12
I'm creating a point of sale system for a small shop. I am particularly interested in finding patters from all items purchased, which I will log in their entirety. I'm thinking of even making queries on things like temperature to sales of specific categories of products.
Should I use a plain text based database such as CSV, or go for SQLite?
What are some examples of situations where a plain text database is often used?
gnat
  • 21,442
  • 112
  • 288
infinite-etcetera
  • 237
    Use a database for local storage and upload to a datawarehouse for your BI queries – Ewan May 30 '16 at 22:28
    The answer is almost certainly a database, not a CSV file. Use a database. – Robert Harvey May 30 '16 at 23:54
    Seriously, or as a hobby project? There's no way you can build this for less than it would cost to purchase a solution. – kevin cline May 31 '16 at 03:37
  • it's a bit of both. it's something i need to learn to begin with, so i am prepared to build it mostly from scratch – infinite-etcetera May 31 '16 at 10:22
    You're a beginner. As a learning exercise, try writing a prototype using each. Then make your own decision. There are dozens more options, by the way, in the NoSQL sphere. – slim May 31 '16 at 11:03
This (Queries) is one area relational databases are designed for. You are better off with a database with SQL support.
Low Flying Pelican
  • 1,602
  • Not that SQL is actually relational. [It isn't.](https://www.safaribooksonline.com/library/view/sql-and-relational/9781491941164/) And SQLite is particularly non-relational with its lack of strong typing. – Wildcard Jan 22 '17 at 14:32
    @Wildcard, If one can say one feature of SQL databases it is that they ARE relational. Strong typing has nothing to do with "relational database" concept. – Andrzej Martyna Apr 20 '18 at 10:33
I asked the same question years ago and actually built the app both ways. The build-my-own database version was a lot of fun, but it was a toy. Using a real database enabled a commercial product that performs well under stress.
SQL Database
  • SQL lets you write one-liners for most of the kinds of reports you are talking about - one-liners that other programmers will recognize.
  • There are all kinds of tools written for databases: backup, sharding, replication, pre-built docker containers...
  • You can fairly easily migrate to a different database (PostgreSQL, MySQL, etc.) if you change your mind.
  • Most databases have Transactions so that when someone purchases an item, and that adjusts both the money in their account and the stock of the item, the database either takes both adjustments or neither. It simply cannot store half of a transaction and leave you with broken data.
  • Other programmers will immediately recognize what you are doing
  • To get the same performance out of text files or some made-up binary format, you're going to have to implement some serious data structures. If you don't know what a B-Tree is, or want to spend weeks optimizing it, you'll never compete with the speed of a database.
  • Someone else is developing the database, so even when you don't work on it, when you apply upgrades, you get the advantage of their work.
  • You didn't say what language, but there are ORM's written for every database. I used to use Hibernate, but the learning curve is steep and I've been having good luck with eBean lately. Sub-point: If you have any loops in the data structure you are saving (users are last-updated by other users), the ORM takes care of not going into a tail-spin re-saving the looped objects.
  • Most databases allow constraints of some kind to prevent bad data from ever being entered. You can set it to fail of someone tries to enter a customer without a last name, or an order without an amount, or if the user isn't associated with a company.
Home-Grown Database
  • You probably don't need to learn someone else's ORM (Object-Relational Mapping Software)
  • You will learn a lot about the algorithms behind databases and the difficulties in implementing them.
I run mysql-backup daily on production and a few times over the years. I've had to do a few restores. The data never gets splinched, half-way between one update and another. Our hosting provider automatically runs these backups for no extra charge.
Finally, SQL databases today are largely commodities. You can do the same basic stuff with PostgreSQL, MySQL, SQLite, SQL-Server, and Oracle. Sure, each has some special thing that the other's don't do, but in general, you don't need that thing. They have reached that point because so many people have used them so many different ways for 40 years now.
Other Options
No-SQL Database
Products like CouchDB are ideally suited for blogs, wiki's, email, and chat software, where the base unit of the app is a document of some kind. SQL-databases are more suited for little pieces of data that have lots of relationships, like products, orders, and inventory.
Key-Value Stores
Products like Redis.io are great when the relationship between items is more important than the items themselves. It's like a big dictionary where you pop in a word, and get back a definition.
Datomic
Has some aspects of a key/value store and some of a SQL database (generally uses a SQL database on the back end). This mostly competes with a SQL database, but you'd pick Datomic when keeping a history is almost more important than keeping the data itself.
Flat Files
Images, videos, and audio files don't belong in a SQL database (thought they might in a no-SQL-document-store). Some other kinds of files or data (like HTML) generally don't either. Keep these things in a folder or folders and when something in the database relates to them, store the file-name in the database.
GlenPeterson
  • 14,890
  • 47
  • 75
    It's not true, in general, for all kinds of 'flat files', that they shouldn't (ever) be stored in a SQL database. Like all things, there are definite tradeoffs involved, but lots of SQL database systems are more than capable of storing flat files in 'BLOB columns' in tables which provides lots of obvious advantages (e.g. referential integrity, simpler data access). I'd probably avoid storing video and audio files generally, but images, HTML, and other data files, particularly fairly small (less than a couple of megabytes) ones, are almost certainly fine stored in the database. But test it! – Kenny Evitt Dec 09 '16 at 19:54
