Today at work a colleague was looking at a piece of module I had written a month ago as a reference implementation.
I had written a WCF service which a Windows service was consuming.
I have a single operation
exposed as below.
[ServiceContract]
public interface IMyService
[OperationContract]
void PerformASpecificTask(int randomNumber);
I have a similar interface in a separate assembly and I refer to this contract in a different assembly which implements this above interface,
similar to how one would implement any WCF service contracts.
I have the interface in a separate assembly because I can distribute the dll with the interface alone to the clients (Windows service in my case).
public class MyService : Contract.IMyService
private readonly Domain.ISomeDomainNameHereDataProvider _domainDataProvider;
private readonly Domain.ADomainService _aDomainService;
public MyService(Domain.ISomeDomainNameHereDataProvider domainDataProvider,
Domain.ADomainService aDomainService)
_domainDataProvider = domainDataProvider;
_aDomainService = aDomainService;
public void PerformASpecificTask(int randomNumber)
var myRequiredData = _domainDataProvider.GetMyRequiredData(randomNumber);
myRequiredData.ForEach(data => _aDomainService.DoSomething(data));
_domainDataProvider.SaveMyChanges(myRequiredData);
Here ADomainService
is a class which lives in an assembly named Domain
and this class uses another WCF service internally,
the proxy of which is injeccted during its instantiation.
is a interface I have in the Domain
assembly I also have another interface IDataAccess
in the Domain
assembly.
IDataAccess
is implemented in my DAL
assembly.
Implementation of `ISomeDomainNameHereDataProvider` is in the same `Domain` assembly
and an implementation of `IDataAccess` which lies in `DAL` is injected to it.
So `ISomeDomainNameHereDataProvider` makes use of `IDataAccess` to access the data or to be specific sql-server in this case.
Please note I didn't define `IDataAccess` in a separate assembly of its own, as this work was a small task and my `Domain` would be only one consuming it.
Now coming to the question, this colleague calls me and question why is your service talking to `DAL` directly and not using the `Domain` layer.
His reasoning was my implementation of an interface defined in `Domain` came from `DAL`.
He went to say your service has business logic and it violates `open-close` and `single-responsibility` prinicple,
I take pride in my work and explanned I don't violate the principles and all my classes have only one responsibility and
open-close is not a rule and does not apply in this usecase at hand.
I also tried reasoning for this requirement I have to get some data, perform some operation with the data and then save it back and
you need a place to co-ordinate all this and my service class does that and that is the responsibility of my service.
He wouldn't agree and started talking about requirements changes, etc.
I tried reasoning another solution would have been to move the code I have in my service implementation to a different class and that class would have the same code
and he wouldn't agree.
Am I missing something ?
Please let me know what you think of the above solution and events ?
I could only think, he comes from a `MVC` background and thinks of the service class akin to a 'Controller'.
`Controller` anyway would delegate the calls to a service layer and all the code I have in my service implementation would remain?
I have read this How accurate is "Business logic should be in a service, not in a model"? and would still require you opinions on my solution above.
