My understanding of how ORM persist works:
//ORM "persist" oversimplification
function persist(&$entity)
    $insertId = api_actual_db_insert(...);
    $entity->setId($insertId);
//usage of ORM later ...
$this->getEntityManager()->persist($entity);
print $entity->getId();  //prints ID of newly inserted record
But why not ..
function persist($entity)
    return $insertId;
//later ...
$insertId = $this->getEntityManager()->persist($entity);
Both ways work. My issue is with "references". I can perhaps see a little bit why and what the reasoning is behind why ORMs work this way .., but my question stems from writing my own similar domain specific functionality that I have decided to mimic after the ORM concepts and I am having "issues" with using references. Not technical issues but moral and computer sciency-issues as far as reasoning and rationale for using them in this context.
To be precise, examining Doctrine's own code (my choice of ORM), I did not see an explicit Entity reference being passed, so the mechanics of an ORM may use some other different technique. My question will stand though regardless of the method. What's of interest to me is that Entity is populated with the insert_id, and insert_id is not returned explicitly.
My code
I have a concept of Selection object that contains a lot of stuff. Maybe later it may become a true Entity, but right now it's not (lots of refactoring work to be done before it is ready), so I have to manage it manually, without ORM backing. I wrote my own persist function that is similar and my question is basically what I've already stated above. I may understand why an ORM works this way but I do not understand if I should implement my own storage the same way or not.
Question
To be explicit ... is there any particular or specific reason why an ORM would use this specific technique of populating Entity with insert_id without an explicit return statement, opposed to returning insert_id explicitly via return statement to the caller? If I do choose to return insert_id explicitly, what will I be missing/breaking?
Dennis
  • 8,157
  • 68
  • Because if it didn't you'd have to call `setId` every time you persist something? – user253751 May 25 '16 at 21:03
  • so it's done because "it's more work for the programmer" otherwise, ja? – Dennis May 25 '16 at 21:21
  • Think on id generated manually. What would be the point of returning a value that you manually setted? What if persitence doesn't generate a new id? What would you return? Null? – Laiv May 25 '16 at 21:42
You are running up against the challenges inherent to an ORM. ORM's are by definition leaky abstractions. Martin Fowler has an excellent article addressing your "moral and computer-sciency issues". http://martinfowler.com/bliki/OrmHate.html
The truth is, ORM's are a pain and never feel right, especially for purists. This is because quite simply they are not pure. By definition, they are not a pure abstraction (persisting/syncing data to an external store), but an implementation detail (specifically, persisting/syncing data to some relational data store).
As to your concern "if I should implement my own storage the same way or not", Fowler's basic point is that at some point, in order to program against a database well, you have to realize the relational database is actually part of the domain, and so it must be reflected in the domain model. The sooner you can come to terms with this concept the sooner your path forward will make sense.
With all of that said, it is simply more code to write:
id = perist(entity);
entity.id = id;
print entity.id;
than to write
persist(entity);
print entity.id;
And the second is more clear and more readable. If there is anything you are missing it will be clarity.
Price Jones
  • 635
  • Not to mention in the second case you don't have the risk of forgetting to set the ID which otherwise could be a big pain to debug! And also it leaves you the return value to use for boolean indicating status of the persist operation. – Maurycy May 26 '16 at 11:02
  • thanks. While I think I understand what you mean by, "*The sooner you can come to terms with this concept the sooner your path forward will make sense*". I am also not clear on if you indicate there is something to be cognizant of .. The way I understood it is that database is essentially to be treated as an external variable of sorts, to be used in my own code/model, and hence treated with same respect as any other domain variable. Aka, not to be treated as a foreign concept. But this is all vague, and I'm not clear – Dennis May 26 '16 at 14:19
