I've been tasked to query 2 large csv files which are roughly 1 GB in size each. The files contain related data, so file one may contain a list of order numbers, Order Dates, etc and the file may contain the order lines, stock codes, quantity, etc.
Other Restrictions:
  • No Access to a database - so I can't just bulk insert and query
  • Must be able to add new queries at a later point
The kind of query I need to write is Sum all the lines grouped by Stock Code or How many orders were there between two dates.
My initial idea is to create two models representing the spreadsheet and then import the lot and query via Linq. However this may cause an issue due to the size of the data (and i can't use a database for lazy loading, etc). Also the querying of the models maybe quite slow.
The other idea I had was to create an import routine that evaluates the data line by line i.e. if I need to count how many stock codes there are in a file I can simply just query the one column in the spreadsheet on a line by line basis and then count them. This would mean that i would have to write a csv import and some sort of query class.
Any thoughts or ideas on how to handle this or the best approach? Is there a pattern for this already?
CodesInChaos
  • 5,697
  • 26
Rhodes73
  • 43
    You 'cant use a database' but your approach is 'program my own database engine' whats the real restriction? cant _install_ a database? just use an inmemory one like sqlite – Ewan Oct 06 '16 at 08:08
    Seriously, why do you accept such limitations? No database for two one gig files with these specs? tell them to do the job themselves. In any case this sounds like reinventing the wheel, use some data analytics tool like Knime, RapidMiner or even IBM's Watson Analytics. – thorsten müller Oct 06 '16 at 08:17
    If you have a decent computer, loading everything into RAM should still work with these file sizes. – CodesInChaos Oct 06 '16 at 08:41
    (When you write "gb", you mean "GB", right?) – CodesInChaos Oct 06 '16 at 08:42
  • Excel for 2 GB of data because you don't have a database? 2 GB is the limit in 32 bit. There are many free databases that do this. – paparazzo Oct 06 '16 at 15:36
A Stream does not need to read the entire file into memory, so...
Don't bother with Excel at all if you can accumulate needed information while reading records:
  • Sum as records are read
  • Build a Dictionary of StockCode & count
  • Build a Dictionary of StockCode & sum
  • Define lean DTO kinds of classes if you must have a comprehensive collection.
  • A collection or Dictionary of said DTO objects, keyed on .. whatever
Perhaps separate classes for each separate purpose, possibly based on an abstract class that has common file read code - future proofing.
Links discussing efficient Stream I/O
radarbob
  • 5,808
  • ++ RadarBob, but maybe it'd be best to perform an ODBC query? No database, with the power of SQL. Much simpler no? – RubberDuck Oct 07 '16 at 00:16
Ummm...Use Excel. Excel can import CSV files. All the functionality you describe here can be done in Excel.
If these are recurring tasks, you could write some macros to automate the loading of the files and just hand off xlsx file as needed.
Latest version of Excel limitations:
Worksheet size
1,048,576 rows by 16,384 columns
If the files have more data than these limitations I would go with @MainMa/RadarBob solution.
Jon Raynor
  • 10,905
  • 47
    The first thought of a professional programmer should be: do I need to write code, or has someone else already done it? – kevin cline Oct 06 '16 at 15:39
  • Actually, querying the csv file with an ODBC connection might work surprisingly well. I wouldn't have thought of it if you hadn't mentioned Excel. – RubberDuck Oct 07 '16 at 00:14
I do not know which, from the other answers, will work best for you.
AFAICT, I'd remark, mostly from an implementation standpoint, that they all make sense, but from a design perspective, which one will scale best, will be best maintainable, etc, it all depends on other factors you may have left out from your question as-is.
I can think of two.
1) the actual shape of the flat data you have already on hand (independently of the volume of it)
2) whether or not you have the comprehensive knowledge of a bounded, predictible set of the query criteria your application will need.
For instance, if one can make two more strong assumptions about that (and which you only know about) -- and beware, they are indeed very strong:
a) if we assume the answer to (2) is "yes";
and
b) the flat CSV is already sorted on: order id > order line, with order date strictly increasing after the first (order id).
Then radarbob's answer might be the best -- where all you'd need would be a fast line-by-line CSV reader -- implementing, e.g., IEnumerable < RawOrderLine > -- with little code to write, easy to maintain, and with no other dependencies.
E.g.:
(much hypothetical & untested code)
OrderNo         OrderLine       OrderDate       StockCode       Quantity        Etc
1001            1               1/4/2016        Product1        5               ...
1001            2               1/4/2016        Product2        3               ...
1002            1               5/7/2016        Product1        10              ...
1003            1               2/8/2016        Product2        4               ...
get all orders for given stock code and given date:
API:
IEnumerable<RawOrderLine> GetOrders(IEnumerable<RawOrderLine> csv, string stockCode, DateTime orderDate)
How to:
csv.Where(line => line.StockCode == stockCode && line.OrderDate == orderDate)
get all orders for given stock code and falling in given date range:
API:
IEnumerable<RawOrderLine> GetOrders(IEnumerable<RawOrderLine> csv, string stockCode, DateTime startDate, DateTime endDate)
How to:
csv.SkipWhile(line => line.OrderDate < startDate).
    TakeWhile(line => line.OrderDate <= endDate).
    Where(line => line.StockCode == stockCode)
get sum of quantities for given stock code of all orders falling in given date range:
API:
int GetQuantity(IEnumerable<RawOrderLine> csv, string stockCode, DateTime startDate, DateTime endDate)
How to:
    Where(line => line.StockCode == stockCode).
    Aggregate
        0,
        (sum, line) => sum += line.Quantity
Etc, etc.
For a quick and dirty full sample, this below will generate exactly 3 millions random orders into the future, spaced by 1 to 2 minutes from each other (cf. OrderDate), and with 1 to 10 order lines each (of distinct product / quantity pairs) -- resulting in a ~ 500MB file (if in ASCII/ANSI encoding anyway).
The two sample queries (over the last 3 days of 2016, for "Product9") take only a couple seconds on my end (machine rather sluggish).
(the main thing which is annoyingly slow is to spit out that random sample data, in the first place)
//#define GENERATE_SAMPLE
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace _332960
    public class RawOrderLine
        public override string ToString()
            return string.Format("{0},{1},{2},{3},{4}", OrderNo, OrderLine, OrderDate.ToString("yyyy-MM-dd HH:mm"), StockCode, Quantity);
        public RawOrderLine Parse(string data)
            var columns = data.Split(',');
            OrderNo = int.Parse(columns[0]);
            OrderLine = int.Parse(columns[1]);
            OrderDate = DateTime.Parse(columns[2]);
            StockCode = columns[3];
            Quantity = int.Parse(columns[4]);
            return this;
        public int OrderNo { get; set; }
        public int OrderLine { get; set; }
        public DateTime OrderDate { get; set; }
        public string StockCode { get; set; }
        public int Quantity { get; set; }
    public class RawOrderReader
        public RawOrderReader(string filePath)
            FilePath = filePath;
        protected string FilePath { get; private set; }
        public IEnumerable<RawOrderLine> Data
            get
                using (var reader = new StreamReader(FilePath))
                    string line;
                    while ((line = reader.ReadLine()) != null)
                        yield return new RawOrderLine().Parse(line);
    class Program
        public const int BaseOrderCount = 1000 * 1000;
        public static string[] StockCodes =
            new[]
                "Product0", "Product1", "Product2", "Product3", "Product4",
                "Product5", "Product6", "Product7", "Product8", "Product9"
        static Random random = new Random(DateTime.Now.Millisecond);
        static DateTime lastOrderDate = DateTime.Now;
        static int lastOrderNo = BaseOrderCount - 1;
        static IEnumerable<RawOrderLine> NewRandomOrder()
            var lines = new List<RawOrderLine>();
            // for random selection of 1 to 10 order lines (incl.)
            // one product per line
            var codes = 1 + random.Next(1023);
            var codeMask = 512; // idem
            var product = 9; // idem
            var orderLine = 0;
            lastOrderDate = lastOrderDate.AddMinutes(1 + random.Next(2));
            lastOrderNo++;
            while (codeMask > 0)
                if ((codes & codeMask) > 0)
                    lines.
                    Add
                        new RawOrderLine
                            OrderNo = lastOrderNo,
                            OrderLine = ++orderLine,
                            OrderDate = lastOrderDate,
                            StockCode = StockCodes[product],
                            // random quantity from 1 to 20 units (incl.)
                            Quantity = 1 + random.Next(20)
                codeMask >>= 1;
                product--;
            return lines;
        public class CsvQuery
            public IEnumerable<RawOrderLine> GetOrders(IEnumerable<RawOrderLine> csv, string stockCode, DateTime orderDate)
                return
                    csv.Where(line => line.StockCode == stockCode && line.OrderDate == orderDate);
            public IEnumerable<RawOrderLine> GetOrders(IEnumerable<RawOrderLine> csv, string stockCode, DateTime startDate, DateTime endDate)
                return
                        Where(line => line.StockCode == stockCode);
            public int GetQuantity(IEnumerable<RawOrderLine> csv, string stockCode, DateTime orderDate)
                return
                    csv.Where(line => line.StockCode == stockCode && line.OrderDate == orderDate).
                        Aggregate
                            0,
            public int GetQuantity(IEnumerable<RawOrderLine> csv, string stockCode, DateTime startDate, DateTime endDate)
                return
                        TakeWhile(line => line.OrderDate < endDate).
                        Aggregate
                            0,
        static void Main(string[] args)
#if GENERATE_SAMPLE
            // create 3 millions of orders (of 1 to 10 order lines each)
            for (var i = 0; i < 3 * BaseOrderCount; i++)
                var lines = NewRandomOrder();
                foreach (var line in lines)
                    Console.WriteLine(line);
#else
            var csvReader = new RawOrderReader("data.csv");
            var csvQuery = new CsvQuery();
            Console.WriteLine();
            Console.WriteLine("Get last 3 days of Product9 orders... " + DateTime.Now);
            var lastThreeDaysOf2016Product9Orders =
                csvQuery.
                GetOrders
                    csvReader.Data,
                    "Product9",
                    new DateTime(2016, 12, 29),
                    new DateTime(2016, 12, 31).AddDays(1).Subtract(new TimeSpan(0, 0, 1))
                ToArray();
            Console.WriteLine("... done @ " + DateTime.Now);
            Console.WriteLine("Get last 3 days of Product9 quantities..." + DateTime.Now);
            var lastThreeDaysOf2016Product9Quantity =
                csvQuery.
                GetQuantity
                    csvReader.Data,
                    "Product9",
            Console.WriteLine("Details...");
            foreach (var order in lastThreeDaysOf2016Product9Orders)
                Console.WriteLine(order);
            var quantityCheck = lastThreeDaysOf2016Product9Orders.Sum(order => order.Quantity);
            Console.WriteLine("{0} = {1} ?", lastThreeDaysOf2016Product9Quantity, quantityCheck);
#endif
            Console.ReadKey();
'Hope this helps.
YSharp
  • 888
Of course you can use bulk import. If you can't access the corporate database for some reasons, you install one locally and use it. Since you seem to be working with Microsoft's stack, SQL Server Express Edition is free. Open source databases could also be used (and would probably be easier/faster to install).
Otherwise, like already suggested in the comments, you may be able to load both files in memory: 2 GB CSV would translate in less than 2 GB of memory used, which should be doable even on low grade hardware, not counting developer's machines. This approach, however, would probably not work well if you need to start and stop the application frequently: loading large CSVs to do just one or two queries won't be as efficient as querying the database directly.
Arseni Mourzenko
  • 134,780
  • 343
  • 513
Another [potentially complex and painful] Technical Solution in search of a Problem.
... query 2 large csv files which are roughly 1 GB in size ...
... No Access to a database ...
Why not?
A database is the right tool for the job.
Anything else will be [more] cumbersome, slow[er], less reliable and, ultimately, cost more (that'll get their attention).
All compelling reasons for you to go back and challenge this so-called "Requirement".
Phill W.
  • 11,891
