As an example, lets say I am working on creating an eCommerce solution. Part of the functionality of this solution will be to ensure that the final price of an order is correct. Lets say the final price will include the grand total of all products, the shipping costs and any tax.
Lets say I have two public methods:
* @return array
public function viewAllOrders(){};
* @return array
public function viewOrder($guid){};
Each method returns (amongst other things) the grand total of an order.
The problem I have run into is that because each of these methods is tested in separate tests, the tests could have different definitions on what the grand total should be.
For example, lets say for an order 'A' the product price is $100, shipping $10, tax $20 giving grand total $130.
A developer is writing the test for viewAllOrders
. He writes the test correctly, and asserts that for order 'A' the grand total is $130.
Another developer writes the test for viewOrder
. He thinks that grand total is just the price for the products, and forgets about tax and shipping. He now asserts that for order 'A' the grand total is $100.
Both developers write production code that ensures all the tests pass, but we now have a situation where order 'A' has a different grand total depending on the public method that you call! Errors have crept into our system (even though all tests are passing) because two tests disagree on the definition of grand total.
What are some good ways to ensure that we don't use different definitions of functionality across our tests?
I am adopting 'Classical/Statist' testing over mocking. The reason being is I'm using a dynamic language. See Are mocks in dynamic languages dangerous?. This means I cant just simply have a grandTotal() method that the other classes call and can then be mocked in tests.
I have also considered testing each method in the same test (thus ensuring the definition of grand total stays in one test). The problem with this is that you open yourself up to Assertion Roulette.
Also note I have trivialise this example. Most people do know what grand total is, but my problem is a general one, being explained with a simplified example. When you read 'grand total' this could equally be read as 'some value with definite meaning'
