With the static methods, there is no object to provide proper control of the override mechanism.
The normal class/instance virtual method mechanism allows for finely tuned control of overrides as follows: each real object is an instance of exactly one class. That class determines the behavior of the overrides; it always gets the first crack at virtual methods. It can then choose to call parent method at the right time for it's implementation. Each parent method then also gets its turn to invoke its parent method. This results in a nice cascade of parent invocations, which accomplishes one of the notions of reuse of code that object orientation is known for. (Here the base/super classes' code are being reused in a relatively complex way; another orthogonal notion of code reuse in OOP is simply having multiple object of the same class.)
Base classes can get reused by various subclasses, and each can coexist comfortably. Each class that is used to instantiate objects dictating its own behavior, peacefully and simultaneously coexisting with the others. The client has control over which behaviors it wants and when by choosing which class to use to instantiate an object and pass around to others as desired.
(This is not a perfect mechanism, as one can always identify capabilities that are not supported, of course, which is why patterns like factory method and dependency injection are layered on top.)
So, if we were to make an override capability for statics without changing anything else, we would have difficulty ordering the overrides. It would be hard to define a limited context for the applicability of the override, so you would get the override globally rather than more locally like with objects. There is no instance object to switch the behavior. So, if someone invoked the static method that happened to have been overridden by another class, should the override get control or not? If there are multiple such overrides, who gets control first? second? With instance object overrides, these questions all have meaningful and well-reasoned answers, but with statics they do not.
Overrides for statics would be substantially chaotic, and, things like this have been done before.
For example, the Mac OS System 7 and prior used a trap patching mechanism for extending the system by getting control of application-made system calls before the operating system. You could think of the system call patch table as an array of function pointers, much like a vtable for instance objects, except that it was a single global table.
This caused untold grief for programmers because of the unordered nature of the trap patching. Whoever got to patch the trap last basically won, even if they didn't want to. Each patcher of the trap would capture the previous trap value for a sort-of parent call capability, which was extremely fragile. Removing a trap patch, say when you no longer needed to know about a system call was considered bad form as you didn't really have the information needed to remove your patch (if you did it you would also unpatch any other patches that had followed you).
This is not to say that it would be impossible to create a mechanism for overrides of statics, but what I would probably prefer to do instead is turn the static fields and static methods into instances fields and instance methods of metaclasses, so that the normal object orientation techniques would then apply. Note that there are systems that do this as well: CSE 341: Smalltalk classes and metaclasses; See also: What is the Smalltalk equivalent of Java's static?
I'm trying to say that you would have to do some serious language feature design to make it work even reasonably well. For one example, a naive approach was done, did limp along, but was very problematic, and arguably (i.e. I would argue) architecturally flawed by providing an incomplete and difficult to use abstraction.
By the time you're done designing the static overrides feature to work nicely you might have just invented some form of metaclasses, which is a natural extension of OOP into/for class-based methods. So, there is no reason not to do this -- and some languages actually do. Perhaps it is just a bit more of a fringe requirement that a number of languages choose not to do.
