I am creating a new site and will base it on ASP.NET MVC 5 & Dapper Contrib. I want to go all in with all these technologies - and get all the time saving / convention over configuration / terse code advantages available.
I am designing the database in SQL Server 2014. Historically I have always named primary keys TableId rather than "Id".
CREATE TABLE User (
    UserId int IDENTITY(1,1) NOT NULL,
    Username VARCHAR(50),
    FirstName VARCHAR(50),
    LastName VARCHAR(50)
Rather than...
CREATE TABLE User (
This avoids ambiguity in some SQL - and avoids joining primary key fields to foreign keys with a different name. Good for clarity.
However - and I think Ruby on Rails Active Record started this - ORMs such as Dapper Contrib require less configuration if the Id of a table / model is called "Id". To me this is an indication of best practice and is to be encouraged.
This is Dapper Contrib having an opinion and recommending a best practice.
Having said that very few example sites or code I have found (beyond dapper documentation) - using Dapper or not - use "Id" - most use "TableID".
Are there advantages beyond not having to add the [Key] attribute to the "TableID" property of a model to get it to map - and what is "best practice" when doing green field development?
Yes this question has been asked many times - but not with direct relation to ORMs - and not specifically about ASP.NET MVC 5 & Dapper Contrib. These are new(ish) factors.
Or am I just flogging a dead horse here - is it purely personal preference and not that important - even when ORMs are taken into account?
niico
  • 241
Does your DBMS care about which naming convention you use?
  • No
Do you care?
  • You probably do, just like any other human would. Everyone has a preference.
Do your colleagues care?
  • Yes? Consult with them.
Does your ORM care?
  • You should be able to answer this one yourself. I'm not familiar with Dapper but I have experience with Entity Framework, NHibernate and Eloquent and I find it ridiculous for any ORM to force a naming convention.
Does it make ever sense to name a primary key TableNameId instead of Id?
  • Not in my experience. If you do raw SQL queries and are worried about issues when doing joins you should use aliases. In fact, I find it more proper to name primary keys Id since that way I'm forced into the good practice of using aliases!
For me, User.UserId does not make sense. I always name my primary keys Id.
The only factors in this decision should be yours and your colleagues' preferences.
If there's something I missed out you can probably find it in this popular holy debate.
Alternatex
  • 1,033
    Dapper doesn't *force* a convention - it just knows (like Ruby on Rails with Active Record) that Id is a primary key - with other primary keys you obviously have to tell it explicitly. "Convention Over Configuration". "TableNameID" IMHO makes SQL more readable (many agree). Thanks for your input - you make good points. – niico May 28 '16 at 00:55
