128
Are different version naming conventions suited to different projects? What do you use and why?
Personally, I prefer a build number in hexadecimal (e.g 11BCF), this should be incremented very regularly. And then for customers a simple 3 digit version number, i.e. 1.1.3.
1.2.3 (11BCF) <- Build number, should correspond with a revision in source control
| | +--- Minor bugs, spelling mistakes, etc.
| +----- Minor features, major bug fixes, etc.
+------- Major version, UX changes, file format changes, etc.
Adam Lear
  • 31,939
  • 101
  • 125
Richard Stelling
  • 2,061
13 Answers13
103
Semantic Versioning deserves a mention here. It is a public specification for a versioning scheme, in the form of [Major].[Minor].[Patch]. The motivation for this scheme is to communicate meaning with the version number.
Josh Correia
  • 107
sourcenouveau
  • 6,460
  • 44
  • Surprised this isn't getting more love. – Mark Canlas Jan 19 '12 at 17:48
  • I was a little late to the party... I added this answer 9 months after the original question. ;-) – sourcenouveau Jan 19 '12 at 19:12
  • Looks like this works out to be the same as the RubyGems Rational Versioning policy that I mentioned below, only better formalized. – Ken Bloom Oct 09 '12 at 23:59
  • @MarkCanlas doesn't get more love because it attaches specific ideas to what constitutes a major/minor/patch release. It talks about APIs which is kinda...weird –  Jul 05 '13 at 16:54
    SemVer is meant for versioning APIs, not user-facing software: "Software using Semantic Versioning MUST declare a public API." So technically, you can't use SemVer without a public API. However, it might make sense to adopt something similar to SemVer for versioning user-facing applications. – Ajedi32 Apr 01 '14 at 16:18
    @Ajedi32 For example if an user-faced software saves files, then the author could declare the file format as their "public api" and version the software accordingly (all ui changes are minor/non-breaking and format changes are major). – beppe9000 Jul 05 '16 at 17:53
50
I tend to follow Jeff Atwood's opinion of the .NET convention of version numbering.
(Major version).(Minor version).(Revision number).(Build number)
More often than not, for personal projects, I find this to be overkill. The few times where I have worked on substantial projects like search engines in C# I've stuck to this convention and have been able to use it as an internal tracker effectively.
Rob Bednark
  • 117
Mike B
  • 1,316
    This tends to follow the pattern I've seen used successfully in many projects, large or small. It is very effective. – luis.espinal Oct 16 '10 at 12:09
    How does/should "build number" relate to "changeset identifier (hash)"? Is it part of the hash, incremental, or something else? – Jace Browning Jul 23 '13 at 13:28
  • @Jace, where I work we use Mercurial, and go off the changeset number. We only ever push to/pull from a single repository, so the number is not unique to the specific checkout. We then have [major].[minor].[changeset] accordingly (though the major and minor numbers are often more marketing than indicative of progress since the last version). – Wai Ha Lee Feb 08 '15 at 21:37
  • If you call ToString() on a .NET Version structure the build will be the 3rd number, not the revision. As you can see with this powershell script: `$version = New-Object System.Version 1, 2, 3, 4; $version.ToString(); $version.Build;` – Joel McBeth Sep 03 '15 at 15:48
    Does "build number" imply that it's just minor tweaks like bug fixes? Should any new functionality at least get its own revision number? – Kyle Delaney Apr 05 '17 at 14:44
    I encourage everyone to actually read the article that Mike B is referring to. Atwood suggests to NOT use the .NET or any numbered versioning and use date-based versioning instead. – Stefan Jan 12 '18 at 20:45
  • For me, it was less than he recommends it, but that I agree with him that it's largely overkill for a basic software package. The same goes for SemVer, although in the seven years since I made this post I'd say I side more with SemVer than in the past. A lot of regularly updated projects (i.e. VSCode) use date-based versioning like Atwood recommends, and that seems to be quite popular now as well. – Mike B Jan 15 '18 at 10:57
34
I don't use it but I have seen and it's an interesting structure:
Year.Month.Day.Build
Self explained.
Maniero
  • 10,826
  • 80
  • 133
    And you always know how fresh is your code..! :) – Lipis Sep 14 '10 at 01:43
  • This is much better, because then I will not have to think about whether the change is major or minor. – Geoffrey Nov 11 '10 at 07:04
  • This is what I've been using on all of my projects recently, and it works well, particularly when you have lots of releases. – Scott Whitlock Nov 13 '10 at 01:11
    this is also similar to Ubuntu's version numbers. They do year.month Examples: 10.04 and 10.10 – Brad Cupit Nov 13 '10 at 02:38
    It's worth mentioning that this only works well for a system which either doesn't have compatibility issues (a website), or inherently always has incompatibility (an ubuntu release). – jkerian Dec 17 '10 at 21:41
    @jkerian, why does compatibility matter for this? – AviD Jan 03 '11 at 10:30
    @AviD: I'm a bit confused about why you're asking this, since nearly every other answer to this question shows version systems that include compatibility information. Your choice depends on what information you want to record with your version numbers. For my purposes, a date has basically no meaning (just starting at v1 and incrementing every build would be an improvement). Do you ever branch? do you ever release "new patch on old code" while releasing "new version"? But for something like a website or operating system, a date-based system seems quite appropriate. – jkerian Jan 03 '11 at 16:28
  • @jkerian now I get it - wasnt thinking about "new patch on old code", was only thinking of the main trunk... Makes sense now, thanks – AviD Jan 03 '11 at 18:37
    One disadvantage of using YYYY.MM.DD is that users know how old your application is, if it's an application not updated frequently. – Gordon Bell Dec 17 '12 at 15:33
  • @jkerian, I can understand how this work for a website, but how is this going to work for OSes? – Pacerier Jan 07 '15 at 07:54
  • @Pacerier: It was a reference to ubuntu's numbering scheme. (which, truthfully, only uses dates as the most significant part of the version number "year-month of initial release") – jkerian Jan 08 '15 at 17:36
  • Not terrible and certainly fine for most cases. What erks me about this is that the only intrinsic value you get from the version number is a release date, which is typically already contained somewhere else, like the changelog. This format doesn't tell you, or your fellow engineers, or your support staff, or your users anything about each release (beside the release date). There's value in knowing if a version is considered a major change or a minor change or just a simple patch release. That's what something like SEMVER provides with `major.minor.patch`. There's intrinsic value there. – Joshua Pinter Apr 03 '21 at 17:39
18
I try to use the RubyGems Rational Versioning policy in which:
  • The Major version number is incremented when binary compatibility is broken
  • The minor version number is incremented when new functionality is added
  • The build number changes for bug fixes.
Ken Bloom
  • 2,384
Here is very fine-grained approach to version numbering:
  • N.x.K, where N and K are integers. Examples: 1.x.0, 5.x.1, 10.x.33. Used for intermediate builds.
  • N.M.K, where N, M and K are integers. Examples: 1.0.0, 5.3.1, 10.22.33. Used for releases.
  • N.x.x, where N is integer. Example: 1.x.x. Used for support branches.
  • N.M.x, where N and M are integers. Example: 1.0.x. Used for release branches.
Here is the picture for simple illustration of version numbering approach:
Agile version numbering
PA means pre-alpha A means alpha B means beta AR means alpha-release BR means beta-release RC means release candidate ST means stable
Advantages of such version numbering approach are following:
  • It represents specifics of agile software development lifecycle.
  • It takes into account specifics of source code repository structure.
  • It is self explaining for those who got used to the patterns. Every pattern represents different artifact. Such patterns can be easily parsed and used for other purposes, such as issue tracking.
  • Versioning patterns set, which basic for the described versioning approach can be used for gathering metrics and planning.
  • It is focused on the concepts of maturity and level of quality. Very often such version numbers as 1.0.0 are assigned without much necessity (when software is in deep alpha). Presented version numbering approach allows to establish several levels of maturity. In the simplest case it will have only two levels: intermediate build (N.x.K) and release (N.M.K). Release means that piece of software with full version number (N.M.K) has gone through some kind of quality management process within the supplier company/organization/team.
  • It is an evidence of agile nature of both development and testing.
  • Encourages modular approach to the software structure and architecture.
There is also more complex diagram representing versioning approach in details. Also you might find useful presentation slides describing transition to the versioning approach. Presentation slides also explain why it is important to stick to the same versioning approach throughout the whole life of the software project.
Personally my attitude towards using date version instead of real version numbers assumes that developers of the software with dated versions:
  • Know nothing about software development lifecycle. Development is usually agile and iterative. Version numbering approach should represent iterative nature of software development process.
  • Do not care about software quality. Quality control and assurance are agile and iterative. Just like development. And version number should be the evidence of agile and iterative nature of both development and quality control/assurance.
  • Do not care about architecture or idea of their application. Major version number (N in N.M.K) is responsible for both architectural solution and underlying principle of the application. Major version number N is to be changed accordingly to the changes in architecture or changes of major ideas and principles of its working/functioning.
  • Do not have control over their codebase. There is probably only one branch (trunk) and it is used for everything. Which personally I do not think is right as it encourages codebase to become one large garbage dump.
This approach might seem a little bit controversial, but I believe this to be most straightforward way of giving software appropriate version numbers.
UPD (Feb-2021): I have also created a web-site https://versioningright.com aiming to explain deeper principles of software versioning that remain hidden behind the scenes.
altern
  • 757
  • First link down............... – Pacerier Jan 08 '15 at 07:11
  • Third links is also down. Also: Is there video to the presentation slides? – Make42 Feb 23 '21 at 00:02
  • @Make42: There is no video unfortunately. But I have been working on the concept a bit and now the most recent developments are described at the https://versioningright.com page – altern Feb 24 '21 at 03:35
  • Thank you! I already found your website. I will have a deeper look. I went through all of your slides and liked them a lot. It seems to me that you extend the (standard) idea that (a) difference in the first version number are non-backwards compatible (you switch the phrasing saying that the older version branch - the support branch - cannot be merged back into the newer version branch), (b) differences in second version number can be merged together (you say that the "release" branch can be merged back) and (c) differences in the third version number just indicate consecutively versions. – Make42 Feb 24 '21 at 16:17
  • Two extensions that I see are: 1. That you see it from a perspective of merging instead of compatibility - but these two views are a one-to-one mapable. 2. You give branches themselves a versioning scheme by introducing the "x". A third extension is less about version numbers but more about the branches: 3. You introduce the branches PA, A, B, AR, BR, RC, ST. It seems to me that none of these extensions is new by itself but the way you bring them all into a framework is the (excellent) contribution. Did I get this right? – Make42 Feb 24 '21 at 16:21
  • Where did you give (if you did) the presentation of the slides "Agile Software Configuration Management"? – Make42 Feb 26 '21 at 10:11
  • @Make42: it was an internal company training on configuration management. There is another similar slide deck in my slideshare profile though, which I presented at the AgileBaseCamp conference – altern Feb 27 '21 at 11:06
  • Did I get the things right in my last two comments? – Make42 Feb 27 '21 at 11:30
  • You got everything mostly right. Only thing I would correct is that PA, A, B, AR, BR, RC, ST are not branches, but rather "directions for tags" as long as they accept read-only snapshots, not always editable branches. – altern Feb 28 '21 at 12:06
  • The website seems to be down. – Make42 Oct 07 '22 at 10:13
For every major version you release, it's not uncommon to have a working version you call it internally. For instance, at my last job, we referred to a major version with the following Ubuntu-inspired naming convention:
[sickly condition] [alliterative animal name]
Which gave such names as "Limp Lamprey", "Wounded Wombat" and "Asthmatic Anteater".
Make sure unless it's a truly cool name that it doesn't leak to your customers.
Jesse C. Slicer
  • 6,002
  • 32
  • 44
    Seems like an inefficient use of time and energy............. – Pacerier Jan 08 '15 at 07:16
    So was leaving that comment, but it didn't stop you. – Jesse C. Slicer Jan 08 '15 at 12:46
  • It's a whole magnitude less...... – Pacerier Jan 08 '15 at 15:08
  • I agree with @Pacerier generally, but there can definitely be some "fun" to be had with naming major releases. However, my recommendation would be to name it something less insulting and something more inspiring. At least make it so that if the customer does find out, it instills **confidence**, not the lack thereof. For example, we are space nerds at CNTRAL so we named major releases after the up and coming SpaceX ships, like `Falcon Heavy` and `Starship`, etc. Was a nice way to look to the stars while looking at semi-colons and brackets all day. – Joshua Pinter Apr 03 '21 at 17:44
git describe provides a nice extension to whatever numbering convention you've chosen. It's easy enough to embed this in your build/packaging/deployment process.
Suppose you name your tagged release versions A.B.C (major.minor.maintenance). git describe on a given commit will find the most recent tagged ancestor of the commit, then tack on the number of commits since then, and the abbreviated SHA1 of the commit:
1.2.3-164-g6f10c
If you're actually at one of the versions, of course, you'll just get the tag (1.2.3).
This has the nice benefit of letting you know exactly what source you built from, while not having to number every single build yourself.
Cascabel
  • 172
Generation.Version.Revision.Build (9.99.999.9999)
Generation rarely changes. Only a big turn on product: DOS -> Windows, complete reengineering.
Version is for big incompatible changes, new functionality, changes on some specific paradigms on software, etc.
Revision is often done (minor features and bug fix).
Build is internal information.
Maniero
  • 10,826
  • 80
  • 133
Version numbers should have enough information that you avoid conflicts and fixing a bug in the wrong release type problems, but shouldn't convey additional information that isn't relevant.
For instance if you use the date customers can tell that they have an older version, and patches against old versions can have confusing versions.
I personally like semantic versioning:
  • Releases are Major.Minor.Patch
  • Patch increments every time you release a build.
  • Minor increments every time backwards compatible functionality is added.
  • Major increments when new functionality is not backwards compatible.
  • When Major == 0 you're in alpha/pre-release. Major >= 1 are your public releases.
  • Lower numbers reset to 0 every time you increment, so
    1.5.3 -> 1.5.4 (bug fix) -> 1.6.0 (minor feature) -> 2.0.0 (breaking change)
This way if someone is using, say, version 1.5.3 they could tell at a glance that they could upgrade to 1.5.4 to get the patches, that 1.6.0 would add functionality and that they shouldn't upgrade to 2.0.0 (at least without handling the change).
Keith
  • 854
I prefer version numbers that assign some semantic meaning. As long as you can use the version number to track bugs reported with a particular version to changes that occurred in the source code (and in your activity management system) then you're probably using the right method.
I use .NET so I'm stuck with the .NET version numbering system but I try to give semantic meaning to the numbers so with
major.minor.build.revision
  • major = (up to the project)
  • minor = (up to the project)
  • build = build number from Hudson (you could use TeamCity or TeamBuild, etc. here)
  • revision = subversion or bazaar revision (depending on the project and what its using)
We always make sure thatt he version number is visible in some way (with our batch console-based programs its printed to console and a log file, with web apps its on the menu bar at the top usually)
This way if clients report problems we can use the version number to track if they are using the latest version and how many problems we have had with particular versions.
It's all about traceability!
Jeffrey Cameron
  • 355
Major.Minor.Public (build) [alpha/beta/trial], such as "4.08c (1290)"
  • With Major being the major version number (1, 2, 3...)
  • Minor being a 2 digit minor version (01, 02, 03...). Typically the tens digit is incremented when significant new functionality is added, the ones for bug fixes only.
  • Public being the public release of the build (a, b, c, d, e), which is often different from the minor version if a minor version is never released as a public update
  • build, being the actual build number that the compiler keeps track of.
  • with TRIAL, ALPHA, BETA X, or RC X appended for those special cases.
GrandmasterB
  • 37,990
  • 78
  • 131
We use Major.Minor.Build#.YYMMDD[suffix], as we usually only do one production build on any particular day (but use a b/c/d suffix if there's more than one) and the YYMMDD gives users/customers/management an indication of the age of the build, where 6.3.1389 does not.
Major numbers increase with significant product features (paid-for).
Minor numbers increase with fixes/improvements (free update).
Build always increases; not all builds ship, so it's not a linear progression.
JBRWilkinson
  • 6,759
              1.0.1
(public 1.0)  1.0.2-----
              2.0.0    1.1.0
              2.0.1    1.1.1 (public 1.1)
(public 2.0)  2.0.2-----
              3.0.0    2.1.0
                       2.1.1 (public 2.1)
                       2.2.0
                       2.2.1
X.Y.Z is our internal version number. X.Y is the public version number, the one that has a meaning to our clients. When a X.Y.Z version becomes public, there will never be a X.Y.(Z+1) version : the public version is always the last of the serie.
X is incremented when a major version is released.
Y is used for the maintenance branches of those major releases, only for bug fixes.
Z is used internally, and has no fixed meaning. Until now, I create a new Z version when I think that the application has a set of features that are interesting to show to non developers, and is relatively stable. This way, I can show a demo of the "last known good version" of the application when someone ask one. In a near future, I plan to use the Z number versions for naming a "target" of features, in our bugtracker.
As a side note, we use maven (with the release command) to increment the version number. So, there are X.Y.Z-SNAPSHOT versions, too (which indicates any version between X.Y.(Z-1) and X.Y.Z).
barjak
  • 1,720
