I am trying to implement DNS-SD, and I understand how it works, but don't really understand the purpose, so I have a few questions about it.
Let us assume that we have two devices on local network, and we registered services both devices provide, how dns-sd really helps us, it just replaces ip:port/path/to/service with some symbolic name? What if we want to use that service in our program, for instance written in C, how we will handle it?
I think google will help you with why you would want to use it https://en.m.wikipedia.org/wiki/Zero-configuration_networking#DNS-SD
This is important if you can not define the path to the service ahea of time. For example if your C program is inside a printer and you want anybody on the network to be able to find the printer without knowing its IP address.
This has nothing to do with C itself but is a way to find things in a network regardless of the language used.
Tereus Scott
  • 296
  • So I will call service browse command and resolve required service with for instance system() function in C? –  May 06 '16 at 10:22
  • @Lazar: Check to see if there is a service discovery library available, then you can use that instead of capturing and parsing the output of `system()`. – TMN May 06 '16 at 17:07
