Events and Subscribers
When you make the shift from polling to event notifications, the best way to think about it is in terms of events and subscribers.
In your concept, you imagine the web server maintaining a session state for each instance of the client, and effectively polling the database on its behalf in order to know when to send the notification to the client.
You are right to be concerned about the impact on server resources of this approach! You haven't yet fully leveraged the power of notifications, you've just shifted where the polling happens.
A more effective way is for clients to register themselves to receive a notification when a particular piece of data changes. Then, when that data changes, publish a notification that the data has changed. Let the notification framework identify who has registered to receive a notification (subscribed) and to let them know.
One way to do this with signalr is through 'groups'. Exactly how it should be structured depends on your data model, but using your example, you could have a group per driver. A simplified view of the sequence:
- The client app starts and initiates a connection to the signalr endpoint
- The client app subscribes to notifications about a particular driver
- There are many ways to do this, but if you are using signalr, you can directly call server methods from the client
- The server would add the client into a group for the requested driver
- When the driver reports a new location, tell signalr to send a message to the group for that driver
- Strictly speaking in signalr, this is done by invoking a client side method from the server
- The client now has the updated info and can refresh the page
- If there are no clients registered in the group, signalr will do nothing
- If there are multiple clients registered in the group, signalr will invoke the same method (with arguments) on all of them
- You can further decouple the 'write operation' which updates the data from the code which sends the notification via signalr through a concept such as domain events
This way you receive notifications on the client, without polling anywhere.
Edit to add - Efficiency
Following your comment, a few notes on efficiency using your example of a chat application:
With polling approach, you are using the following resources:
- storage (db/memory):
- list of who is talking to who
- chat message history with appropriate metadata so that the poll request can identify new messages since the last request
- computation
- handling new messages pushed in by the client - storing them appropriately
- you'd have one request per new chat message
- handling poll requests by the clients - querying for new messages and returning them - would happen on every poll from every client
- if you have 500 clients, some of whom are idle, you'd still have 50 requests per second
Scalability:
- Your storage load grows with number of active clients, and with chat activity
- Your compute load grows with message chat activity and with number of connected clients
With a signalr notification approach, you have:
- storage
- list of who is talking to who (signalr will do this for you for free with it's 'group' system
- chat messages (optional - only if you want a chat log on the server - and could be persisted asynchronously)
- computation
- handling new messages pushed in by the client, which includes asking signalr to propagate them to the members of the group
- one request per new chat message
Scalability:
- Your storage load grows with the number of active clients only
- Your compute load grows with message chat activity only
Based on that, I think the notification approach is more efficient. As you can see, while signalr will maintain the group membership list, you have to do that anyway even if you go down a polling approach.
Terminology Note
- Push Notifications have a well defined meaning in this space, which permits sending a notification via the mobile device's operating system, which permits the notification to appear in the device's notification list even if your app isn't running - e.g. Apple Push Service & Google Cloud Messaging. Strictly speaking, signalr won't give you that, as your app must be running to receive the signalr client invocation.
