I have a fairly complex immutable data type that I'm using a builder object to instantiate. Currently, I have a setup where I parse a file, setting various fields in my builder, and then build the object. However, the files I'm using are error-prone, so I want to do some verification on my unbuilt objects first. And it's important to note that I don't want to throw an exception if an object doesn't pass verification, as that doesn't mean it's invalid, just incorrect.
The way I'm accustomed to seeing builders, though, is that they're "write-only". For example, Guava's ImmutableList.Builder
class does not allow you to view the data you've submitted to it, leading me to use ArrayList
s as a builder on the occasion that I need to edit the data before freezing it.
Alternatively, I suppose I could just go ahead and build my objects with errors in them, then create a new builder pre-loaded with the data of the built object, inspect the data, edit, and rebuild. This seems wasteful and inelegant, though.
Is it considered a code smell to put getter methods on your builder objects? Intuitively, it does seem a little strange to me, but more than once I've been faced with this type of problem, which often prompts me to keep an accessible copy of some of the data I'm passing to the builder so I can look at it later. Simply having a getter would make things easier.
