I've recently started developing a project in Node.js. Of course, right now the packages I'm using are pretty up-to-date as I'm starting afresh and using the latest version, but there's a pretty high version turnover rate for most Node.js packages and often certain features will be deprecated or dropped, and of course security vulnerabilities will be fixed.
Since most of my packages are specified using the semantic versioning syntax ^1.2.3
(stick to the given major version number to avoid breaking changes), any important updates beyond the current major version will be lost.
What is a prudent way to ensure that you stay reasonably up-to-date with your dependencies? Is it necessary to put, say, a weekly check for updates to your dependencies into your workflow to make sure you don't fall way behind? And for this reason, would it be a good idea to try and minimize dependencies to minimize the pain of dealing with breaking changes when you necessarily update to newer major versions?
