You're doing quite a lot in a single class, that being said let's see what we can do.
First lets modify the code so that we can better support OCP. We will do this by introducing a dictionary that will contain your processors and a related interface IFileTypeProcessor.
// not sure what string you intended to return
string Process(FileStream fileStream);
class FileProcessor : IFileProcessor
private readonly IDictionary<string, IFileTypeProcessor> processors;
public FileProcessor(IDictionary<string, IFileTypeProcessor> processors)
this.processors = processors
public string Process(string fileName)
using (FileStream fileStream = new FileStream(fileName, FileMode.Open, FileAccess.Read))
BinaryReader binaryReader = new BinaryReader(fileStream);
string hexString = BinaryFunctions.BytesToHexString(binaryReader.ReadBytes(2));
string result = "";
if(!this.processors.ContainsKey(hexString))
throw new YourApplicationSpecificException();
return this.processors[hexString].Process(fileStream);
Next let's introduce a new class called FirstTwoByteHexKeyProvider that implements a new interface IKeyREader which will then become an additional dependency on the CTOR. We'll also include some guard clauses to help our users because we like them.
interface IKeyReader
string GetKeyAsHexString(FileStream filestream)
class FirstTwoByteHexKeyProvider : IKeyReader
public string GetKeyAsHexString(FileStream fileStream)
if(fileStream)
throw new ArgumentNullException(nameof(fileStream));
return BinaryFunctions.BytesToHexString(binaryReader.ReadBytes(2));
private readonly IKeyReader keyReader;
public FileProcessor(IDictionary<string, IFileTypeProcessor> processors, IKeyReader keyReader)
if(processors == null)
if(keyReader == null)
throw new ArgumentNullException(nameof(keyReader));
this.keyReader = keyReader
string hexString = this.keyReader.GetKeyAsHexString(fileStream);
Now on to dependencies, do you need to support only Ninject? if so it could be as simple as using NinjectModules:
public class FileProcessorNinjectModule : NinjectModule
public override void Load()
Bind<IFileProcessor>().To<FileProcessor>();
Bind<IKeyReader>().To<FirstTwoByteHexKeyProvider>();
Bind<IDictionary<string, IFileTypeProcessor>>().ToMethod(context => new Dictionary<string,IFileTypeProcessor>
["123"] = new FileType1Processor(),
["456"] = new FileType2Processor(),
Once you have the module built tell your customers to use some form of Dynamic Module Loading and Bob's your uncle.
I wrote this quickly here and didn't test it via compiler but I'm sure it'll work with a bit of correction on your part but it should be enough to get you going.
If you have to support more than one form of DI then I'd recommend exposing an interface that will allow the customer to provide their own DI Container to you and your package will then use that to resolve dependencies much the same way that ASP.NET Core does it today.
Lastly you may consider ripping out the action of actually reading the file into another class and making the binary result of this "file read" an argument that get's passed in to your process method instead of the fileName since as it stands this will be a bit of a pain to test.
If you don't want to do that then you at the very least can extract the "new FileStream(..." into an internal virtual function which will give you the ability to MOQ around this system call in unit testing.
Hope that helps...
