13
I'm writing an application for learning foreign words of exactly one language (english at the moment), which has currently an ineffective design.
I use Java and SQLite-jdbc for saving the words. After starting, the application downloads a comma separated wordlist and inserts each value pair into the Database. I hosted the wordlist on an extra github repository, because i thought I shouldn't store the database file inside the development git repository - its binary, so everytime I do sth with the database, the hash of the database file will change. I don't like that, because then Id have to create unreadable commit messages, and the actual change to the database would be hard to understand.
Therefore my actual question: Is there a more elegant solution of saving the DB file than saving it inside the git repo? Should I simply store the current database file on another filehost? What are the best practices for such a situation?
toogley
  • 846
Store the words using a text format, and build a database during the build.
Instead of storing the information in binary format and storing the binary file in the version control, keep the pairs in a CSV file. This allows you to easily change it, commit the changes and, later, diff the changes with ease.
Later, when you actually need this data in a database, do a bulk insert from the CSV file. This can be done during a build or deployment. By the way, SQLite has a feature which makes it possible (and more importantly fast) to import data from CSV files.
JGC
  • 103
Arseni Mourzenko
  • 134,780
  • 343
  • 513
