I have below in my stored proc
if
then
SELECT TABLE1.COLUMN1,TABLE1.COLUMN2,TABLE1.COLUMN3,TABLE1.COLUMN4 FROM TABLE1,TABLE2 where criteria1 (covers functionality 1)
UNION
SELECT TABLE1.COLUMN1,TABLE1.COLUMN2,TABLE1.COLUMN3,TABLE1.COLUMN4 FROM TABLE1,TABLE3 where criteria2 (covers functionality 2)
UNION
SELECT TABLE1.COLUMN1,TABLE1.COLUMN2,TABLE1.COLUMN3,TABLE1.COLUMN4 FROM TABLE1,TABLE4 where criteria3 (covers functionality 3)
elseif
then
SELECT TABLE1.COLUMN1,TABLE1.COLUMN2,TABLE1.COLUMN3,TABLE1.COLUMN4 FROM TABLE1,TABLE5 where criteria4 (covers functionality 4)
UNION
SELECT TABLE1.COLUMN1,TABLE1.COLUMN2,TABLE1.COLUMN3,TABLE1.COLUMN4 FROM TABLE1,TABLE6 where criteria5 (covers functionality 5)
UNION
SELECT TABLE1.COLUMN1,TABLE1.COLUMN2,TABLE1.COLUMN3,TABLE1.COLUMN4 FROM TABLE1,TABLE7 where criteria6 (covers functionality 6)
is it good idea to execute these SQL's separately (in parallel) and then put results in set (to get only unique) ?
I want to understand theoretically it is good idea or there is something I am not able to see right now?
Because SQL's are separate DB2 stored procedure internally might be running them in parallel already.
