Can I use R via RDOTNET without having to provide the source code of my application.
R is covered under GNU GPLv3.
RDOTNET is under New BSD.
From the RDOTNET description:
"R.NET enables the .NET Framework to interoperate with the R statistical language in the same process. R.NET works on Windows, Linux and MacOS."
I use R via RDOTNET in my application. I run a few commands get the output and display it to the user. I am not modifying the R code in any way.
Does my application have to be distributed under GPLv3?
What
1) if the user installs R themselves, in which case we only distribute R.NET
2) if we provide the R files as part of our distribution
If I do have to provide the source for my entire application in either case. Can I wrap the calls to R in a library and open source just that library and use that library in my program?
cheedep
  • 133
It depends on whether or not you're creating a derived work and triggering the copyleft provision.
In general, for your program to not trigger copyleft, it must either be a separate work, or not be distributed. To qualify as a separate work, it must:
  1. Communicate with the GPL'd software at arms length, and
  2. Not be dependent on the GPL'd software for all or a substantial portion of its proper functioning.
Here comes the important part.
Communicating with the GPL'd software through a third-party interface doesn't change the nature of the relationship between the two programs. In particular, communicating through a third-party interface doesn't automatically confer arms-length communication, nor does it change the essential relationship between the program and its GPL'd component, in terms of its proper functioning.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
  • Microsoft provides R services in SQL server and provides just the source code for R base packages and not for SQL server. I guess that would fall under your second point. But would it mean all applications using SQL server have to do the same as well? – cheedep Jul 15 '16 at 22:37
  • I seriously doubt that Microsoft deals with GPL'd code in any way, shape or form. If they provide R services in SQL Server, they almost certainly wrote their own code to do that. – Robert Harvey Jul 15 '16 at 23:44
  • "Microsoft R Open, formerly known as Revolution R Open (RRO), is the enhanced distribution of R from Microsoft Corporation. The current release, Microsoft R Open 3.2.5, is based the statistical language R-3.2.5 and includes additional capabilities for improved performance, reproducibility and platform support." This is from the Microsoft R site. – cheedep Jul 16 '16 at 03:00
  • Seems it is GPL after all: https://mran.revolutionanalytics.com/faq/#mro-eula – Robert Harvey Jul 16 '16 at 04:19
