I have an application that I want to be MIT and I have a roo gem in my Gemfile (roo is licensed under MIT) however it depends on spreadsheet that has GNU license. Am I allowed to use roo and have MIT licence?
    Can you be more specific with your question? Otherwise, the answer is "because those were the licenses the license holders decided to choose." – Robert Harvey May 30 '16 at 19:02
  • Did my best =) I apollogise is this is still confusing – Bohdan Pohorilets May 30 '16 at 19:06
  • Are you saying that roo depends on a GPL spreadsheet, or your application? It's unclear from your question. – David Arno May 30 '16 at 20:57
  • @DavidArno roo depends on a GPL spreadsheet – Bohdan Pohorilets May 31 '16 at 03:26
    The short answer is this: *so long as you don't close the source, the MIT license is compatible with the GPL.* See the FSF site for more information. – Robert Harvey May 31 '16 at 06:16
  • @RobertHarvey, do you have a link? I thought the GPL virus was unstoppable: if you depend on GPL, then your code too must be GPL. Didn't realise that you can keep it at bay by using MIT. – David Arno May 31 '16 at 08:04
    [This question](http://stackoverflow.com/questions/3902754/mit-vs-gpl-license) suggests that @RobertHarvey's comment isn't correct. Whilst MIT is compatible with the GPL, your overall application must be GPL'ed if you use any GPL libraries within it. So whilst roo can be MIT-licensed, your app can't be as roo depends on a GPL-licensed component. – David Arno May 31 '16 at 13:02
The MIT license is compatible with the GNU GPL. You can use MIT libraries in your projects, so long as you continue to abide by the GPL's terms.
However, the MIT terms only apply to the MIT library in isolation. If, for example, you want to close your source, you cannot do it if you use any GPL'd code in your project. The copyleft provision of the GPL takes precedence over the "use it however you like" terms of MIT.
So even though you're using MIT code that is compatible with the GPL, you still must abide by the responsibilities of the GPL.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
