There are a bunch of design patterns for event-driven code out there, some of which were already mentioned in the comments. I'll write a short introduction to each of the ones I'm familiar with.
Promises/Futures
These two terms are generally used for essentially the same concept: a value which will be available in the future, but isn't necessarily ready yet. (I'll let Wikipedia cover the differences between these concepts.)
Promises/Futures are used in cases where you might have used a callback to receive a value. They often will provide functionality to let you know when the value becomes available and let you retrieve it:
Future<X> doSomething() {
Future<X> fx = doSomething();
while (!fx.isAvailable()) {}
x = fx.getValue();
This would probably be the closest thing to the structured code of your first example and, while doable, isn't in the best style.
The preferred way to do things is to give the Promise/Future a callback function to call with the promised value when the value becomes available:
doSomething().then(x => print("Got X: " + x));
The callback passed to the then()
function will be called and given the value of the Promise/Future that was returned by doSomething()
once it has been resolved (i.e. becomes known).
"But wait!" I hear you say, "this is still using callbacks!"
Yes, it's still using callbacks, but in a cleaner way than just assigning a callback function. The then()
method in this case also returns a Future
for a value of the same type as the return value of the callback function. If this return type happens to be a Future
itself, then the value of that Future
becomes the value of then()
s future, and you can chain these asynchronous callback functions:
Future<Y> doSomethingElse(X) { ... }
Future<Z> doAnotherThing(Y) { ... }
void output(z) { print("Got a Z: " + z) }
doSomething()
.then(x => doSomethingElse(x))
.then(y => doAnotherThing(y))
.then(z => output(z));
The control flow of this asynchronous Promise/Future chain is readily apparent from all the then()
s: doSomething()
, then doSomethingElse()
with the result of the first step, then doAnotherThing()
with that result, then output the final result.
(A side note: Yes, I could have just put method references instead of lambda expressions in the then()
calls (e.g. .then(doSomethingElse)
instead of .then(x => doSomethingElse(x))
, but there are cases where this can lead to issues in some languages.)
Some languages have basic Promises/Futures baked in as part of the language and provide keywords for using it; e.g. C# has async
for declaring an asynchronous method and await
to use when calling that method (result), as a way to wait for and unwrap the promised value:
async Task<X> doSomething() { ... }
X x = await doSomething();
Other languages have flexible-enough type systems and syntax to accommodate this sort of thing via monads; e.g. Haskell with do
-notation:
do
x <- doSomething ()
y <- doSomethingElse x
z <- doAnotherThing y
output z
or F# with its async
"workflow":
async {
let! x = doSomething ()
let! y = doSomethingElse x
let! z = doAnotherThing y
output z
Functional Reactive Programming
In functional programming, loops are abstracted over -- instead of looping over a data structure (like a list or a tree or a set) explicitly, you pass a function that you would like to e.g. be applied to each element of that structure and the abstraction takes care of the looping for you:
List<Int> ints = [1,2,3,4]
List<String> strings = ints.map(i => i.toString());
// strings == ["1", "2", "3", "4"]
There are abstractions for changing every element of a data structure (aka mapping), filtering values from it, reducing the elements to a single value (e.g. doing a sum), etc.
This sort of abstraction can be done to streams too:
InputStream<byte> byteStream = readFileBytes(path);
InputStream<char> charStream = byteSream.map(b => b.toAsciiChar());
printFromStream(charStream);
In this way you can transform streams on-the-go, without having to explicitly consume the whole stream to loop over it.
In Functional Reactive Programming (FRP), an event source can be treated as a stream of values (that forms over time) which can be transformed as time progresses.
Take downloading a file as an example. Suppose the downloader class supported events like:
Progress
to broadcast a change in completion status (e.g. passing the % completed)
Done
to broadcast when the download had completed
Errored
to broadcast when an error had occurred
During the process of downloading a file, the Progress
event would likely be fired multiple times to inform the application of how much of the file had been downloaded. The Done
and Error
events would likely only be emitted once a piece, and only if the other one wasn't, when the file had completed downloading or an error had occurred while downloading.
This gives us three events to listen to, but using FRP we could combine them into a single stream to listen to the progress of our download:
abstract class Status
int getPercentDone() { return 0; }
bool isDone() { return false; }
byte[] getValue() { return null; }
bool errored() { return false; }
Error getError() { return null; }
class ProgressStatus extends Status
private int progress;
ProgressStatus(int progress) { this.progress = progress; }
@Override
int getPercentDone() { return this.progress; }
class DoneStatus extends ProgressStatus
private byte[] value;
DoneStatus(byte[] value)
super(100);
this.value = value;
@Override
bool isDone() { return true; }
@Override
byte[] getValue() { return this.value; }
class ErrorStatus extends Status
private Error error;
ErrorStatus(Error error) { this.error = error; }
@Override
bool errored() { return true; }
@Override
Error getError() { return this.error; }
Downloader downloader = new Downloader();
EventStream<Status> progressStream =
downloader.Progress.map(percent => new ProgressStatus(percent));
EventStream<Status> doneStream =
downloader.Done.map(payload => new DoneStatus(payload));
EventStream<Status> errorStream =
downloader.Errored.map(error => new ErrorStatus(error));
EventStream<Status> compositeStream =
EventStream.merge([progressStream, doneStream, errorStream]);
downloader.download(url);
Once everything is setup, you can listen to compositeStream
to get a comprehensive view of the download's progress over time using a single callback.
State Machines
I've used state machines many times to control event-driven systems; I'll just quickly give a template that I've found handy for dealing with simple machines in code:
class StateMachine
private StateEnum currentState;
void transition(input)
StateEnum nextState = getNextState(currentState, input);
output(currentState, nextState, input);
currentState = nextState;
StateEnum getNextState(currentState, input)
// determine the next state given the current state and input
void output(previousState, nextState, input)
// generate output for the transition
This template breaks up the different parts of operation orthogonally into separate methods making for nice coding and debugging. For more complex machines (e.g. with nesting) you'll probably want something like UML State Machines.
Actors
I'll only briefly touch on Actors since I don't think they're what you're looking for.
An Actor is, in essence, a thread coupled with a message queue. The thread reads a message from its queue, performs some action, then loops to read the next message. Actors send each other messages by enqueuing them in each others' queues.
This may sound like a very simple mechanism, and it is, but it's a nice way to split responsibilities or distribute operations. There are many popular libraries for utilizing Actors in different languages, and the Erlang programming language was designed around this concept.
