If the whole application fits into a single file, that is the most simple solution.
Otherwise, it is best to create a complete package. When you create a setuptools-based setup.py
file, you can define various entry points that should be installed as scripts. However, these entry points refer to functions, not files.
Instead of running a script with Python (python path/to/script.py args...
), you can also run a module or package: python -m example.package args...
. For modules (i.e. Python files), you have to do the if __name__ == '__main__'
check and dispatch to your main function. For packages (i.e. directories with an __init__.py
file), you have to create a __main__.py
file as an entry point. It makes sense to put the argument parsing & user interface code here.
This is particularly sensible when adding a command line interface to an existing library. However, it is often elegant to write the central behaviour of an application as a library, and then only wrap that library with a simple user interface. In particular, this layered architecture makes unit testing easier.
