Let's say I have some library "foo" and I have it listed as dependency of my project. For example in Python I have requirements file saying
foo==1.0
foo library needs "bar" library and it lists it as dependency. At one point I realize "bar" can be useful for my project too, and I have an idea of calling some function of "bar" directly. So I add
import bar
somewhere in my project code.
Should I now add bar library to my project dependencies? If I don't add it my build system will not complain about missing bar because bar is already required and installed by foo. What is recommended practice in case like this?
Pawelmhm
  • 103
  • The day you no longer need `foo`, you'll be thankful you added `bar` to your list of dependencies. After all, it _is_ a dependency. – Vincent Savard Jun 07 '16 at 13:49
  • The day you call a function from bar is the day you add it to your list of dependencies. If you don't need it yet, don't import it. – Snoop Jun 07 '16 at 13:54
It won't hurt.
  • It's explicit. Relying on someone else's dependencies looks a bit like cheating. it works, but it's like you were abusing the dependency tree feature.
  • You may remove foo one day, and be very surprised that your app stopped working for a cryptic dependency reason.
  • You may upgrade foo, and the newer version could be using a new version of bar. it appears that the developers of foo did a great job of migrating their code, but yours still uses the old version of bar. Actually, the new foo may even not use bar at all.
  • foo may use an old version of bar which doesn't have the features you need, so you may be interested in having a dependency to the newer version.
Note that if you actually need to run two different versions of the same package within the same app, you may be in trouble.
Arseni Mourzenko
  • 134,780
  • 343
  • 513
