Two of the top 3 security vulnerabilities in the OWASP Top 10 come from trusting user input (Injection and XSS). To deal with this, Ruby lets you "taint" Strings received from the user as unsafe.
In a type-safe language like Kotlin you can (theoretically) take this one step further with a Tainted
class that wraps a String
, but is not extended from CharSequence
. Then everywhere you write your (for example) HTML output, you have to run all your Tainted objects through an escapeHtml(Tainted t)
, escapeSql(Tainted t)
, or escapeUrl(Tainted t)
, or you get a compile error.
I can make a Tainted
class in Kotlin too, but Kotlin's String Templates assume that every class has a toString()
method and make no complaint when writing these Tainted
objects out in strings, thus defeating most of the purpose of a tainted class.
Is there a way I can generate a compile-time error in Kotlin when I do this:
val t = Tainted("Robert'); DROP TABLE STUDENTS; --")
return "SELECT * FROM STUDENTS WHERE NAME IN ($t);"
If there was a way to exclude a class from working inside a String Template (and StringBuilder) that would do it. Or a compiler setting to raise an error when using a certain class or classes in them? I'm just wondering if anyone has found a way to do this effectively in Kotlin.
Without this, there could still be a benefit of using a Tainted class to "Make Wrong Look Wrong", even if the IDE and compiler can only detect some and not all encoding errors.
