I'm looking at the alternative that can substitute the use of eval()
and new Function()
javascript techniques. I'm developing a solution build with javascript and the platform on which it is built (Salesforce) recently has announced they're introducing CSP (content security policy) that will block the use of eval()
, and other unsafe functions.
My solution is using eval function to evaluate string expressions and do some other magic stuff. I'm looking for some alternative, ideally without writing my own parser.
As I have mentioned, I use eval to evaluate expressions. Expressions that should be to be supported are usually like:
- String comparison
eval("'something' == 'something'") // return true
- Calculations
eval("2 + 2 * 3)" // return 8
and||
supporteval("1 == 1 && 'cat' == 'dog'") // return false
- Conditional operators,
- at least ternary
eval("(1 == 2 ? 'dog' : 'cat')") // return "cat"
- full
if-else
would be really great:eval("if(1 == 2) { 'dog' } else if (1 == 3) { 'dog' } else { 'nothing' }") // return "nothing"
- at least ternary
- Some basic
Math
class methods, e.g.:eval("Math.ceil(12.313)"); // return 13
Capabilities that would be really great to have
- Inject variable
new Function("var item = this; item.number = 10;", item); // item is variable defined outside of eval and I want to dynamically modify it within eval()
- Inject function definition
eval("invert('123')") // return 321, invert() is a function defined somewhere else
I'm looking for something that is:
- Relatively close to Javascript syntax (but I would accept if it would be some different language that can be interpreted by some js library compliant with CSP)
- Not too much dependent on other libraries
- Can be loaded without node.js etc (standalone js library)
