The C++ wrapper of JNI is easy to use, and its object orientation is well designed. I personally find it makes the relationship between the JNI objects somewhat more visible and understandable than in the C interface (see examples here) .
As you pointed out, if you're doing heavy C++ work to call some Java functionality, you could elaborate a little more the design and use constructors/destructors to automate some tasks that you would have to manually code in C.
However if you're doing the things the other way round, calling native C/C++ functions from Java, C++ won't bring you a big benefit: this calling interface is really designed for calling C functions (or static C++ functions with exposed as "C"). So if you want to use C++ classes, you have to organise the link between the static world and the objects that you create on C++ side.
Both can of course perfectly interoperate.
