Here's the problem I'm trying to solve:
There's a rather large API I'm trying to write a wrapper class around. The simplest approach would be to make one class with a method representing each possible API call. This gets unwieldly though as the API is very large.
My first thought is to break up each API section into a separate class. If this was the Github API I might have a class for the users API and a class for the repositories API etc. However I want the final interface to be accessible from one namespace like so (this is in Python):
from my_api import APIClient
api = APIClient(api_token)
api.users_api_call()
api.repositories_api_call()
How should I achieve this? At first multiple inheritance seemed like a good option, but I'm unsure how to access things like an API token and other general properties/functions in the specialized classes, furthermore conventional wisdom suggests that MI is a poor design choice. What are some approaches to consider here?
Spencer Wood
  • 123
  • related (possibly a duplicate): [Is it always a good idea to divide large classes into smaller ones?](http://programmers.stackexchange.com/questions/280305/is-it-always-a-good-idea-to-divide-large-classes-into-smaller-ones) – gnat Jul 27 '16 at 16:22
  • Thanks for the link, I'll take a look. I would really like to split this up because it's a pain to work with at the length it's at. However maybe I'm overcomplicating and should keep it as is. – Spencer Wood Jul 27 '16 at 16:23
  • Your example code still looks like it's accessing one class. Why doesn't it look more like `api.repositories.api_call()`? – Robert Harvey Jul 27 '16 at 16:24
  • >However, I want the final interface to be accessible from one namespace – Spencer Wood Jul 27 '16 at 16:25
  • I'm treating `repositories` as a class, though I suspect you have several repositories as well. Each one probably needs its own class. – Robert Harvey Jul 27 '16 at 16:27
  • I realize each one needs it own class, the question is asking how I can avoid calling the functions like baseclass.subclass.method and instead just do baseclass.method. – Spencer Wood Jul 27 '16 at 16:31
  • That puts you back into "single giant class" territory. So you have to decide if you want the big class or the big method names. – Robert Harvey Jul 27 '16 at 16:57
    What language are you using? – Tulains Córdova Jul 27 '16 at 17:00
  • @TulainsCórdova I am using python – Spencer Wood Jul 27 '16 at 17:45
  • You could have two wrappers, one broken down into logical classes, and one bundled into a single big class. Depending on what's easier for you, pick which one delegates to the other. If the programmers using it end up preferring one to the other, you can deprecate and remove the unused one. – Andrew Jul 27 '16 at 19:04
This sis quite common, at least in APIs I deal with.
First, you should create a class for each logical component of your API: users, transactions, tweets, etc etc. I recommend putting a good amount of thought into this. Clear organization is instrumental to a usable API. You should make all these classes publicly available, so users can import these components individually.
If you decide you really must have a single class to handle all API requests, just create a wrapper class API (choose a better name of course) that will hold handles to all of your other classes. Then you can do:
my_api = API(api_token)
my_api.users.get_users()
If you want to go a step further, you can even create forwarding methods such as
def get_users():
    users.get_users()
so your users can save some keystrokes.
gardenhead
  • 4,719
Since this is python specific, you can have the best of both worlds: a package which splits your API in manageable pieces, and avoids the god-object and have a single import. The solution? Python packages have typically an init.py file, which can be used how the package imports things and presents them to the outside world.
Example:
package\
__init__.py
moduleA.py
moduleB.py
in __ init__.py:
__all__ = [ 'moduleA', 'moduleB']
now you should be able to import them directly using import package.
See this post for additional information: https://stackoverflow.com/questions/1944569/how-do-i-write-good-correct-package-init-py-files
Christian Sauer
  • 1,269
What you are trying to do is the Facade pattern, but by trying to wrap all of a giant API you are incurring in the God Object antipattern.
God objects violates Single responsbility principle and interface segregation principle and make it hard to comply with Open/Closed principle.
I don't know what language you are using but some languages support packages (a kind of namespace) so you can import several classes at once:
import com.apifacade.*;
My advice is that you model different classes with specific concerns like in the example you give: User, RepositoryList, Repository, etc. That way you will have less dependency problems.
Tulains Córdova
  • 39,201
  • 154
    You're throwing around a lot of "laws" here, but at the end of the day, it's *just a façade,* so the problem amounts to "what is convenient, both for the end user and the programmer." – Robert Harvey Jul 27 '16 at 17:30
  • @RobertHarvey Not laws but principles. Principles are not mandatory. Those principles ammount to more maintainable code, which is convenient for both end users and programmers. – Tulains Córdova Jul 27 '16 at 17:34
  • The thing is, for the end user I want it to be a god object of sorts. I want them to instantiate my API class, and be able to make any API call that they want to on that object. – Spencer Wood Jul 27 '16 at 17:48
    @SpencerWood You might be right that "any API call from that object" is desirable to your users, but I rather doubt it. Often two or three objects will get you a good amount of conceptual segregation without forcing the user to grapple with a 20 object API. Finding a sweet spot is tricky, Think of the old ADO API. You could do almost anything you needed to with only "Connection" and "Recordset". – Mike Jul 27 '16 at 18:06
