your personal ideas might be. – alephzero Oct 17 '16 at 21:27
    The question is how to find positive things. How do you know a name is good enough? When is a name too poor to pass code review? Many things he could praise are too subjective to have a hard and fast rule on. As such, I don't think this answers the question. – Aaron Hall Oct 17 '16 at 22:20
    I echo the sentiment about writing down the rules. Every repo has a `CONTRIBUTING.md`, and the rules go in there. Each code repo can change depending on what language/etc. Then there's no bad guy here, it's simply enforcing what is already known. – Jack Oct 17 '16 at 22:53
    -1 I love the way you jump from criticising "nerd wars" and then say "The only way to ensure you avoid this". – tymtam Oct 18 '16 at 00:26
  • 35
    It is impossible to write a rule down for every possible poor design decision. And if you tried to make one as you go, you would quickly find that the document becomes unusable from sheer length. -1 – jpmc26 Oct 18 '16 at 02:52
  • @jpmc26 **YES** you will soon find that code reviews that arent just doing the essentials are inherently flawed – Ewan Oct 18 '16 at 08:03
    @tymski its true because its bold! – Ewan Oct 18 '16 at 08:04
    This is still an underrated answer. Standards have to be written down and agreed upon by everyone on the team, including managers. Specially if they can fit into a single page and be as clear as possible. The whole purpose of code reviews is not to find something good, but to find the most bad things possible. Also, mandatory measurement of code reviews: http://www.osnews.com/story/19266/WTFs_m – Machado Oct 18 '16 at 11:35
    Much more useful than coding standards is developers and reviewers that can act as proper adults. – gnasher729 Oct 18 '16 at 14:23
    @gnasher729 well even then, what do you do? agree to disagree and just ignore the 'bad' thing? have one reviewer who will approve some things and another who will approve others? you might as well not do the reviews – Ewan Oct 18 '16 at 14:25
  • @Ewan how large that list could be? 10, 50, 200 rules? – enkryptor Oct 18 '16 at 15:14
  • @gnasher729 while I agree with you that everybody should act as proper adults, we may disagree in what is the proper behavior of adults. Some people are more flexible than others, and some will just stand by what they think that are correct. Didn't you watch Avatar ?(the series, not the movies). Even Aang had to learn how to be more stubborn in order to accomplish things. – Machado Oct 18 '16 at 16:22
    The whole purpose of code reviews is to find bugs. You can optionally add on coding standards, variable naming, clean coding and whatnot but it always needs to be clear that most important purpose of code reviews is to find bugs. It is amazing how almost all code reviewers seem to only focus on everything but finding bugs because that's the hard part of reviewing code. Pointing out coding standard discrepancies and suggesting "how you would of done it" pale in importance than finding bugs. If I were the OP, I'd be focused exclusively on finding bugs. It's hard to get mad about that. – Dunk Oct 18 '16 at 21:58
    The problem with relying on a document for this kind of thing is that people won't give up their job as office politicians, they'll just take on a second job as office constitutional-lawyers. – Ben Aaronson Oct 19 '16 at 13:16
  • The process of writing the doc is also important. It forces you to have those constitutional discussions up front and functions as a barrier of entry to frivolous rules and opinions – Ewan Oct 19 '16 at 14:46
    My team manages to conduct code reviews without a rule book or any of this apparently unavoidable negativity... – David Meister Oct 20 '16 at 14:00
  • fear will keep the juniors developers in line @DavidMeister – Ewan Oct 20 '16 at 14:12
  • @Ewan i'm not sure what you mean by that at all. Keeping junior developers "in line" is not a problem I have. Even if I did, I'm sure I could come up with a more productive and enjoyable solution for all involved than "fear". – David Meister Oct 21 '16 at 14:48
  • my point is that if you have no negativity it could be because you all agree on what constitutes 'good' or it could be that a culture of fear prevents people raising issues. – Ewan Oct 21 '16 at 15:25
    The story of how you bring civilisation to humankind doesn't stop at writing laws. It may help, but everybody knows actual laws are TL;DR. What really matters is the process in keeping them somewhat fair and applying them. – Diane M Oct 25 '16 at 18:20
25
I would not sugar coat your feedback because it may be considered as patronising.
In my opinion, the best practice is to always focus on the code and never on the author.
It's a code review, not a developer review, so:
  • "This while loop may never finish", not "Your loop may never finish"
  • "A test case is needed for scenario X", not "You didn't write the test to cover this scenario"
It is also very important to apply the same rule while talking about the review with others:
  • "Anne, what do you think about this code?", not "Anne, what do you think about Jon's code?"
Code review is not the time for a performance review - it should be done separately.
tymtam
  • 1,703
    You're not actually answering the question. The question is "How to find positive things in a code review?" - and this answer is just a contradiction - you're answering, "how do I give negative feedback". – Aaron Hall Oct 18 '16 at 18:47
16
I'm surprised it hasn't been mentioned in any answer so far, and perhaps my experience with code reviews is the unusual one, but:
Why are you reviewing the entire merge request in a single message?
My experience with code reviews is via GitLab; I always imagined that other code review tools would work similarly.
When I am giving a code review, I comment on specific, individual lines of the diff. This is extremely unlikely to be received as personal criticism, because it is commentary on the code—and is actually displayed as commentary on the code, shown directly below the code it is a commentary on.
I can also comment on the entire merge request, and often do. But specific points can be pointed out on specific lines of the diff. (Also, when a new commit is added such that the diff changes, the comments on the "outdated diff" are hidden by default.)
With this workflow, code reviews become much more modular and less cohesive. A line from a code review can simply say,
Nice approach, wrapping this in a dedicated function!
Or it might say,
This object name doesn't really match the purpose of the object; maybe we could use a name like 'XYZ' instead?
Or if there are major problems with a section, I might write:
I see that this code works (and I see why it works) but it requires focused study to understand it. Could you please refactor it into separate functions so it will be easier to maintain in the future?
(Example: Function ABC is actually doing three things here: bazzing the foo, barring the boz and fripping the zorf. Those could all be separate functions.)
After writing all of the above, I can make a summary comment on the entire merge request, something like:
This is a great new feature and it will be really useful once merged. Can you please clean up the function naming, and handle the refactoring mentioned in the individual comments I've made, and then let me know to look at it again? :)
Even if the merge request is a complete dog's breakfast, the individual comments can each be simple. There will just be more of them. Then the summary comment might say:
I'm sorry, but this code isn't really up to snuff. There are a great many edge cases (as detailed in individual comments) that will be handled incorrectly and give a bad user experience, or even data corruption in one case. (See comment on commit 438a95fb734.) Even some normal use cases will result in extremely bad application performance (specifics noted in individual comments on the diff for somefile.c).
To be production ready this feature will need a full rewrite with more attention given to what assumptions are safe to make at every point in the flow. (Hint: No assumptions are safe unless they've been checked for.)
I'm closing the merge request pending a full rewrite.
Summary: Review the technical aspects of the code as comments on individual lines of code. Then summarize those comments in an overall comment on the merge request. Don't get personal—just deal in the facts, and in your opinion about the code, not about the coder. And base your opinion on facts, accurate observation, and understanding.
Wildcard
  • 544
I am really surprised nobody picked that up, but there is something wrong with the sample review posted.
There is simply no reason you should address to Joe directly. That Joe fixes his failures is none of your business. That someone does, is your business. Your concern is code quality. So, instead of writing requests/orders/demands (that, if I were Joe, I could simply refuse because you are not legitimate for this), stay at your role and write a simple anonymous todo list.
Trying to be fair in giving good and bad points is not only impossible but completely out of your role.
Here are example of reformulation with content taken from your review:
  • Before we pull changes in the Library\ACME\ExtractOrderMail Class we need to fix a few issues.
  • Unless I missed something, "TempFilesToDelete" shouldn't be static.
  • In the future, we may call the function more than once per run, this is why we need (what has to be done here).
  • I need to understand why does "GetErrorMailBody" take an Exception as Parameter. (and, I'm being borderline here, because by now, you should already have a conclusion)
  • SaveAndSend should be renamed to better fit its behavior, like for example to "SendErrorMail"
  • Commented out code should be deleted for readability purpose. We use subversion for eventual rollbacks.
If you formulate the review like this, no matter how much the reader hates you personally, all he can see here is notes on improvements that someone has to carry on later on. Who ? When ? Nobody cares. What ? Why ? THAT you should say.
Now, you will address the very reason code reviews are rising tension by taking human factor out of the equation.
Diane M
  • 2,046
  • The sample review is a recent addition to the question, most of the answerers hadn't seen it – Izkata Oct 18 '16 at 23:47
The whole point of code review is to find problems. If there is any bug, the best thing you can do is write a test case that is failing.
Your team(manager) should communicate that producing bugs is part of the game, but finding and fixing them will save everybody's job.
It might be helpful to have regular meetings (either team or pair) and go through a couple of the issues. The original programmer didn't introduce problems intentionally, and sometimes he might think it was good enough (and sometimes it even might be). But having that second pair of eyes gives a completely fresh view, and he might learn greatly from looking at the problems.
It really is a cultural thing, and it needs lots of trust and communication. And time to work with the results.
Eiko
  • 785
    "The whole point of code review is to find problems" true - but none of this answers the question as asked. – Aaron Hall Oct 17 '16 at 22:21
    He is asking the wrong xy-problem, see http://meta.stackexchange.com/questions/66377/what-is-the-xy-problem – Eiko Oct 18 '16 at 08:01
    **Your team(manager) should communicate that producing bugs is part of the game, but finding and fixing them will save *everybody's* job.** This is true and it means that everybody is a stakeholder. But it should not be the responsibility of someone pointing out a bug (or, just bad spaghetti code) to write a test case to prove to the original coder that it's a bug. (only if it is widely disputed that it truly *is* a bug.) – robert bristow-johnson Oct 18 '16 at 17:27
I think the positive thing to do would be to get some consensus on coding standards before doing reviews. Others tend to buy in more to something when they have input.
For something like naming conventions, ask others if this is important. Most developers will agree especially among their peers. Who wants to be the person who doesn't want to agree with something so prevalent in the programming world? When you start the process by picking someone's code and pointing out the flaw, they get very defensive. When standards are established, there will be disagreement on the interpretation or what is considered "good enough," but you're better off than you are now.
Another part of this process is determining how code reviews will handle objections. This cannot become endless debate. At some point, someone has to make the decision. Maybe there can be a third-party to be the judge or the reviewer gets all the power. Stuff has to get done should be the goal.
The final piece of this is to let everyone know that Code Reviews were not your idea, they're going to stay, so everyone should make an effort to make the best of it. If everyone feels powerless, maybe they can be allowed to review your code?
Hopefully, some measurable result for management is to limit bugs, customer complaints, delays etc. Otherwise, someone just heard the buzzword "code review" and figured if they just add it to your process, miracles will occur without a lot of time, energy and effort put into this.
JeffO
  • 36,816
  • 57
  • 124
This may be harsh, but don't worry about giving good feedback if there's nothing good to measure.
However, in the future, as your developers start to improve their code, that's when you'll want to give them good feedback. You'll want to point out the improvements in the code, and you'll also want to point out the benefits to the team as a whole. When you start seeing improvement, they will as well, and things should slowly start to come around.
Another thing; there may be a defensive air because they feel as though they don't have a say. Why not let them review each other's code? Ask them specific questions and try to get them involved. It shouldn't be you versus them; it should be a team effort.
  1. What would you change about this code if you had the time?
  2. How would you improve this area of the codebase?
Ask that now, and ask that six months from now. There's a learning experience in here.
The main point - don't give praise in terms of code where it isn't warranted, but recognize effort and definitely recognize improvement. Try to make reviews a team exercise instead of an adversarial one.
    "don't worry about giving good feedback if there's nothing good to measure" I find it hard to believe that he couldn't find at least something positive to say about code written by other professional programmers while still raising the bar on expectations for everyone's code. This doesn't answer the question - it's simply a contradiction. – Aaron Hall Oct 17 '16 at 22:24
    @AaronHall: "Your code can serve as a good example how not to write code". Is that positive enough? – gnasher729 Oct 18 '16 at 14:25
    @AaronHall If the OP can find something positive to say about code written by other professional programmers, then by all means he or she should. However, if there is not, then there's no point in trying to make something up. Instead, the OP should focus on developer effort and learning, not the code itself. –  Oct 18 '16 at 16:07
Quality without Tension
You’ve asked how you can find positive things to say about code, but your real question is how you can avoid “tensions within [your] team” while addressing “serious quality problems.”
The old trick of sandwiching “bad news in good news” may backfire. Developers are likely to see it for what it is: a contrivance.
Your Organizations Top-Down Troubles
Your bosses tasked you with ensuring quality. You came up with a list of criteria for code quality. Now, you want ideas for positive reinforcement to provide to your team.
Why ask us what you need to do make your team happy? Have you considered asking your team?
It sounds like you are doing your best to be nice. The problem is not how you are delivering your message. The problem is the communication has been one-way.
Building a Culture of Quality
A culture of quality has to be nurtured to grow from the bottom up.
Let your boss know you are concerned quality is not improving fast enough, and you want to try applying some advice from The Harvard Business Review.
Meet with your team. Model the behaviors you want to see in your team: humility, respect, and a commitment to improve.
Say something like: “As you know, [coworker] and I were tasked with ensuring code quality, to prevent the sort of production issues we’ve suffered recently. I personally don’t think I’ve solved this problem. I think my biggest mistake was not involving all of you more at the beginning. [coworker] and I are still accountable to management for code quality, but going forward, we are all in the quality effort together.”
Get ideas from the team about code quality. (A whiteboard would help.) Make sure your requirements get in there by the end. Offer your insights in respectful ways, and ask questions when appropriate. Be willing to be surprised about what your team feels is important. Be flexible, without compromising business needs.
(If you have some old code you’re embarrassed about, you might trot it out, encouraging everyone to be candid. At the end, let folks know you wrote it. Model the mature reaction you are hoping for when others receive construction criticism.)
Collaborative Code Reviews
I haven’t worked at a place like you describe, where a few senior programmers review all the code and make corrections. No wonder folks respond like you are a teacher making red marks on their papers.
If you can sell the idea to managment, start doing peer code reviews. This is best done in small groups, including you or the other accountable developer. Ensure everyone is treated with respect.
An important goal of peer reviewing code is to ensure the code can be understood by all members of the team. Consider your example of unclear function names: hearing from a more junior developer that they find the function name confusing can be easier to accept than another “correction” from the senior dev.
Quality is a Journey
One other thing to do is to expunge any notion that a code review is a pass/fail sort of thing. Everyone should expect to make some edits after a code review. (And your job is to ensure they happen.)
But if that doesn’t work...
Let’s assume you make some strides establishing a culture of quality. You still might not get everyone on board. If someone is still not with the quality program, now the problem is they are not fitting in with the team, rather than there being a problem between the two of you. If they need to be dismissed from the team, the rest of the team will better understand the reasons.
Tim Grant
  • 1,360
  • Be careful about peer code reviews. We did that for a while, until we realized that a junior dev did a review for another junior dev, and allowed code through that should never have passed. The two seniors on the team now do the reviews. – Gustav Bertram Oct 19 '16 at 14:16
Sorry for yet another long answer, but I don't think the others have fully addressed the human element of this issue.
The problem with "Why did you implement it this way?" is that you put the developer immediately on the defensive. The question itself can imply all sorts of things depending on context: Are you too stupid to think of a better solution? Is this the best you can do? Are you trying to ruin this project? Do you even care about the quality of your work? etc. Asking 'why' the code was developed a certain way is only going to be confrontational, and that subverts any pedagogical intent your comment might have had.
Similarly "I would have done this differently..." is also confrontational, because the immediate thought the developer will have is "Well I did it this way... You got a problem with it?" And again, it's more confrontational than it needs to be and turns the discussion away from improving the code.
Example:
Instead of asking "Why did you choose not to use the constant variable for this value?", simply state "This hard-coded value should be replaced with the constant XYZ in file Constants.h" Asking the question suggests that the developer actively chose not to use the already-defined constant, but it's entirely possible that they didn't even know it existed. With a large enough code base, there's going to be a lot of things each developer doesn't know. This is simply a good learning opportunity for that developer to get acquainted with the project's constants.
There's a fine line to walk with code reviews: you don't need to sugar coat everything you say, you don't need to sandwich bad news with good news, and you don't need to soften the blow. It could be the culture I'm in, but my coworkers and I never compliment each other in code reviews - the parts of the code we develop that are defect-free are enough of a compliment. What you need to do is identify the defect you see, and perhaps give a reason why (the why is less useful when it's obvious/simple).
Good:
  • "The name of this variable needs to be changed to match our coding standard."
  • "The 'b' in this function name needs to be capitalized in order to be PascalCase."
  • "This function's code isn't indented properly."
  • "This code is a duplicate of code found in ABC::XYZ(), and should use that function instead."
  • "You should use try-with-resources so that things are guaranteed to be closed properly in this function, even if errors occur." [I only added a link here so non-java users would know what try-with-resources means]
  • "This function needs to be refactored in order to meet our n-path complexity standards."
Bad:
  • "I think you could improve this code by changing the variable name to match our standard"
  • "Perhaps it would be better to use try-with-resource to properly close things in this function"
  • "It might be desirable to take another look at all the conditions in this function. Its N-path complexity is over our standard's maximum allowed complexity."
  • "Why are the indents here 2 spaces instead of our standard's 4?"
  • "Why did you write a function that breaks our n-path complexity standard?"
In the bad statements the italicized parts are things that people commonly use when they want to soften the blow, but all it really does in a code review is make you sound uncertain of yourself. If you, the reviewer, aren't certain on how to improve the code, then why should anyone listen to you?
The 'good' statements are blunt, but they don't accuse the developer, they don't attack the developer, they're not confrontational, and they don't question why the defect exists. It exists; here's the fix. They're certainly not as confrontational as that last 'why' question.
Shaz
  • 2,614
    Many of the examples you give would be detected by static analysis. In my experience the things that come up in code reviews are often more subjective and opinionated: "I would call X Y instead because I think it better reflects the behavior". In our organization, the creator of the PR can then use her own judgement and either change the name or leave it as it is. – Muton Oct 19 '16 at 12:38
  • @Muton I agree with you about the static analysis. We have those checks automated in the projects I work on. We also have tools that automate code formatting so most coding style issues never (or rarely) come up either. But OP specifically mentioned that their code base is a mess, so I imagined these are the kinds of problems they're dealing with in reviews, and I think these simple examples remain relevant to the update OP made to showcase an example review. – Shaz Oct 19 '16 at 13:40
I would respectfully disagree with the method of code review you've described. Two staffers going off into a 'closed room' and coming out with criticism institutionalizes the very kind of adversarial notion that good code reviews should be avoiding.
Making code review a positive experience to the extent possible is essential to making it successful. Step one is to remove the adversarial notion of review. Make it a weekly or bi-weekly group event; ensure everyone knows they are welcome to participate. Order in pizza or sandwiches or whatever. Don't even call it a 'code review' if that stirs up negative connotations. Find something to celebrate, to encourage, to share - even if it's nothing more than progress through the current sprint or iteration. Take turns assigning leadership over the review.
Make the process an endeavor to serve the product and the people. If they are done constructively, positively, wherein good techniques or patterns are shared and encouraged just as poor ones are discouraged - everyone benefits. Everyone gets coached in public. If you have a problem programmer who isn't "getting it," they should be addressed privately and separately - never in front of the broader group. That's separate from code review.
If you're having trouble finding something "good" to bring up, that to me begs a question: If progress is being made in the project, and people are working, that progress in and of itself is something to celebrate. If you're truly finding nothing good, that implies everything that's been done since the last review is either bad or no better than neutral. Is that really the case?
As for the details, common standards are essential. Give everyone a stake in what's being done. And allow for newer, better techniques to be integrated into your code base. The failure to do that guarantees old habits are never excised under the guise of "we've always done it that way."
The point in all this is that code reviews are given a bit of a bad rap because they are poorly implemented, used as hammers to belittle less experienced or less skilled programmers, and that is of service to no one. Managers who use them in this way aren't likely to be very effective managers, either. Good code reviews wherein everyone is a participant serves everyone - the product, the employees, and the company.
Apologies for the length of the post, but having been in a group where code review was largely ignored, it led to a legacy of unmaintainable code and only a narrow range of developers able even if allowed to make changes to a years-old codebase. It was a path I'd opt not to traverse again.
David W
  • 149
The problem that you see is: Developers are unhappy that their code is criticised. But that's not the problem. The problem is that their code is no good (assuming obviously that your code reviews are good).
If the developers don't like their code attracting criticism, then the solution is easy: Write better code. You say you had serious problems with code quality; that means better code is needed.
"Why should the method have a sensible name, I know what it does?" is something that I find particularly disturbing. He knows what it does, or at least he says so, but I don't. Any method should not just have a sensible name, it should have a name that makes it immediately clear to the reader of the code what it does. You might want to go to Apple's website and look for a WWDC video about the changes from Swift 2 to Swift 3 - a huge number of changes made just to make everything more readable. Maybe that kind of video could convince your developers that developers who are a lot smarter than them find intuitive method names to be very, very important.
Another disturbing item was your colleague who said "she told me herself, that after a bugreport was filed by a customer, that she knew of the bug, but feared that the developer would be mad at her for pointing it out". There is the possibility that there is some misunderstanding, but if a developer gets mad if you point out a bug to them, that is bad.
gnasher729
  • 42,090
  • 59
  • 119
The paradox of good code is that it doesn't stand out at all, and looks like it was very straightforward and easy to write. I really like the pool player example from this answer. In code reviews, that makes it really easy to gloss over, unless it happens to be a refactor from bad code.
I make a point to look for it. If I'm reviewing code and I've gone through a file that was so easy to read that it seems deceptively easy to write, I just throw in a quick "I like how the methods here are short and clean" or whatever is appropriate.
Also, you should lead by example. You should insist that your code be reviewed too, and you should model how you want your team to behave when receiving correction. Most importantly, you should sincerely thank people for the feedback. This makes more difference than any unilateral feedback you can give.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
It sounds like the real problem is that it is only two people who are doing all the code reviews, of which it is only you who take them seriously, which has ended you up in an unfortunate situation with a lot of responsibility and a lot of pressure from the other team members.
A better way would be to distribute the responsibility of doing the code reviews over the team, and have everyone take part in doing them, for example by letting the developers choose whom to review their code. This is something that your code review tool should support.
HelloGoodbye
  • 121
  • Unsure why this was downvoted (downvotes with no comments are ludicrously silly on a thread about good code review). Everyone reviewing should be standard procedure. On a Kanban board, there would be a column for code review, and whoever in the team picks up the next item should do the review (with caveats; newbies should not pick up reviews for a while, and then should start on those which require little domain knowledge). On a scrum board, essentially similar: work right to left. – Dewi Morgan Oct 21 '16 at 15:39
I've seen this happen first-hand and want to caution you away from the emotional intelligence challenged answers - they can kill entire teams. Unless you want to recruit, train and normalize new developers every year, creating a positive rapport with your peers is essential. After all, isn't the whole point of doing these reviews to improve code quality and foster a culture where the code quality is higher in the first place? I would argue that it is indeed part of your job to provide positive reinforcement as a means of integrating this code review system into the team culture.
Anyways, sounds like you need to review your Code Review system. Right now, from the sounds of it everything in your review process is, or can be interpreted as, subjective rather than objective. It is easy to get hurt feelings when it feels like someone is just picking apart your code because they don't like it, rather than them having a reason that they can cite when something doesn't fit the guidelines. This way, its easy to track and 'celebrate' positive improvements in code quality (with respect to your review system) in whatever way is appropriate for your office culture.
The Technical Leads need to get together outside of a review session and put out a Coding Guidelines/Code Review Checklist and it needs to be adhered to and referred to during the review. This should be a living document which can be updated and refined as the process develops. These Tech Lead meetings should also be when the 'Way we've always done things' vs. 'New and improved ways of doing things' discussion should happen, without the developer being reviewed feeling like the disagreement is a result of their code. Once the initial guideline has been more or less smoothed out, another way to positively reinforce the developers is to ask for their feedback and then actually take action on it and evolve the process as a team, this does wonders to bring them up to speed to begin to review code for onboards so you're not stuck doing reviews until you retire, too.
navigator_
  • 139
Premises...
Programmers are problem-solvers. We are conditioned to start debugging when presented with a problem or error.
Code is an outline-format medium. Switching to a paragraph-format narrative for feedback introduces a disconnect that must be translated. Inevitably something gets lost or misunderstood. Unavoidably, the reviewer is not speaking in the programmer's language.
Computer-generated error messages are seldom questioned and never taken as a personal affront.
Code-review items are human-generated error messages. They are intended to catch the edge-cases that programmers and automated tools miss as well as the inevitable side-effects on other programs and data.
Conclusions...
Thus, the more code-review items can be incorporated into automated tools, the better they will be received.
The caveat is that, to remain unquestioned, such tools must be continuously updated, usually daily or weekly, to be in compliance with every change to procedures, standards and practices. When a manager or developer team decides to make a change, tools must be changed to enforce that. Much of the code-reviewer's job then becomes maintaining the rules in the tools.
Example Code Review Feedback...
A rewrite of the given example incorporating these techniques:
  • Subject:
    • Library\ACME\ExtractOrderMail Class.
  • Principle issue...
    • TempFilesToDelete is static
      • Subsequent calls to GetMails throw an exception since files are added to it but never removed after deletion. Though only one call now, performance could be improved in the future with some parallelism.
      • TempFilesToDelete as an instance variable would allow multiple objects to be used in parallel.
  • Secondary issues...
    • GetErrorMailBody has an exception parameter
      • Since it does not throw an exception itself, and just passes this to ToString, is it necessary?
    • SaveAndSend name
      • Email may or may not be used to report this in the future and this code contains the general logic for storing a persistent copy and reporting any errors. A more generic name would allow such anticipated changes without change to dependant methods. One possibility is StoreAndReport.
    • Commenting out old code
      • Leaving a line commented and marked OBSOLETE can be very helpful in debugging, but a "wall of comments" can also obscure errors in adjacent code. We still have it in Subversion. Perhaps just a comment referencing exactly where in Subversion?
DocSalvager
  • 305
If you don't have anything nice to say about the existing code (which sounds understandable), try to involve the developer in improving it.
In a patch for a functional change or bugfix, it's not helpful to have other changes (renaming, refactoring, whatever), bundled into the same patch. It should make the change that fixes the bug or adds the feature, nothing else.
Where renaming, refactoring and other changes are indicated, do them in a separate patch, before or after.
  • This is pretty ugly, but I guess it's consistent with all our other nasty code. Let's clean that up later (in a patch with, ideally, no functional changes).
    It also helps if you join in refactoring, and let them review your code. It gives you a chance to say why you think something is good, rather than bad, and also to show an example of taking constructive criticism well.
If you need to add unit tests to a new feature, fine, they go in the main patch. But if you're fixing a bug, the tests should go in a prior patch and not pass so you can demonstrate the fix actually fixed the bug.
Ideally the plan (for how you can test a fix, or what to refactor and when) should be discussed before the work is done, so they haven't sunk a load of effort in something before finding out you have a problem with it.
If you find code doesn't cope with inputs you think it should, it may also be a mismatch in what the developer sees as reasonable input. Agree that in advance too, if possible. At least have some discussion about what it should be able to cope with and how nastily it can be allowed to fail.
Useless
  • 12,380
  • Whether in separate patches or not, a broken window policy needs to be instated with legacy code, whether that policy is "don't fix broken windows" or "only in [methods/classes/files?] that are touched by the current patch". In my experience, preventing developers from fixing broken windows is toxic to team morale. – Dewi Morgan Oct 21 '16 at 15:44
    True, but forcing them to fix every broken window in a module before their one-line change passes review is equally toxic. – Useless Oct 21 '16 at 15:45
  • Agreed! A policy that's been thrashed out by the team, rather than externally imposed, is the only kind that can work, I feel. – Dewi Morgan Oct 21 '16 at 15:50
I think it's a mistake to assume there is a technical or easy solution to: "my co-workers are upset when I judge their work by my standards, and have some power to enforce it".
Remember code reviews aren't just a discussion of what's good or bad. They are implicitly a "who's yard stick are we using", a "who makes the decision" and hence -most insidiously- a rank.
If you don't address those points, doing code reviews in a way that doesn't have the problems you encounter are going to be hard. There is some good advice here about how to do it, but you've set yourself a difficult task.
If you are right, without any wiggle room, pointing it out is an attack: someone messed up. If not: your another MBA who doesn't get it. Either way, your going to be the bad guy.
However, if the what the review is looking and why, is clear and agreed upon, you have a decent chance of not being the bad guy. You aren't the gatekeeper, just a proofreader. Getting this agreement is a hard problem to solve[1]. I'd like to give you advice, but I haven't got the hang of it myself yet...
[1] It's not solved just because people have said "ok", or stopped fighting about it. None want to be the guy to say X just isn't practical for our {intelligence, experience, man-power, deadlines, etc} but that doesn't mean when it actually comes to some specific instance of doing X...
drjpizzle
  • 264
Code reviews should be mutual. Everybody criticized everybody. Let the motto be "Don't get mad, get even." Everybody makes mistakes and once people have told a hot shot how to fix their code, they will understand that this just the normal procedure and not an attack on them.
Seeing other people's code is educational. Understanding the code to the point where you can point out its weak spot and having to explain that weakness can teach you a lot!
There is little room for praise in a code review, since the whole point is to find flaws. However, you can heap praise on fixes. Both timeliness and neatness can be praised.
Stig Hemmer
  • 552
  • Unsure why this was downvoted (downvotes with no comments are ludicrously silly on a thread about good code review). Everyone reviewing should be standard procedure. On a Kanban board, there would be a column for code review, and whoever in the team picks up the next item should do the review (with caveats; newbies should not pick up reviews for a while, and then should start on those which require little domain knowledge). On a scrum board, essentially similar: work right to left. – Dewi Morgan Oct 21 '16 at 15:41
    @DewiMorgan I disagree with "newbies should not pick up reviews for a while". Newbies doing reviews is an excellent way for them to gain familiarity with a code base. That said, they shouldn't be the ***only*** reviewer! And that said, I'm in any case also wary of having only one reviewer most of the time. – Disillusioned Oct 25 '16 at 13:55
