Statement
I often find myself still writing the following statement all over my code:
// TODO: (the work that needs done)
I do this in order to flag that I need to come back and do something later on. It often happens when the functionality of the code is dictated by other code that will be written later on. I did a quick Google search and took the first two results about this...
The first result I found explains that this is a valid way of doing things, and is the first result that shows up in Google:
How do you flag code...
Then, another result I found suggested something about that a Task List could be used as an alternative...
Creating Task Lists with Visual Studio...
The problem I have with both of these is that they are both 7+ years old, and I am exploring what has changed between now and then.
Question
Is writing TODO, still a valid way of doing things?
Snoop
  • 2,718
  • 52
    Do you have a way of efficiently revisiting those places? If yes, then it's a workable solution. For instance, Eclipse automatically adds lines marked like this into its task list - it doesn't get any more automatic than that. – Kilian Foth Apr 26 '16 at 12:46
  • I've been doing that lately. We'll see how it turns out. :) – MetalMikester Apr 26 '16 at 12:48
  • @MetalMikester Yeah, it seems as though either doing it this way, or by TDD would be good ways to track what needs done next. – Snoop Apr 26 '16 at 12:51
    Something that I've seen used to great effect is gated check-ins looking for TODO code. If it finds the phrase in a comment, source control won't allow check-ins. It's a good way to make sure you don't accidentally check in testing code. – mgw854 Apr 26 '16 at 12:51
  • @mgw854 Never heard of that, so the VCS actually looks for the TODO and won't allow check-in? That gives me the incentive to keep doing it this way. – Snoop Apr 26 '16 at 12:52
  • @StevieV It's something custom we wrote to hook into the VCS, but yes. – mgw854 Apr 26 '16 at 12:53
  • @mgw854 Do you have some server or something that looks at it when a check-in is requested? – Snoop Apr 26 '16 at 12:54
  • @StevieV It's a plugin to the VCS solution on the VCS server. It will differ based on your VCS of choice, but most offer a way to hook in to the check-in pipeline (hence why they're often called "hooks"). – mgw854 Apr 26 '16 at 12:59
  • @mgw854 Thanks that's helpful, will look into hooks at some point then. – Snoop Apr 26 '16 at 13:04
  • this topic has been beated to death in [Do TODO comments make sense?](http://programmers.stackexchange.com/questions/125320/do-todo-comments-make-sense) – gnat Apr 26 '16 at 13:28
If you are into TDD, I suggest you write up a test which will fail until the functionality gets implemented.
The only downside I can see is if you are a somewhat lazy function such failing tests will contribute a lot of noise to runs and may hide actual failures behind all that.
    That's really not a bad idea. Until the other day I didn't know what TDD actually was, but yeah I started writing the tests then defining library functions later that would adhere to those tests. I guess I could do the same thing for my application code where I would need to write a TODO. – Snoop Apr 26 '16 at 12:50
