Background
Thinking about OOP I feel that it binds data and behavior together, taking the real world example we already have array data type which is a collection of homogeneous type and in Java we have build a nice abstraction over it hence, we have methods like clone
which does its job perfectly i.e. we have data and we have associated an operation to it making client code
simple and logic of clone encapsulated behind a nice API.
Hopefully I am correct till now.
Question
So, suppose we need to sort an array, it would be good to have sort
method exposed as the API which does sorting on the array elements whose ordering is based on the element type which seems perfect but wait I see no such methods on Array ADT and here comes the confusion we have page full of documentation here which lists a number of static methods. If I remember properly it is a most hated pattern in TDD community to have static methods because it makes testing a hell, even we ignore their concern then also I see a violation of OOP concept here, we already have data then why not have all these methods in the array itself?
Update
The presence of Array example here doesn't mean that I am confused about the Array in Java, my main concern is regarding the static method in general. Normally I get myself in the situation where I think it would be best to have a static method but many times I have seen community go against it hence there should be a solid reasoning about whether my design is flawed or static method is the best alternative in that situation.
