Using C++ I'd like to do something along the lines of:
- Try to get a reference to something in, say, a map
- If it throws, then return straight away
- Otherwise, go and use the reference
However because we can't declare a reference object without initialising in C++, then we can't do this directly.
For example if I was happy to pass by value, I could do:
std::map<char, int> mymap {...};
int x;
try {
x = m.at('a');
} catch (out_of_range& e) {
return;
// do something with x
However because I need a reference, I would have to do the following which won't compile.
int& x;
try {
x = m.at('a');
return;
So the options I can see are (1), use a pointer, which I'd like to avoid, or (2), use a different map method which results in more verbose code, such as:
auto x_it = m.find('a');
if (x_it == m.end()) {
return;
int& x = x_it->second;
Are those the only options or, is there another way of doing this neatly?
