I'm working on a component where I put in data and I get different data as a result. The input is always the same (3 Objects). From these 3 Objects up to 9 other Objects can be calculated. One calculation for each output Object is performed. Before the output data is calculated I want to set which of the 9 Objects shall be calculated.
- Set input data
- Set which output data shall be calculated
- Get Output data
I'm working in Visual C++ (C99). At the moment I'm facing a bit of a design problem here. After I set the input data, I am using a bit mask to configure which output data is supposed to be calculated.
const int foo1 = 1; //000000001
const int foo2 = 2; //000000010
const int foo3 = 4; //000000100
const int foo4 = 8; //000001000
const int foo5 = 16; //000010000
const int foo6 = 32; //000100000
const int foo7 = 64; //001000000
const int foo8 = 128; //010000000
const int foo9 = 256; //100000000
SetOutput(foo2 | foo4 | foo5 );
The data is held in an array ARRAY[9]
. For those that have been set (foo2, foo4 and foo5) the elements contain valid data after the calculation (ARRAY[2]
, ARRAY[4]
, ARRAY[5]
I then want to get the the resulting data.
GetData(foo2);
GetData(foo4);
GetData(foo5);
My problem is how do I get the element index from the mask values foo2 = 2
, foo4 = 8
or for example foo5 = 16
The only possibility would be taking log2(n)
and get 2
, 3
and 4
, which would be the correct element indexes of ARRAY
Is there a simpler way than this? I thought about using a map instead, with the mask value (1,2,4,8...256) as key field and the calculated data in the value field. But would prefer to keep the static array. Thanks in advance!
