I have a couple of users who have a User Interface for an application that they must use to do their job. The UI can be cumbersome to navigate to perform some time critical tasks.
This UI does not expose any API and has no integration points.
I would like to be able to do something to help the users to perform various tasks.
I've been looking into the feasibility of using VS2013's coded UI tests to allow me to control the UI from some of my own code which would run on the user PCs. Obviously this is not really what coded UI tests are intended for.
Has anyone else tried this technique to integrate code with a closed UI? How successful were you? Are you aware of any other frameworks which would achieve the same result?
In some more detail (not required reading for question): The UI in question is a market making tool within finance. For simplicity sake, let's say the use of it is enforced by regulation. Currently the users will run a model and then manually type several values into the UI as their bids and offers. This is time consuming and has potential for human error (even with copy and paste). I would like to create an app that took the correct values from the model and posted them into the correct boxes on the screen.
Things I can control:
  • The application they take the values from
  • The integration software
Things I cannot control:
  • Anything to do with the market making UI
Any suggestions or advice much appreciated.
Ken Hung
  • 188
GinjaNinja
  • 350
    You may want to consider [AutoHotKey](https://autohotkey.com/) – JeffO Apr 27 '16 at 20:27
  • Not 100% sure about AutoHotKey but you should make sure you can use window classes to recognize controls. Don't go for timing-based scripting. –  Apr 28 '16 at 06:58
    I used AutoHotKey in the past for automating UIs. For pure scripting, however, [AutoIt](https://www.autoitscript.com) might be better suited. How well this works, however, depends on how stable the UI layout of the controlled application is (from one version to the next). An old list of UI robots is here: https://en.wikipedia.org/wiki/List_of_GUI_testing_tools – Doc Brown Jun 27 '16 at 06:10
  • Can you decompile closed UI and check possible names for controls you need. Usually this kind of finance market software have plugins possibility – Fabio Sep 07 '17 at 02:51
    Is this a web UI or a desktop application? If desktop, any idea what GUI toolkit is used? – whatsisname Mar 06 '18 at 14:57
  • If the use of the app is enforced by regulation, you should double-check whether it's legal to automatically do the things it does. – user253751 Apr 06 '18 at 01:20
  • It is unclear what technology stack you are running on. But if it is Windows then the CBT (Computer based training) API will allow complete control of the application – kiwiron Apr 06 '18 at 09:07
  • @whatsisname sorry - I missed this. It is a desktop app. I do not know the underlying technology. – GinjaNinja Apr 11 '18 at 12:58
  • @GinjaNinja: what does it look like? Does it look like an ordinary windows application? Does it look like a WPF app? If you use Spy++ can you see what makes up the gui widgets? – whatsisname Apr 11 '18 at 18:55
You can probably make it work. But, I find when using coded UI, or other test frameworks you are quite dependent on changing the code to make the various buttons and other elements easy to pick out and interact with.
I think you will find it easier to just buy an off the shelf automation product
Ewan
  • 70,664
  • 76
  • 161
  • bing it! http://www.winautomation.com/macro-recorder/ – Ewan Apr 27 '16 at 22:40
  • Mouse and keyboard recording is not suitable. There are six monitors on a standard traders PC. I need to be able to interacts with individual controls in a closed UI – GinjaNinja Apr 27 '16 at 22:47
  • Essentialy this kind of software does the same thing as coded ui. sends windows interupts to a process. They have just given you a ui to record the actions. You can code it directly into a console app if you want. But its never going to be super reliable if you run it on a users pc where you dont know what windows are open etc – Ewan Apr 27 '16 at 22:53
  • I wrote a couple of console apps to do a similar thing years ago. But you had to run them on a server with the os/desktop etc in a known state. Open two windows with the same name for example and it wouldnt know which to click. Press tab while it was in the middle of its script? Focus changed to the next button and everything goes wrong – Ewan Apr 27 '16 at 22:56
    @Ewan: I would rule out any tools which advertise themselves with "no programming" immediately. – Doc Brown Jun 27 '16 at 06:05
Have you looked into Spock and Selenium? Spock can load pages and selenium can manipulate UI elements. This can be set up for purposes other than testing and should run just fine. Beware, things can get tricky if you have UI elements that need to be activated, then you have to wait for something to load, and then you can proceed. Some creative coding may become necessary when it comes to telling it to wait the required time.
Selenium is not generally loved by most people who have to use it a lot, but it works. It should be possible to set up a script that would run and a sequence of actions in the UI occur.
JBiggs
  • 139
How to programmatically control a GUI application?
I guess that you have written, or at least can modify that GUI application, so have access to (and understanding of) its source code (and the capacity and resources to improve it).
Then you could add some RPC-like service to that application. You could consider adding some JSONRPC, some REST or other Web service, some SOAP, etc...
Adding such service to an existing GUI application is generally easy (since GUI frameworks have some event loop).
If you have no control (and no access to its source code) on the GUI application, in general you cannot control that GUI application programmatically. But depending on the display server (X11, Wayland, etc...), the operating system and the widget toolkit used by it, in some specific -and rare- cases you might control it programmatically (for example, some recent GTK applications using Gobject introspection).
Perhaps the best solution is to go back to the vendor of that GUI application and ask him (and pay him) to develop some programmatical interface (and discuss with him the technical details, e.g. the inter-process communication protocol to use).
If you know the source of the data ("The application they take the values from") and the computation that this GUI is making, you might perhaps consider redeveloping your code doing that computation (Only you could know if that makes sense).
Read also Comparison of GUI testing tools and GUI testing wikipages.
Basile Starynkevitch
  • 32,434
  • 84
  • 125
  • As mentioned in original post, I have no control over the GUI whatsoever. I don't specifically mention it is provided by a thord party. – GinjaNinja Apr 10 '18 at 08:46
    @GinjaNinja: why don't you answer my question? Do you not want to get a useful answer? – whatsisname Apr 10 '18 at 15:48
